Frame Sliders - Wrist Twisters
post #1 of 29 Old 03-09-2006, 01:44 PM Thread Starter
Naked in Cheese Land
Anti-Shadows's Avatar
Frame Sliders
Guys - I scored some 3" Delron cut-offs from a plastic company here and I want to make my own sliders. My question is where do you guys think the best place to bolt them on would be?
Position A - is what i'm thinking due to the fact that if I did go down it shouldn't put too much added torque on the engine casing.
Position B - would be good too, but I;m afraid of putting it down and the leverage of the slider cracking the casing.
What are your thoughts?
Anti-Shadows is offline
post #2 of 29 Old 03-09-2006, 01:50 PM
Wookie
ragdoll's Avatar
Should be put on whatever bolt is used for an engine mount. Said bolt should be a rod actually that goes all the way through to the other side.
Either that or I'm way off here. On an Engine mount for sure though. How would it break the engine case?
'02 RC-51
'10 Unicycle
ragdoll is offline
post #3 of 29 Old 03-09-2006, 02:02 PM
Honda Addict
razorbike's Avatar
http://p196.ezboard.com/fhornetsnest...cID=2663.topic
Check out the above link for the worst case scenerio of mounting them in position B. Nasty, nasty. He must have gone down hard because I went down hard enough to bend the bolt on a Sato slider and split the slider in half and my engine case came out ok. Still have mine in position B but after seeing that hole, I think I'm going to move them to position A!
razorbike is offline
post #4 of 29 Old 03-09-2006, 02:21 PM Thread Starter
right - so a threaded rod all the way throught the Frame to the Sliders - Not a problem - thanks for pointing me in the right direction.
post #5 of 29 Old 03-09-2006, 03:13 PM
Heavy Metal
ratdog's Avatar
honda OEM is option B
LOS is option A
i'd go w/ A and use the rod/sleeve as suggested
another point to consider is how they mate up to the frame...you don't want oversized sliders and an undersized bolt w/ too much offset between the slider and the frame creating an exaggerated point of failure...
checkout the LOS sliders, the LOS setup is a good place to start
15 seconds from talkin sh!t...
panhandling for gas money to CMP
the Project
H87 No Guts No Glory
ratdog is offline
post #6 of 29 Old 03-09-2006, 03:27 PM Thread Starter
RD do you have a link to the LOS information or is it the same link from Razor?
post #7 of 29 Old 03-09-2006, 03:58 PM
Here is another photo of a Sato mounted to the motor.
Not a pretty sight...
post #8 of 29 Old 03-09-2006, 04:05 PM
They say a picture is worth a 1000 words.
LOS crash bobbins
post #9 of 29 Old 03-09-2006, 04:19 PM
Honda Addict
razorbike's Avatar
Here's a link to get hooked up with the LOS sliders. I think I'll order some myself. Kinda like the way that setup looks. Much more peace of mind in that area.
http://p196.ezboard.com/fhornetsnest...picID=94.topic
post #10 of 29 Old 03-09-2006, 05:35 PM
Love Machine
awarble's Avatar
I ended up making mine. I picked the b location. Check my site to see mine that I made...
I thought a engine case would be cheaper than a frame so that's why I went with b.....Am I wrong in this thinking.....
Awarble,
07 Honda CBR600RR
My Site
awarble is offline
post #11 of 29 Old 03-09-2006, 05:37 PM
Brain stolen again?
Aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
的 said I never had much use for one.
Mathew Quigley
Bigdaa is online now
post #12 of 29 Old 03-09-2006, 05:40 PM
Brain stolen again?
Yes, adam, you are wrong wrong wrong like a swinging monkey dong. No seriously, a frame is gonna take a tweak and the case is gonna get boned. But I like the idea of making your own.
Mathew Quigley
post #13 of 29 Old 03-09-2006, 08:16 PM
Dark8
Guest
Posts: n/a
What are your thoughts on theses:
http://www.twistedthrottle.com/trade...view/2356/197/
Best of both worlds? Just wish they were about $100 cheaper....
post #14 of 29 Old 03-10-2006, 05:36 AM
Love Machine
awarble's Avatar
Yep, Bigdaa, I am wrong. That's what I get for assuming....lol. I just looked on Ronayers.com and the frame and the crankcase are only 126 dollars difference. Plus, what am I thinking, I would rather swap a frame than a whole engine case, I'm a tard.
Looks like I'll be moving mine for sure now!!!!!
Awarble,
07 Honda CBR600RR
My Site
awarble is offline
post #15 of 29 Old 03-10-2006, 06:13 AM
Heavy Metal
ratdog's Avatar
the part of the frame you're worried about is really just the cradle for the radiator and should be an easier fix than the engine case....
course, w/ sliders you never know til it happens...
the motion pro isn't a bad setup...if you add a rod and figure out how to flush up the bobbins a little tighter to the frame
the Project
ratdog is offline
post #16 of 29 Old 03-10-2006, 06:26 AM
BockHawk's Avatar
I picked up sliders from Motovation. Mounting location A for about $30 less than LOS crash bobbins. They use a rod all the way through, just like they should. I haven't had to use them, yet. Hopefully I'll never need them.
2002 919 40,000 miles
BockHawk is offline
post #17 of 29 Old 03-10-2006, 07:23 AM
Brain stolen again?
It would be a better choice than an engine case only. It gets to transfer load through a machined (therefore bendable and not breakable) aluminum mount to two different locations. I still gotta recommend getting away from any motor contact. The slider contact point is also placed away from the bolt centerlines and this makes a lever arm, which magnifies the force to the mounting points during impact.
I think that some of this stuff is engineered for sale and not for function. But in the case of the double mount, there is some thought given to the 'frailty' of the engine mount alone. It is a rule that cast stuff is weaker than machined billet. Also, steel is very good at absorbing energy while maintaining it's form without breaking.
Mathew Quigley
post #18 of 29 Old 03-10-2006, 07:40 AM
Heavy Metal
ratdog's Avatar
well said, thx 4 that
only other comment...the sliders that have a designed gap between the frame and the bobbin (creating that bad-news point of leverage), in some cases, can be improved w/a couple washers to take up the gap (thx m51142 4 the suggestion)
ratdog is offline
post #19 of 29 Old 03-10-2006, 08:38 AM Thread Starter
Thanks for the information gang - i need to make some time to get to the Lathe. I'll post pictures when i get it done.
post #20 of 29 Old 03-10-2006, 10:10 AM
Brain stolen again?
Just post some more pics of that chick with the chubs in your avatar (no offense if she's like your mom or gf or sis or wet nurse)
Mathew Quigley
post #21 of 29 Old 03-10-2006, 10:45 AM Thread Starter
Talk about Frame Sliders!!
Haven't found many pictures of tail on 919's - these two pictures sort of work for me cause they are riding the Wing.
post #22 of 29 Old 03-10-2006, 11:52 AM
I love when others post pics I've taken. I don't know why, just gain a little satisfaction from it. Just wish that weren't my bike
LOCATION A LOCATION A LOCATION A LOCATION A LOCATION A LOCATION A
bigassbertha is offline
post #23 of 29 Old 03-10-2006, 11:54 AM
Wait! I'll be damned, that's NOT my bike...
THIS is my bike... lol
post #24 of 29 Old 03-10-2006, 11:54 AM
Talk about an identical break...
post #25 of 29 Old 03-10-2006, 11:58 AM
Brain stolen again?
You know, babs, any publicity is good publicity.
And what excellent chubage!!!!!!
Mathew Quigley
post #26 of 29 Old 03-10-2006, 12:21 PM Thread Starter
Damn - guess we know what not to do now.
post #27 of 29 Old 03-10-2006, 12:36 PM
Brain stolen again?
Yes........that chick has great, uh, yes it's definitely not what to do......
mumumumu mammmmsssssss arggghhhhhhhhhh droooolll
Mathew Quigley
post #28 of 29 Old 03-12-2006, 08:51 PM
Trickhornet
Guest
Posts: n/a
oh wait I got mine too lol
I know how you feel but I got mine fixed!
Just smash your tank and bondo it or buy a new tank! frames and blocks can be a lot of money lol
post #29 of 29 Old 03-17-2006, 01:59 PM
Wazoo919's Avatar
Boy I have seen that up close.. thats my pic.. ouch.
05' 919
Wazoo919 is offline
