Fork Seal Job - Wrist Twisters
post #1 of 7 Old 04-09-2017, 05:57 PM Thread Starter
Fork Seal Job
Reading threads here.... just found my left seal is leaking while checking the bike out before i try to get it sold.
I'm gonna try the seal cleaning with a piece of film first just to be sure it's not dirt...but I'm never that lucky
Thinking if i replace one... i do both.
Any seals to prefer or stay away from when doing this?
I assume to do this, i'll be changing the oil too... i see someone here recommends maxima 10w RACING... that a good call, or look for something else?
anyone know the driver size for the seals? my friends who help/do this have stuff for their other honda bikes, and if i'm lucky the driver size will match... whether it's a real driver... or pvc.
Carphunter is offline
post #2 of 7 Old 04-09-2017, 06:22 PM
bartsitarski's Avatar
I would stick with OEM. They're good quality and cost roughly the same. Maybe a couple bucks more than aftermarket. I can't remember if the driver is 41 or 43mm, I would have to look at mine but it's at the new house. Far as fluid, you will have everything apart. Might as well swap it out. I use Maxima 7.
-Michael Jordan
bartsitarski is offline
post #3 of 7 Old 04-09-2017, 08:15 PM
I just did mine a few weeks ago, made a huge difference as my leak allowed water into the fork!
I used a PVC pipe that was cut to make slots so that I could use a hose clamp to make the correct size. It worked like a champ.
post #4 of 7 Old 04-11-2017, 10:46 AM
The Instigator
Ditch's Avatar
Speaking of fork seals, if one were to be stupid enough to allow some brake fluid drip down the fork without noticing, would that be enough to destroy a seal?
2007 919
2003 CBR1100XX
Ditch is offline
post #5 of 7 Old 04-11-2017, 03:47 PM
I think if you were to flush it out soon enough, you'd be fine. I think it's the different kinds of fluids and how they mix that could be a problem. I would guess that the damage would be the seal going bad and you'll know about that over time.
post #6 of 7 Old 04-15-2017, 06:33 AM Thread Starter
going to pick up parts today... reading other threads about possible o-ring needs when taking this apart... in this diagram are we talking part 23 or 24 for the o-rings that may need to be replaced?
http://www.bikebandit.com/oem-parts/...1030#sch421803
also how much oil per fork will i need to have?
and how much difference between using maxima 7 wt vs maxima 10 wt? (10 appears to be stock weight...that's why i ask)
post #7 of 7 Old 04-15-2017, 03:25 PM
1 Liter did both forks. I'll let someone else talking about the wt, but I went stock. Basically it's about how thick the oil is and that's about the speed that it flows thru the holes. It can be used to fine tune, but the stock 919 front is not known as the best and since mine is bone stock, I went with OEM.
The o-rings on mine were fine, I reused them, but I imagine they are cheap.
I used brake cleaner on mine because I had sludge built up after water got in. Some don't like that and others say put some fluid in there and flush out the cleaner, then fill with clean fork oil. I didn't bother with that, just cleaned dried and refilled.
