Exhaust Swap/Header Torque Specs - Wrist Twisters
post #1 of 17 Old 11-17-2008, 07:13 PM Thread Starter
Heath's Avatar
I finally got parts in to start changing to a low side exhaust. I've gone with a 98 900 header and a Leo Vince can. The Leo Vince was a good price and I think the removable silencer might make long rides easier on the ears. I have the header put on and waiting on the can to show up in the mail, hopefully by Thursday. I left the header mounting bracket on in order to fashion a mount using the center stand mount.
Thanks for everyone on here that has written about this swap. The suggestions, especially on how to remove the Y pipe, were extremely helpful. I would have not got to this point without the great help from you all on this forum. And if anyone had seen the balancing act to get the shock off and back on, they would post it as "How not to remove the Y pipe."
Does anyone know about what the header bolt should be torqued to? While removing the bolts, I found them much less tight than I imagined. I would love to not over tighten them, that would be bad, but I also want to make sure the new gaskets are well seated.
If anyone out there is thinking about doing the lowside exhaust, or the GP shorty can mod, I have a black set of 900 head pipes that i need shed of. I got them fairly cheap, but they need sandblasted to clean them up and look more presentable. I'll end up posting them on Ebay by the weekend, but I figured I'd mention them here.
Heath is offline
post #2 of 17 Old 11-17-2008, 11:11 PM
The manual specifies 14 ft/lbs torque. It also gives a length specification for the studs, measured from the tip of the stud to the ring gasket sealing surface in the head, 42.5mm plus or minus 0.5mm, obviously with the gasket removed. This is given to check for previously overtightened nuts which may have stretched the studs, possibly breaking when retightened.
You will have to be careful when installing the header, first to use new ring gaskets, second to be sure all four head pipes are fully inserted and contacting the gaskets before running the nuts down, third to make sure the nuts are finger tightened to contact the flanges on both sides and the flanges are seated squarely on the headers, and fifth to torque the nuts a small amount at a time until the torque is reached. After the whole system is installed and the engine is run for a couple days recheck the torque to be sure everything has settled in properly. Some loosening is normal as the gaskets bed in, but it should not require much rotation to bring back to proper torque.
post #3 of 17 Old 11-19-2008, 05:35 PM Thread Starter
Heath's Avatar
I finished up the exhaust this evening. Everything for the most part went smooth. I mounted the can to the footrest with a piece of L shaped plat metal I found in Lowes. I also used the head pipe mounting bracket and bolted it to the center stand frame piece with a rubber grommet to hopefully help with vibration.
So far, just in the garage, I think it sounds good. I'll take it out tomorrow or friday to see how she's running.
Thanks again to everyone that has written about this before, it helped a bunch. And thanks for the torque specs, I would have over tightened the hell out of them. I think there is a pic attached.
And before it gets said, yes, the shovel of a rear fender will be gone soon.
Heath is offline
post #4 of 17 Old 11-19-2008, 05:36 PM Thread Starter
Heath's Avatar
And before you comment on the bracket being off center, I cut it too much. I already plan on remaking it.
Heath is offline
post #5 of 17 Old 11-19-2008, 06:09 PM
PM sent about the headers.
Ripper is offline
post #6 of 17 Old 11-19-2008, 06:15 PM
Nice job. Looks good.
post #7 of 17 Old 11-19-2008, 06:17 PM Thread Starter
Heath's Avatar
I have to retrack my statement about the black set of headers. These pics show why I think. The rust could be sand blasted off, but the two dents in the center two pipes makes me think I need to return them to the ebay seller. I am sorry about posting about them before getting a good look, I took the seller's word that they were in good shape. My bad.
Heath is offline
post #8 of 17 Old 11-19-2008, 06:56 PM
Very nice job Heath. Thanks for the pics. I am getting ready to do the single sided exhaust and was thinking about using the existing bracket and mounting to the center stand bracket. Good to see it pretty much lines up.
post #9 of 17 Old 11-19-2008, 07:19 PM Thread Starter
Heath's Avatar
If you do it, I would suggest making the rear bracket first, to push down the can where you want it. Its easier to do that, then drill and mount the header bracket to the center stand bracket.
As far as a rubber/anti-vibration mount. I found some windshield wiper bushings at Autozone. You have to take out the center metal piece, very easy, and it makes a pretty good grommet for the header bracket.
Heath is offline
post #10 of 17 Old 11-19-2008, 08:12 PM
Great idea. Thanks!
post #11 of 17 Old 11-20-2008, 04:03 PM Thread Starter
Heath's Avatar
I got the first ride out of the way. I like the way the bike feels to run better. I'm not sure its faster, but it feels like it gets through the low RPM's better. The Leo Vince sounds good, but its a little quet for my taste, I should got a D&D or a Hindle. Here's for hoping that it gets louder with time.
Heath is offline
post #12 of 17 Old 11-22-2008, 04:06 PM Thread Starter
Heath's Avatar
I went cheap and cleaned up the tail with the existing fender, minus a lot of plastic. This is not an end product, but will do until I can put the money into turn signals for the front and rear. I think next will be a red fly screen, maybe santa can hook it up.
Sorry the pics aren't better, I always seem to finish in the dark.
Heath is offline
post #13 of 17 Old 11-22-2008, 04:44 PM
Looks great man!
I got the headers today, thanks!
Ripper is offline
post #14 of 17 Old 11-22-2008, 04:59 PM
Nice work! I am gonna start on mine hopefully next weekend.
post #15 of 17 Old 11-23-2008, 04:09 PM Thread Starter
Heath's Avatar
Here are a couple videos for the sound of the new exhaust. Its definitely different than stock.
http://www.youtube.com/watch?v=HvzF4LUfzZk
http://www.youtube.com/watch?v=uxInVAqRclU
Heath is offline
post #16 of 17 Old 11-23-2008, 05:45 PM
Sounds awesome in that second video. Definitely a much deeper tone.
post #17 of 17 Old 11-23-2008, 06:01 PM
Looking at these headers more, I'm getting excited. I've moved on to a new cheaper and easier plan that I hope will net positive results. I'm going Hardcore GP on these babies.
Ripper is offline
