Exhaust gasket - Wrist Twisters
post #1 of 8 Old 09-29-2008, 07:47 PM Thread Starter
Barry570's Avatar
Exhaust gasket
If I remove my exhaust header from my 919 would I be able to reuse the header gaskets. What are the gaskets made of metal or some kind of fiber.
Thanks
Barry570 is offline
post #2 of 8 Old 09-29-2008, 07:52 PM
New gaskets
post #3 of 8 Old 09-29-2008, 07:57 PM Thread Starter
Barry570's Avatar
That what I thought
Thanks
Barry570 is offline
post #4 of 8 Old 10-06-2008, 01:43 PM
I recently had my header off, and also replaced the slip-ons, but did not notice any gaskets at any of the connections.
I'm looking at the online microfiche and it shows a gasket for each cylinder, one for the connection to the Y-pipe, and one for each slip-on. Do all these gaskets need to be replaced any time the header, Y-pipe, or slip-ons are removed?
I've only ridden it about 20 miles since putting the header back on, but I don't notice any difference in sound or performance with the old gaskets.
The bike is new, I'm just wondering why I didn't notice any of the gaskets, are they stuck up in there?
post #5 of 8 Old 10-06-2008, 02:43 PM
Hey Mdtoney
Glad your back in the saddle.
The gaskets I'm used to are normally copper 1 at each head pipe. If you didn't notice them they were most likely stuck in the header or head, if you don't notice any extra noise don't worry you lucked out ! I know nothing about any Y pipe or slip on gaskets.
post #6 of 8 Old 10-07-2008, 12:33 PM
9nineteen's Avatar
Donation BOTM
Originally Posted by ideajones View Post
Hey Mdtoney
Y-pipe and slip-ons use a lead-like gasket. If it didn't fall apart when taking apart your exhaust, 98% of the time they are re-usable. Mike, you were lucky with the copper header gaskets. The header fell into its original position on the gaskets causing no leaks/abnormal sounds. Once the header is seated off slightly on the original gaskets, you'll definitely hear "piffing" sounds around the head and exhaust.
When are we going to see your mods in-progress pics???!!!
9nineteen is offline
post #7 of 8 Old 10-07-2008, 12:49 PM
I'll listen closely for the piffing or any other abnormal noises. If I hear this piffing, is it bad for the engine or just annoying?
When I pulled the header, no gaskets came out of the cylinder and nothing was stuck inside or on the ends of the header pipes; and the header slid out of the Y-pipe easily with no gasket residue and nothing falling apart. The same as when I swapped the slip-ons, no gasket material and the old ones came off easily and the new ones went on with with no problems. It might be because the bike only had 1400 miles on it at the time.
Roy, I didn't get to work on my bike last week or the weekend, but I plan to spend time on it this weekend, so I'll be able to take some photos of the progress so far. Unfortunately, the upper triple clamp and the powdercoated parts are still another week or two away...
post #8 of 8 Old 10-07-2008, 01:41 PM
9nineteen's Avatar
Donation BOTM
When I pulled the header, no gaskets came out of the cylinder and nothing was stuck inside or on the ends of the header pipes. . .
If you didn't hear anything, re: exhaust leak, after reinstalling the header, then you should be OK. If it's leaking, the noise will be annoying more than anything. But check after you get your 9er back together with a few hard throttle runs. When you first pulled your header off, the copper gaskets stayed jammed in the recess of the exhaust ports. Usually, they need to be pried out with a screw driver after being squished in the recess by the header manifold.
Pics please!!
