Engaging to neutral gear - Wrist Twisters
post #1 of 17 Old 04-30-2012, 08:51 PM Thread Starter
ragemydream's Avatar
Hi all
After riding for seven years, now having problem to engage neutral gear while bike is stationary. Especially, stopping at traffic light, makes it difficult to down to neutral. Does anyone know where's the problem or experience before?
Btw, I had changed engine oil and lube the chain, helps a bit.
ragemydream is offline
post #2 of 17 Old 04-30-2012, 09:04 PM
are you comming to a full stop then attempting to hit neutral?
if so thats why... your fully stopping the tranny from spinning... try going all the way to first then as your just about to stop (say 2 mph) pop it into neutral.
or if your stopped and want to get it into neutral... pull the clutch in (well obviously its in... its in gear) and rock the bike back and forth while going for neutral.
post #3 of 17 Old 04-30-2012, 09:55 PM Thread Starter
This situation just happen recently, I never experience this before. Plus I did not change anything except X-ring chain. I tot it was the old chain problem but after the chain, still the same.
Strangely is when I off the engine, it is very easy to kick to neutral.
post #4 of 17 Old 05-01-2012, 05:42 AM
Hastatus Prior
TheBeeDeeGee's Avatar
Yeah this, I had this problem with my 599 at first. If you are changing down through all the gears as you come to a stop at the traffic light without letting the clutch out the whole way down it will get stuck. It won't go into first or neutral without rocking the bike.
Solution is to let the clutch engage a couple of times coming to a stop. 6,5 let out the clutch, 4,3..let out the clutch...2,1. Dunno if that's the problem, but there it is.
Sent from my DROID RAZR using Tapatalk 2
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
-2006 599 ** WRECKED
TheBeeDeeGee is offline
post #5 of 17 Old 05-01-2012, 07:42 AM
This ^^^
The tranny does not like the shift from second into neutral at a standstill. It's not a flaw it's a feature. You should be in first by the time that you have stopped anyway...
try to be careful about sitting at an intersection in neutral. That is a good way to have somebody rear-end you while you are being all relaxed and inattentive.
I will always wait until I have at least one car stopped behind me before shifting to neutral and relaxing, that way I wont be unpleasantly suprised.
Ride safe!
post #6 of 17 Old 05-01-2012, 11:14 AM
I had a problem like this recently with my Thunderbird... turned out that the clutch cable had stretched out enough that the clutch was not fully engaging, and needed to be adjusted to pull the clutch all the way in.
I am still waiting on the replacement clutch cable, as I figure if it has stretched that far after 30k miles, it is time for a replacement before it snaps and leaves me stranded somewhere.
2010 Triumph Thunderbird 1600
Wells is offline
post #7 of 17 Old 05-01-2012, 01:36 PM
clutchless riding isnt all that bad.... just gotta time the neutrals at the stop right good.
ya OP how much free play you got in the lever?
post #8 of 17 Old 05-02-2012, 06:51 AM Thread Starter
Clutch cable problem...
I'm wondering if it's clutch plate worn out.
post #9 of 17 Old 05-02-2012, 08:25 AM
It's not. the clunk/lurch is normal, based on how you described the situation. You're giving yourself the vapors. Go ride!
post #10 of 17 Old 05-02-2012, 10:38 AM
cannon
swcannon80's Avatar
Shouldent be putting it in neutral at light youtube rearended biker and see how that looks just my two cents
swcannon80 is offline
post #11 of 17 Old 05-03-2012, 08:33 AM Thread Starter
After adjusting the clutch cable, the problem is resolved. Thanks all
post #12 of 17 Old 05-03-2012, 08:59 AM
Boo-yah! Called it in one!
Since this is also an indication that your clutch cable is stretching, I would recommend you get one ordered for replacement now, like I have. It would really suck to be out there somewhere and have that cable snap completely!
Wells is offline
post #13 of 17 Old 05-03-2012, 09:05 AM
dont be so excited, adjusted clutch or not, if he tries to shift down more than 2 gears at once while stopped, he'll still have the same issues its just a 919 thing you gotta work around.
also, ALL cables stretch to a point. thats why there's 2 adjustment points (1 on each end of the cable) to account for this. when one gets near the outer limits of the adjustment zone is usually a good indicator of when to buy a replacement for the cable can either just snap at that point or continue to stretch beyond the adjustable zone. there's no predicting it.
best thing to do for a stretching cable is to lube it. this greatly extends the life of the cable only takes 5 minutes from start to finish.
post #14 of 17 Old 05-03-2012, 09:24 AM
You must do this often, is this why it hangs down to your knees???
post #15 of 17 Old 05-03-2012, 09:30 AM
why do you think my wife married me? she caught a glimpse of the beast and that sealed the deal: Deaf or not
post #16 of 17 Old 05-03-2012, 09:36 AM
So you're a one-eyed, deaf snake?
post #17 of 17 Old 05-03-2012, 10:51 AM
AAAANND you dont get any of the action
