Emergency sticker removal - Wrist Twisters
post #1 of 52 Old 04-09-2008, 01:34 PM Thread Starter
(oYo)
2000TJ's Avatar
Has anyone had problems removing the white sticker below the gas cap on the 919 tank? I think it used to say wear a helmet or something like that.
I pulled mine off easily enough but it left a clear plastic-like layer below it which has thus far thwarted my attempts to remove it. I've tried Windex and commercial sticker/adhesive remover as well as a sharp razor blade with no luck.
I'll admit that I treaded very cautiously with the blade.
Has anyone else had this issue?
2000TJ is offline
post #2 of 52 Old 04-09-2008, 01:37 PM
Kerosene and a flame thrower, I tried to take that sticker off my VFR and never did get the sticky crap off, why don't they use that stuff to put the heat tiles on the space shuttle.
post #3 of 52 Old 04-09-2008, 01:39 PM
bucky's Avatar
wd 40 will do it.
clean it afterward, maybe a little wax depending on your color.
well, your bike's.
bucky is offline
post #4 of 52 Old 04-09-2008, 01:43 PM
Yeah, used alcohol on mine to remove the sticky, then had to polish it up a bit but still took awhile before it faded to match the tank.
post #5 of 52 Old 04-09-2008, 01:43 PM Thread Starter
(oYo)
2000TJ's Avatar
although I didn't list it I think I did try the WD40 already. The commercial stuff I used was also pretty volatile smelling stuff. I was really surprised when it didn't soften it up at all.
I will revisit the WD40 and try some Kero as well. Oh ya, liberal use of my heat gun did little as well.
Tanks for the ideas.
2000TJ is offline
post #6 of 52 Old 04-09-2008, 01:44 PM
Cafe Racer
BARROSART's Avatar
BOTM
Citrus Oil
BARROSART is offline
post #7 of 52 Old 04-09-2008, 01:46 PM
3M adhesive and wax remover. A little goes a long way. Trick is, to let it soak for a minute and keep it saturated w/ a paper towel.
post #8 of 52 Old 04-09-2008, 01:50 PM
Originally Posted by BARROSART View Post
Citrus Oil
Have you really had luck with that stuff?
I haven't found it did a single thing even remotely as well as they claim.
post #9 of 52 Old 04-09-2008, 01:55 PM
I've never had anything Goo Gone worked on either, it made an attractive black smudge on my tool box when I tried to remove a sticker off of it (WD-40 fixed that)
Where's the Va-Poo-Rize when you need it?
post #10 of 52 Old 04-09-2008, 01:55 PM
2000TJ,
Try a WD-40 squirting, goo-gone launching flamethrower with a razor blade mounted on the front.
Actually WD-40 alone should do it.
post #11 of 52 Old 04-09-2008, 01:55 PM Thread Starter
(oYo)
2000TJ's Avatar
The one thing I should clarify here is that there is no exposed adhesive, on which any of the recommended products would work great.
There is a thick plastic "remnant", stuck to the tank. In this case GOO Gone wont even come close.
I'm suRprised no one else has seen this.
2000TJ is offline
post #12 of 52 Old 04-09-2008, 01:56 PM Thread Starter
(oYo)
2000TJ's Avatar
quick, someone post a pic of Chuck Norris
2000TJ is offline
post #13 of 52 Old 04-09-2008, 02:02 PM
MAM Customs
majorrager's Avatar
You are going to have to very carefully get under it with a razor blade and get all of that film up. I had no problem with mine but my brother's was a pain in the butt. It came up in little sections at a time. After that's all gone, ordinary lacquer thinner on a soft rag will get the adhesive off in 2 or 3 quick passes. Wax afterwards will restore color.
I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day. -Frank Sinatra
majorrager is offline
post #14 of 52 Old 04-09-2008, 02:03 PM
frikjmaser's Avatar
I know what youre talking about! You peeled the sticker in half basically and the base is still there. You just gotta pick at it, alot, to get it to separate from the tank. Then alcohol or goo-gone to get rid of any remaining sticky. Same thing happened on my old 750 Nighthawk. I was impressed that when I bought it in 06 this 97 still had its tank sticker, and it was in good shape, gave me hell removing it tho.
Erik
I've got a lot of places to see! (on the bike) :-)
frikjmaser is offline
post #15 of 52 Old 04-09-2008, 02:06 PM
Wookie
ragdoll's Avatar
Citrus Oil
YES
'02 RC-51
'10 Unicycle
ragdoll is offline
post #16 of 52 Old 04-09-2008, 02:07 PM Thread Starter
(oYo)
2000TJ's Avatar
Thanks guys. I'll grab a beer and a blade when I get home and try again.
Maybe I can live this down some day.
... some day
2000TJ is offline
post #17 of 52 Old 04-09-2008, 02:35 PM
Donation BOTM
You on the right track with a heat guy, get it good and warm and use a bit o' WD40 - that should get it right off -
2ohno is offline
post #18 of 52 Old 04-09-2008, 02:45 PM
Cafe Racer
BARROSART's Avatar
BOTM
it works for me, even took the tank sticker off.
I use it on everything, cereal...
post #19 of 52 Old 04-09-2008, 04:00 PM
Hows about this stuff? It takes the annoying glue from window tints. They named it after what I did alllllll day at work today.
(Do not use in cereal)
dhernb11 is offline
post #20 of 52 Old 05-12-2008, 01:07 AM
Blow Dryer. Get it hot, peel up one edge, then try to pull it as fast as possible so the adhes. doesn't stick. If it does stick, use your finger to roll it into a little ball. After that, keep rubbing with your finger. It'll come off after a minute or so.
FollowtheNerd is offline
post #21 of 52 Old 05-12-2008, 01:38 AM
I like yellow bikes
Janet the jet's Avatar
Hairdryer
I've always just used a hairdryer and fingernails, then some kind of wax polish to get rid of any glue left behind.
It is infinitely easier to get these stickers off if they've not been on the bike very long though.
I got my new Hornet 600 last Thursday. It had come straight from Honda's UK distribution centre and was an '08 bike, so it hadn't been in stock very long. It took me no more than a couple of minutes to get the two stickers off the tank cleanly, in one piece, without leaving any trace of glue residue. This was done by warming with a hairdryer until I could pick a corner up with my fingernail, then peeling clean off.
However, when I did the same with my '06 R1 a year and a half ago it took much more perseverance, as the bike had been sitting around for much of the summer before I bought it. The hairdryer still worked, eventually, but the stickers broke up and I just had to keep going at them with my fingernails, while keeping them warm, and then there was quite a lot of glue residue to polish off afterwards.
Janet the jet
Janet the jet is offline
post #22 of 52 Old 05-12-2008, 05:20 AM
lusting over something...
james_kraska's Avatar
+1
I just used a hair dryer (~2-3 mins) as mentioned above and rolled it off w/ my fingers. honda polish afterwards and you couldn't even tell that there was anything there.
james_kraska is offline
post #23 of 52 Old 05-12-2008, 05:27 AM
I just used Honda Polish!
silver1 is offline
post #24 of 52 Old 05-12-2008, 06:01 AM
Hot sun, peel, goo gone, polish.
dmclone is offline
post #25 of 52 Old 05-12-2008, 07:14 AM
If you have not gotten the sticker off yet you might want to try mineral spirits. I used it to remove all the stickers from the 919 tank and rear fairing 919 decals. Not the honda wings on the tank as they have a clear coat over them. I'd like to take them off but I do not want to pay for the clear coat touch up. Or have the bike off the road during the good riding season. Maybe, in the winter. Anyways ... light coating of mineral spirits ... let it soak ... rub lightly with a soft cloth. Repeat, repeat, repeat ... btw heat from a blow dryer will also help speed up the process. Be sure to wax afterwards. Mineral spirits will take all the wax off the bike. I got this trick from the guys that do pin stripping as this is what he was using before painting his pin-strips and designs.
Unknown is offline
post #26 of 52 Old 05-12-2008, 07:52 AM
Franklin McGillacutty
riquefied919's Avatar
I can't recommend this but I used 20% nitro fuel for my R/C cars it took adh. off yust like that then I washed really well
riquefied919 is offline
post #27 of 52 Old 05-12-2008, 07:55 AM Thread Starter
(oYo)
2000TJ's Avatar
Thanks for the updates everyone. I'll admit that once the weather turned for the better here in Wisconsin i haven't as much as washed the bike... just riding and lubing it.
One of these days i'll give that damn sticker another 10 minutes of my time.
2000TJ is offline
post #28 of 52 Old 05-12-2008, 08:03 AM
Unbannable
Super Sneaky Steve's Avatar
I used a hairdryer then some gasoline on a rag.
Super Sneaky Steve is offline
post #29 of 52 Old 05-12-2008, 11:09 AM
Tire abuser
prtsimmons's Avatar
I like to use a pressure washer to remove stickers. You need to be careful and use the right amount of pressure, and get the tip of the pressure washer really close to the sticker. The pressure washer can mess up paint, seals, bearings if abused, so be careful! I just removed some dealer stickers from the rear cowl on my 919 at the self-serve carwash last week.
I always use lighter fluid for sticky residue.
prtsimmons is offline
post #30 of 52 Old 05-12-2008, 12:02 PM
Church of the Holy Smoke
MotoCycho's Avatar
... some day
Dear Lord! Stay away from it with the razor (and pressure washers for that matter)... you will just scratch the paint for no reason. Might as well hit the paint with a DA and some 80 grit! In fact.. there ya go.. tears that sticker right up. Sheesh!
Lacquer thinner or Acetone will certainly do the trick. You can pick the suborn edges with a finger nail. Once you have got to the sticky stuff the chemicals will dissolve it in seconds. Use a soft rag folding or swapping often.
Can't believe I am participating in this thread.. this is such basic crap. Should be on the first page of the owners manual.
This is why I pull the hideous stickers as soon as I unload the new bike from the trailer and before I even break-in the engine. It always rains the day I bring home a new motorcycle so there is plenty of time to remove lame stickers and reflectors.
- Rev. CYCHO -
MotoCycho is offline
post #31 of 52 Old 05-12-2008, 12:07 PM
speed limits?
i used a cottonball with everclear (yes, the grain alcohol) and goo gone and it all came off
mitsubishimarc is offline
post #32 of 52 Old 05-12-2008, 01:00 PM Thread Starter
(oYo)
2000TJ's Avatar
I'm sure you're not a prick in real life.... just on the internet.
2000TJ is offline
post #33 of 52 Old 05-12-2008, 01:09 PM
MotoCycho's Avatar
It's true. If I knew ya I'd drive over and do it for ya )
Avoid sharp things and use chemicals on soft rags. Modern Urethane paints can't be hurt my Lacquer thinner or Acetone. Even naphtha or Prep-all (wax and grease remover, pre-paint surface cleaner) would do the trick.
Anyway... back to being a prick!
- Rev. CYCHO -
post #34 of 52 Old 05-12-2008, 01:12 PM Thread Starter
(oYo)
2000TJ's Avatar
That's the way I felt when Lemonhead started that horrible rumor that I was a laid back guy.... "hey man, i've got a reputation to uphold here!"
2000TJ is offline
post #35 of 52 Old 05-12-2008, 01:22 PM
Unbannable
Until recently I actually thought you were a chick in pink riding gear. Possibly a lesbian.
post #36 of 52 Old 05-12-2008, 01:31 PM Thread Starter
(oYo)
2000TJ's Avatar
I am a lesbian, trapped inside a man's body. Love the ladies.
Actually, that's just the LADY now.
2000TJ is offline
post #37 of 52 Old 05-12-2008, 01:38 PM
I'm the only one Honda Polish worked for? Only took a few minutes.
silver1 is offline
post #38 of 52 Old 05-12-2008, 03:04 PM
What years is your bike? My Honda wings didn't have clear over them. Mine is an '02. Anyone else have clear over the decal?
post #39 of 52 Old 05-12-2008, 03:07 PM
Unknown is offline
post #40 of 52 Old 05-12-2008, 03:45 PM Thread Starter
(oYo)
2000TJ's Avatar
My wings have clearcoat over them as well. 2006
2000TJ is offline
