Electrical power? - Wrist Twisters
post #1 of 33 Old 11-05-2006, 10:27 AM Thread Starter
Electrical power?
how many watts does the alternator (or stator) put out.. any body know..
looking at electric vests etc and figure it might be an issue.
Thanks
Mitch
Mitch
'83 Suzuki GS750E
'02 Honda 919
Roseknight is offline
post #2 of 33 Old 11-05-2006, 10:45 AM
I don't know for sure but I hooked up a cig lighter adaptor with a 15 amp inline fuse and mounted it under the seat for cell phone charging in a pinch and it seems to be fine as long as I plug it in and wedge my phone down in the tool storage area and ride with it. If it sits and idles or turned off the phone charger kicks the hell outta the charging system.
typhoonblue919 is offline
post #3 of 33 Old 11-05-2006, 10:46 AM
BockHawk's Avatar
Owner's manual says .377kw at 5000RPM. This is just over 30 amp, so you should be able to plug quite a bit of hardware in w/out issue.
2002 919 40,000 miles
BockHawk is offline
post #4 of 33 Old 11-05-2006, 10:51 AM
Yup 377Watts @ 5000RPM. Depending on what other extra loads you added, 1/3 or 125W should be fine. May want to add a volt meter to make sure it stays >12.3V spec idling in traffic.
dream is offline
post #5 of 33 Old 11-05-2006, 11:03 AM
919 Lighting specifications
Added lighting specifications link to the Helpful Topics for new 919 owners:
post #6 of 33 Old 11-05-2006, 11:27 AM
jnor
Guest
Posts: n/a
I just got back from rideing mine with my electric vest, and heated grips on with no problems.
post #7 of 33 Old 11-05-2006, 02:52 PM
Curmudgeon
semi_gray's Avatar
Lots-O-Watts
I rode to work all last week with morning temps in the mid 20's. I use a Widder electric vest, arm warmers and gloves with no problems whatsoever. I made an instrument "panel" that fits above the factory gages and fits in the bubble of my GIVI A755 faring. In that panel I mounted a Powerlet outlet that's powered via a fused line I installed. Alongside, I mounted an Accumen gear indicator. I'll see about getting a pic and posting it here later. It really works great since I can use this outlet for GPS, Phone, etc...
semi_gray is offline
post #8 of 33 Old 11-05-2006, 02:56 PM
I tip my hat to you youngins' that is waaay too cold for me!
post #9 of 33 Old 11-05-2006, 03:11 PM Thread Starter
I have the same givi fairing.. and would love to see a pic of the "panel"
been having idea's along that lines myself..
as to riding in the cold.. it don't stop me much.. but as I get older I enjoy it less.. thus the electrics to keep the enjoyment level up
and thanks to everybody for all your answers.. really helps..
don't know why I couldnt translate the kw to watts earlier..
Mitch
'83 Suzuki GS750E
'02 Honda 919
post #10 of 33 Old 11-05-2006, 03:47 PM
Curmudgeon
semi_gray's Avatar
Here are a couple of shots taken in haste. I made the panel out of 1/8" sheet aluminum and cut it on a band saw using a cardboard template I'd made. The brackets attaching to the GIVI brackets were trickier. I started off with a piece of wood to get the shape, then took the wood to work and fabricated the shape in aluminum. LOTS of compound angles! The brackets I made have three (3) 8-32 threaded holes each and after I clamped the mess together, I drilled holes (two) in the GIVI bracket as well as the aluminum sheet to position the "panel" where it needed to be.
The front view shows how the Accumen is held. Since it's slightly tapered, I machined a "picture box" out of black plastic, drilled and tapped a series of again, 8-32 holes, then "drew" the plastic piece toward the aluminum using the six button head stainless screws you see throughout.
I did capture the shape of some of this in AutoCAD, so I may post these files if I can dig them up on my work computer.
I can also relate to the colder / older relationship. But with the electrics, it's down to the hassle of all the gear since the cold can really be effectively dealt with using the proper apparel. I also highly recommend a “FOGGY” mask in sub-freezing temps.
post #11 of 33 Old 11-05-2006, 03:56 PM
ajcombs's Avatar
Helping a Member in Need
Where did you get the wattage spec of 1/3 or 125Watts? I'm sure that Honda built in a buffer for some extra loads to be added(I hope) just wondered if it was based off of experience or a specifaction wrote down somewhere.
ajcombs is offline
post #12 of 33 Old 11-05-2006, 04:09 PM
The total budget wattage and minimum voltage are in the service manual. I listed a conservative wattage accessory load based on experience, and probably still safe at 50%. Too much load would have dire effects on your electrical system. Plus if you ride in the rain protect the wiring so it doesn't short out.
Be sure to have the motor running before turning on high loads. It sucks to short out your battery in the middle of now where. That happened a while back with a full heated suit and detector while getting gas. "can I borrow some jumper cables to jump start my bike?"
dream is offline
post #13 of 33 Old 11-05-2006, 04:24 PM
Boy, howdy. My bike has been in the great room since the middle of September. If it ain't 70 degrees or more, I ain't riding.
20 degrees. The lad is crazy.
rickmears is offline
post #14 of 33 Old 11-05-2006, 04:49 PM
When I had my Nighthawk 750 knocked out from under me I was riding home from work. It was 2am and 19 degrees outside. First thing said to me as I lay on the ground was not "Are you ok?" but "What the hell are you doing riding in this weather?!?"
Kahuna is offline
post #15 of 33 Old 11-05-2006, 11:00 PM
Kahuna, you must have been riding through a hurricane!
Once on my 600lb bike I changed two lanes without wanting to.
You guys riding in 20os have huge cahones and inspire me! I'm going to search for heated vests.
dream is offline
post #16 of 33 Old 11-06-2006, 12:05 AM
semi grey, where did you get that panel from or did it come with the power outlet? That is a really nice job you did.
post #17 of 33 Old 11-06-2006, 08:36 AM
Church of the Holy Smoke
MotoCycho's Avatar
I rode to work all last week with morning temps in the mid 20's. ....
Um.. get a car bro! Brrrr!
- Rev. CYCHO -
MotoCycho is offline
post #18 of 33 Old 11-06-2006, 04:21 PM
DaveCB919F4
Fastbackdlm's Avatar
Vintage air makes a A/C-Heater unit you could hook up . With that and a moon suit you could be comfortable year round. Or drive the cage.
Fastbackdlm is offline
post #19 of 33 Old 11-06-2006, 11:04 PM Thread Starter
Thank you very much for the pics.. like I said been thinking about that..
just hadnt come up with a way of doing it neatly.. the job you did there has given me ideas I can work with..
Mitch
'83 Suzuki GS750E
'02 Honda 919
post #20 of 33 Old 11-07-2006, 04:07 AM
BockHawk's Avatar
Hang on a sec...you live in TX, right? And you need the vest because...?
BockHawk is offline
post #21 of 33 Old 11-07-2006, 04:42 PM Thread Starter
yes in TX... because it gets cold.... below freezing is not unheard of.. and it's ussaly a wet cold.. and rather then park the bike for a couple months.. plus if you've noticed.. motorcycles have wheels on em.. and mine isn't always in Texas.. I don't like my trips limited due to temps..
Mitch
'83 Suzuki GS750E
'02 Honda 919
post #22 of 33 Old 11-07-2006, 05:23 PM
ajcombs's Avatar
Originally Posted by Roseknight View Post
plus if you've noticed.. motorcycles have wheels on em...
IS that what those round thingy's are??
ajcombs is offline
post #23 of 33 Old 11-07-2006, 09:43 PM
whats so great about YOUR room ? huh.. I think my room is better.
post #24 of 33 Old 11-07-2006, 10:47 PM
power distribution
Today I installed the 6 line distributor and grounding disk under the seat from
http://www.electricalconnection.com
I like that it allows you to set different fuse limits for all accessories and is power relay enabled and master fuse protected. First I wired the stebel horn in, nexy plan on adding a sealed accessory socket, jacket and gloves. I may need to turn the heaters off before using the air-horn.
dream is offline
post #25 of 33 Old 11-08-2006, 09:45 AM
Rangers Lead The Way!
Ranger919er's Avatar
Dream,
Where did you mount the distributor? I have my autocom in the space on the left side under the seat. I'm looking for a place to mount one of these myself.
Thanks.
Ranger919er
Terrorism is a disease. Rangers are the cure.
Ranger919er is offline
post #26 of 33 Old 11-08-2006, 10:23 AM
Ranger,
Unfortunately you picked prime realestate for the Autocom.
I've read those are great (sound quality/noise canceling), but I am looking for a TBD compact blue tooth version (any suggestions?). You can free up space putting your "wireless" tool bag in the tank bag?
I mounted the ground disk and fuse panel on the left side and stuffed the new two horn/panel relays taped and padded on the right side above the main. I ran the wires under the frame top, so the seat doesn't rub them. I wired the panel mains directly to the battery, solder tapped (stripped insulation but not cut) the ignition relay of the PC red wire. One gripe with the panel, it doesn't come with a cover to protect the fuses from moisture/breaking; their service response "we never had a problem", Famous last words! Be careful to mount it securely so it doesn't spark off the ground disk and place it high in the pocket so moisture cannot puddle on it.
The line panel is a good way to add current devices. The stock battery is small, so watch the average/peak watt load ratings or always park at the top of hills.
dream is offline
post #27 of 33 Old 11-09-2006, 08:00 AM
A couple device/wiring tips. The light duty velcro included for the PC, power distributor, and ground pad was worthless as the devices kept moving. I remounted them (PC to the frame top) with industrial velcro. The seat's vertical supports were piercing the stock fuse side outer wires/relays, so I pulled the buddle snug with double sided velcro wrap to provide clearance. I left guide wires under the tank and beam to make it quick to route new wires.
dream is offline
post #28 of 33 Old 11-09-2006, 02:53 PM
Tired of Tirone
jeffspeak's Avatar
Riding, no forget that - Living in that kind of temperature range is crazy. I get a chill when it drops into the 70's. I'd invite you all to move down here to Florida but we really are out of room. Now if you want to talk about riding in hurricane conditions or rain so heavy you can't see, I'm the one to talk to.
jeffspeak is offline
post #29 of 33 Old 11-09-2006, 06:23 PM
Ranger,
Here is a picture of the power distribution panel and ground disk on the left side, and the power relays, DC converter on the right. Still have slots for heat and the TBD blue tooth com mixer.
dream is offline
post #30 of 33 Old 11-10-2006, 01:13 PM
Ranger,
Thanks for the photo. That gives me some ideas to move some stuff around.
WIth the PC3 sitting on the frame, how do you keep the seat from squishing it? How mush space is there between the top of the frame and the bottom of the seat?
Thanks.
Ranger919er
post #31 of 33 Old 11-10-2006, 02:02 PM
Hi Ranger,
Mounting the PC perpendicular to the frame: there is plenty of vertical/side-side clearance, but forward and aft requires careful measuring and positioning with ~1/2" margin. To maximize margin I trimmed the seat's plastic tabs (manual fingers), and leveled it by partially trimming 1/4" off the left side tool rail. Be careful not to let the PC's wire loom get compressed by the forward seat pad. I will tie it down. There are seat support prongs up front that need to clear the left side ground pad and right side relays/wires.
Now it's easy to safely add gizmos!
dream is offline
post #32 of 33 Old 11-10-2006, 02:35 PM
Hi Ranger,
Ahem, I measure again. The forward aft perpendicular PC has 1.5" margin to the seat grooves for placement. This is good since the seat needs to slide forward under the side rails. The vertical height margin given the seat's forward rubber bumper squeezed under load is tightest at ~<1/4". So no room to stack your autocom on the PC.
dream is offline
post #33 of 33 Old 11-12-2006, 05:11 AM
"whats so great about YOUR room ? huh.. I think my room is better."
My room is great 'cause it is adorned by my 919! As an aside, we be looking to move to Eastern Tennessee (Deal's Gap area, yeah, buddy!) because the weather in Cleveland is pathetic. Global warming, my a**.
Okay, how do you post pics? I'll post images of my bike, and how I mounted my PC.
I want more HP.........
