Electrical/Lighting Question - Wrist Twisters
post #1 of 8 Old 09-24-2008, 05:16 AM Thread Starter
STPDSQD's Avatar
It was pointed out to me this morning that none of my rear running lights are working. I checked the brake and blinkers and they are fine. The front running lights are also fine. I look at the fuse and they are fine. all lights appear to be on the same circuit. I have a 2002 919, are the rear running lights (including the tail light) wired in series so that if one goes out they all go out? This seems like a bad idea but I guess you cut cost where you can.
I figured that since the blinkers and break lights work the harnesses must be secure. Anything else I should check?
Thanks,
Jason
I got no time for the jibba-jabba. - Mr. T
STPDSQD is offline
post #2 of 8 Old 09-24-2008, 07:35 AM
1. Have you done any modifications to the stock lighting?
2. Have you tried replacing the dual filament bulbs? It might be something that simple.
3. It can't be a grounding issue otherwise the brake lights would not work.
4. The 3 pin connector in the tail section supplies 12volts and ground to the rear brake/tail lights. The harness side of this connector has a White/Gray wire, the mating plug has a Brown wire. Test both of these wires for 12volts.
Report back...
post #3 of 8 Old 09-24-2008, 08:03 AM
My rear turn signals do not function as running lights and didn't think they were supposed to. Are they supposed to be running lights too?
post #4 of 8 Old 09-24-2008, 08:06 AM
Rear turn signals are single filament, no running lights.
post #5 of 8 Old 09-24-2008, 08:08 AM
hawkeze's Avatar
The rear brake light/running light are dual filament bulbs if one of your bulbs has a filament out that operates your running light the other will still work. I just had one of mine go out recently. It could be that both bulbs are bad, always check the simplest and cheapest fix first.
hawkeze is offline
post #6 of 8 Old 09-24-2008, 08:54 AM Thread Starter
STPDSQD's Avatar
Good call. I assumed that since the front signals were running lights that the rear ones would be too. I guess I never noticed before. It's probably one of the filiments in the taillight then, I'll grab one on the way home. Anyone have the part number/size off hand? Should be something I can get at AutoZone right? Worst case there is a Honda dealer on the way home as well.
STPDSQD is offline
post #7 of 8 Old 09-26-2008, 09:06 AM Thread Starter
STPDSQD's Avatar
It was a bad bulb. There are two, if one goes the both go. $6 for both.
STPDSQD is offline
post #8 of 8 Old 09-27-2008, 07:26 PM
Veteran Donation
Not really, just bad timing.I've replaced 2 sets.each time one went out the other still worked.Now beings the bulbs come in packs of two I replaced both,and toss the other in the spare parts bin.
Which means I'll never find it when I need them,so I'll replace two the next time also.
tvetree is offline
