easy clean behind rad or remove header tip - Wrist Twisters
post #1 of 1 Old 07-04-2007, 07:10 PM Thread Starter
drivit's Avatar
-raise gas tank, slide the rad cap neck off its holding screw and let it hang
-remove bolt at top centre of rad, under steering stem
-remove nut and bolt at bottom of rad, clutch side
-pull rad slightly sideways, off it's locating dowel on opposite side
-go nuts but don't hit the tank with the bars while its raised
drivit is offline
