easy clean behind rad or access pipe clamps #2 - Wrist Twisters
post #1 of 3 Old 02-02-2010, 06:23 PM Thread Starter
drivit's Avatar
-raise and support gas tank
-slide rad cap neck off it's mounting screw, let hang
-lower tank back down to avoid hitting it with handlebars
-remove bolt at top center of rad, under steering stem
-remove nut and bolt at bottom of rad, clutch side
-pull rad slightly sideways off it's locating dowel on opposite side
-use bungies to pull and hold it out of the way
-knock yourself out
drivit is offline
post #2 of 3 Old 02-08-2010, 01:28 PM
jabberjoe87's Avatar
is that a single underseat can on your 9er?
jabberjoe87 is offline
post #3 of 3 Old 02-09-2010, 09:27 AM Thread Starter
drivit's Avatar
yes it's all on here somewhere
drivit is offline
