Dyno Run - Wrist Twisters
post #1 of 3 Old 08-29-2007, 05:00 PM Thread Starter
rider
Dyno Run
Rode the 9er to work today so I could have them put it on the dyno. the bike is bone stock but I wanted to get the numbers before I made any changes. Turns out the stock set-up is making max 96hp and 60.27 torques numbers. The interesting thing is that from about 2000 rpms the bike is running lean (14 to 1 air/fuel) and gradually richens as it approaches 4200 rpms and continues to richen to about 12 to 1 through the remainder of the run up to redline.
Just wondering if anyone else has seen similar results. The dyno guy says he has seen the same type of results on other bikes. It occurred to me that this could be the cause of the often mentioned exhaust stink that so many of us have complained about.
s10hornet is offline
post #2 of 3 Old 08-29-2007, 08:34 PM
Newfie
karlb63's Avatar
The 919 stock runs RICH. That with the positioning of the pipes under the seat are probably the biggest factors to the "stink" you are experiencing. As for the dyno results it only goes to show that every dyno out there is different. I ran mine and had 118hp and 74ft/lb torque. With the flapper mod, bafflectomy and a pcIII installed. Get yerself a pcIII and try a couple of maps. I currently use the simpson map but had found the sato map to also be very good. Also less stink.... unless I can't smell it anymore!
Good Luck!
karlb63 is offline
post #3 of 3 Old 08-29-2007, 09:32 PM
royalchoppers's Avatar
If the PAIR system wasn't disconnected, then you will have false Air/Fuel readings.
royalchoppers is offline
