Dyno Run - Wrist Twisters
post #1 of 9 Old 09-12-2009, 07:25 AM Thread Starter
rider
Dyno Run
So one of my customers owns a 919 and brought it to the shop this morning for a dyno run. He fabricated his exhaust by cutting and rewelding the single portion of the head pipe that runs to the y-pipe. turned it out and cut a scorpion can in half. Just to make everything clear he is running a 15 tooth front sprocket and premium fuel. No power commander.
His dyno numbers came out to 99.08 hp - 61.79 lbs torque and afr of 13. The afr and torque curve was flat all the way across the chart.
I thought that was pretty good numbers for a cheap exhaust mod.
s10hornet is offline
post #2 of 9 Old 09-12-2009, 09:56 AM
I killed Barton664
Basspiece919's Avatar
that looks like a power loss to me...
Basspiece919 is offline
post #3 of 9 Old 09-12-2009, 10:04 AM Thread Starter
rider
in stock trim the bike is 96 rwhp and 60.7 torque.
post #4 of 9 Old 09-12-2009, 10:17 AM
Unless that is a profoundly low reading dyno, I agree. Also, I don't remember seeing 96 rwhp as the stock number.
sike is offline
post #5 of 9 Old 09-12-2009, 11:16 AM
UJM
Banned
Just under a hundred seems to be where the stock ones fall.
Mine, basically stock, pulled 107 in the day with a few mods, but the differences in dyno's, weather, what "horsepower" (SAE, Standard, etc) you are using, a lot of variables.....
UJM is offline
post #6 of 9 Old 09-17-2009, 06:38 AM Thread Starter
rider
The stock numbers I supplied are from a dyno run on my bike a while back. It is completely stock. According to Honda the hp at the crank is 107. Taking into consideration an approximate 10% loss in hp from the crank to the rear wheel then 96 rwhp would be about right.
I'm no engineer but I'd say a 3 hp gain at the rear wheel is pretty good for a simple exhaust mod.
Maybe Lord Duckhunter is lurking around somewhere and can weigh in on this matter.
post #7 of 9 Old 09-17-2009, 07:01 AM
Another Dyno Thread? Let the Scrapping begin!
Ripper is offline
post #8 of 9 Old 09-17-2009, 07:29 AM
Wanna hear about my knee instead?
post #9 of 9 Old 09-17-2009, 08:14 AM
The numbers themselves mean nothing without the chart.
I've seen Two Mothers full systems put a decent peak number on the 919, but actually hurt the mid-range performance. It's all about the power curves on the graph...
