Dropped - Oil in Exhaust - Wrist Twisters
post #1 of 14 Old 09-26-2008, 04:16 PM Thread Starter
My bike fell over in the garage while I was out. It sat on it's side for a couple of hours. The tank is dented and the turn signal is twisted but nothing major - my pride, not withstanding. I'm still not sure what happened, jack slipped, dogs bumped, etc.
But, I stood it back up and let it sit for an hour. I fired it up and the exhaust was very smokey. I let it run for maybe one minute to try and clear it, but it didn't work. I shut it off. I checked the oil level and it looks the same as before.
Question: Is it a problem to have oil sitting in all the wrong places? Is there a procedure for checking? or, do I just need to run it some more?
Thanks for your assistance.
Cheers,
Paul
dasheight-8 is offline
post #2 of 14 Old 09-26-2008, 04:27 PM
Sorry to hear of the tip-over. There is excess oil in the top end which needs to be cleared out. Take the bike for a nice ride.
post #3 of 14 Old 09-26-2008, 07:00 PM
procedure for checking oil depends on the bike
post #4 of 14 Old 09-26-2008, 07:12 PM
Hippie Tinkerer
mntnceguy's Avatar
Run / Ride it till most or all of the smoking is gone, then take your spark plugs out and clean or replace them so they don't become oil fouled
Build List in Spoiler
SOLD SOLD SOLD
When Sold:
599 Headlight
Koso Gauges DB-02r
GiPro gear indicator
Givi Crash bars
Seargent seat w/ gel insert
Dyna Beads for tire balancing
Piaa horns 400 & 500 hertz
Tech-Spec custom tank Pads
Napoleon bar end mirrors
SW-Motech center stand
Shorai Battery
Hydraulic rear brake switch
Powdercoated: 22+ parts
etc, etc,
mntnceguy is offline
post #5 of 14 Old 09-26-2008, 07:24 PM
Go'n So slow I'm stopped
xrmikey's Avatar
Um.... yea. That stuff ^^^^^^^^^^^
xrmikey is offline
post #6 of 14 Old 09-26-2008, 07:27 PM
Most likely some oil leaked into the cylinder on the end of the engine closest to the ground. It takes a surprisingly small amount of oil to make a lot of smoke for quite a while. You might look at the clear tube at the bottom of the airfilter housing to check for any oil there. Then ride it, should stop smoking within a few miles, no harm done.
robert4 is offline
post #7 of 14 Old 09-26-2008, 08:18 PM
look on the bright side .... the inside of your exhaust won't rust anytime soon.....
post #8 of 14 Old 09-26-2008, 10:19 PM Thread Starter
Okay. Sounds like good advice. I'll give it a try tomorrow morning.
thanks
post #9 of 14 Old 09-27-2008, 02:23 AM
nice spoiler Barton, sweet
post #10 of 14 Old 09-27-2008, 07:21 AM
thank you those are my girls... mary is from rose bud.. right up the road from you
post #11 of 14 Old 09-27-2008, 07:47 AM
yea! you got it!
I still laugh every time I think of that pm you sent. I wanted to help but every time I typed the HTML code for the spoiler and sent it to you it made a spoiler and you couldn't see the code... It hard to show someone how to do it without actually making the code work.
See... Even that ^^^^ don't make sense!
Ripper is offline
post #12 of 14 Old 09-27-2008, 05:39 PM
STPDSQD's Avatar
Yep, what they said. The same thing happens if you turn your lawn mower upside down and then turn it back over and start it. Lots of smoke but no real damage.
I got no time for the jibba-jabba. - Mr. T
STPDSQD is offline
post #13 of 14 Old 09-28-2008, 05:20 PM Thread Starter
Thanks for the advice.
I rode about 100 miles today. The bike worked fine.
Thanks again.
post #14 of 14 Old 09-29-2008, 08:45 AM
PHOBMAN's Avatar
Sounds like you need a decent stand?
PHOBMAN is offline
