drewvirbrators<$10 - Wrist Twisters
post #1 of 20 Old 08-23-2010, 06:58 AM Thread Starter
blur
drewvir's Avatar
drewvirbrators<$10
i recently installed my new Tharbars(kudos rob excellent work) and had been thinking about the vibranators but $70???
so i made my own.
go to hardware store for the parts you'll need.
--2 1/4-20x4" or 6mm x 100mm flat head allen or whatever you think will look best
--13/64" drill bit
--1/4-20 or 6mm x 1.5 tap
--2 5/16 washers
--2 1/4" flat washers
--2 l/washers for 1/4 or 6mm
--4" piece fuel line to fit inside the bar(i used 3/8" but it was a little small so i put a small piece of 2 way tape stretched tight which helps to keep it from spinning, more on that later)
now ref. the attached image.
-remove your bar ends and the inserts(how to in helpful topics)
you will need #7 and #8 set the rest aside
take #7 and drill the hole about 1" deeper then tap
assemble in this order
bar end with screw,1" piece of fuel line,5/16 flat washer,lockwasher,part #7.
insert in bar and tighten(a cordless drill helps here)
what you end up with is pic#2
the end of the internal weight doesnt touch the id of the bar so it does the same as the vibranator
this works way better than i hoped it would and knocks out 99% of the vibs that i had in all the bars i've tried
drewvir is offline
post #2 of 20 Old 08-23-2010, 09:09 AM Thread Starter
blur
drewvir's Avatar
the 2 way tape helps the fuelline from spinning while you tighten the screw.
note to above the fuel line should be cut accordingly so the bolt will tighten up with out bottoming in the weight.
i recommend ya give it a try before spending big $$$
drewvir is offline
post #3 of 20 Old 08-24-2010, 08:18 AM
I recommend you amend your post so as not to be sued. That name is probably at least trade-marked, and that item might be patented. Just saying....
Blackheart is offline
post #4 of 20 Old 08-24-2010, 08:32 AM
Gets censored
Aint nobody getting sued over a WT post.
Good job there man, I may have to give this a go. Any pics of the tharbars on? Im feeling a bar change coming.
brian is offline
post #5 of 20 Old 08-24-2010, 01:17 PM Thread Starter
blur
drewvir's Avatar
could'nt edit even if i wanted to. and i didn't use anything that didn't come on my bike except 2 screws,a couple of washers and fuel line from my lawn mower
patent pending
they stole the tech from 'copters.
name may be copyrighted if so apologies
drewvir is offline
post #6 of 20 Old 08-25-2010, 03:33 PM
Gets censored
brian is offline
post #7 of 20 Old 08-25-2010, 05:18 PM Thread Starter
blur
drewvir's Avatar
sorry brian,
i missed that part of your post
i powder coated the cross bar "chrome smoke" and polished the handle portions. they are great bars with nearly unlimited adjustments.
it will take you a good bit longer to swap than conventional bars because of all the possabilities available to you but i love them, they're perfect for me and with the "drewvirbrators"(haha) there's almost no vibes. there's a mild vibe in 6th at 2700-2800 rpm but it's nowhere near before. i use to be able to do "the stranger" after 30-45 mins. now i need to find some strange.
drewvir is offline
post #8 of 20 Old 09-01-2010, 05:28 AM
them bars are fucking sweet man, Rob, mighty fine job my man, fine job
post #9 of 20 Old 09-01-2010, 06:12 AM
Total Awards: 17
excellent job dude.
I noticed you could use a break fluid change. Pic 5 shows it to be pretty brownish / dark when dot 4 is almost clear like water
zaq123 is offline
post #10 of 20 Old 09-01-2010, 03:17 PM Thread Starter
blur
drewvir's Avatar
grassie-ass it's on the to-do list.it's not as bad as it looks the pics were taken way past dusk with a big flash, but thanks
drewvir is offline
post #11 of 20 Old 09-01-2010, 03:32 PM
Gets censored
I LOVE the idea and functionality behind the tharbars but something just looks wrong about them. Maybe its the whole get used to a new idea thing.
brian is offline
post #12 of 20 Old 09-01-2010, 05:01 PM Thread Starter
blur
drewvir's Avatar
they're very industrial/street fighter. once you see that you can make them the coolest,most comfortable bars YOU want,you'll love them too
drewvir is offline
post #13 of 20 Old 09-01-2010, 05:12 PM
Gets censored
Definitly can see the appeal
brian is offline
post #14 of 20 Old 01-12-2011, 11:58 PM
schrock86's Avatar
Awesome write-up I was just about to buy vibranators, but then found this thread. I will give this a try seems like it will do the trick just fine. I nominate this to be added to the helpful topics.
schrock86 is offline
post #15 of 20 Old 01-13-2011, 06:51 AM Thread Starter
blur
drewvir's Avatar
thank, i hope you like them
drewvir is offline
post #16 of 20 Old 01-13-2011, 08:08 AM
patent pending
I like the frugal approach as well as the ingenuity.
I have a suggestion for you, hoping it will help you with the TradeMarking potential.
Your word "vibranators" is suggestive of causing or creating vibration.
Your design does the opposite.
How about VibraNOators instead ? (or VibeNOators)
A bit of a play on words as you can see.
And I want nary a cent from whatever accrues for you !
post #17 of 20 Old 01-13-2011, 08:28 AM Thread Starter
blur
drewvir's Avatar
thanks but "vibranators" isn't my word. that one's taken. i was not gonna pay $70 bucks for a set.
drewvir is offline
post #18 of 20 Old 01-13-2011, 11:55 AM
VibeNOators is yours to keep if you want it.
Or anyone else that wants it.
Rob ????
post #19 of 20 Old 01-13-2011, 12:34 PM
Rob ????
You realize you wouldn't be popular with the ladies anymore, right?
post #20 of 20 Old 01-13-2011, 03:53 PM
When the VibNOator is put into the end of the handlebar, riding is a much more pleasureable experience.
Why would anyone take exception to that ?
And it's not as though seat buzz comes from a bar vibe.
What, pray tell, am I missing re your post ?
