De-restriction in Hornet 919 - Wrist Twisters
post #1 of 42 Old 09-19-2007, 06:18 PM Thread Starter
I have a Hornet 919 date 2002 for Asia market-where the law limit speed under 180 km/h.
While the one for European can go maximum 260km/h (see pictures).
Anybody have ideas how to derestrict the limitter in my bike.
Thanks so much for your helping
NewSol is offline
post #2 of 42 Old 09-19-2007, 06:20 PM
I have no idea. I would imagine it's an ECM thing.
I did notice the top pic has green turn signal flashers.
post #3 of 42 Old 09-19-2007, 06:21 PM Thread Starter
I found a website show how to derestricted rev limitter in Honda RC51.Can we use for Hornet 919.Anybody have other ideas?Thanks again
Link http://www.rc51.org/b2a15.htm
From this website
This is the simple kit I put together & distribute
Remove your tail section & undo the T shaped cover attached (4 push pins) on the bottom of the tail section right behind the battery. Under that there will be a black ECU box with a gray connector & a black connector.
This mod is best done with the PCII, as you can do the mod by splicing into the PCII harness instead of the ECU harness & if you ever need to undo the mod you can make it look 100% stock
You can obtain your own connectors from a cd-audio cable (pictured below) as it has the perfect size connectors to match the ECU pins.
NewSol is offline
post #4 of 42 Old 09-19-2007, 06:24 PM Thread Starter
Another solution that I'm thinking to use the speedohealer to convert from km to miles.When I go at 100 m/h the signal send to ECM only 100km/h it mean I can go maxinum 180 m/h -> 180x1.6 = 288 km/h
SpeedoHealer - Electronic Speedometer and Odometer calibrator for motorcycles
I write an email to the techinal engineer of speedohealer for asking
And this is his answer
Hello,
Yes, if you enable the SH''s "kph to mph" conversion mode, e.g. 140 indicated
on your meter will mean 140 mph road speed.
Probably it will also by-pass the speed limiter.
However, we do not have information on whether there is another kind of
restiction (e.g. HP) on this bike for the Asian market.
Kind Regards,
/Norbert
HealTech Electronics
Anybody have experience with this problems.Please help me
Thanks a lot
NewSol is offline
post #5 of 42 Old 09-19-2007, 06:26 PM Thread Starter
The RC51 wiring diagrams show the black/white wire (B2) from ECU to Fuel injection and Fuel pump show I think the ECU will cut power fuel pump when up to 186 kmh.In that solution they connect B2 with A15 may be to supply power for fuel pump when over 186kmh.That all my guess.
The CBR600 wiring diagrams has same with black/white wire from ECU to fuel injection.All the problems we don't know which port can supply power for it when up to 186kmh
Anybody have ideas?
NewSol is offline
post #6 of 42 Old 09-20-2007, 01:51 PM
drivit's Avatar
the "soft rev limit" affects the ignition not the fuel injection, by intermitent retard, also on all 919/hornets. regarding "speed" the sender in the transmission is the only possible signal, so i think the speedo healer would be your solution.
drivit is offline
post #7 of 42 Old 09-20-2007, 08:13 PM
Trackday Recognition Donation
Last time you brought this up, you mentioned you were going to try an ecu from another country. Did you ever try it?
gpzTurbo is offline
post #8 of 42 Old 09-20-2007, 08:45 PM Thread Starter
Not yet try with another country ECU because I'm in Vietnam-it not many 9er and very difficult to buy spare part for big cc bike like 919.
If I have other ECU i think it still can not work on my bike because HISS key.We need to change HISS key also.It take a lot of money.
I ask one guy in other website,he is in Japan and has the same problem like me.And this is his answers
"Hi, I'm in Japan and have similar questions. I am sure the dealer can help out as they do this mod for other Japanese/asian models to open there full potential .
My hornet has a CB900F on the rear fender which from what I have read means it was reimported from Canada (as they don't sell the CB900F and CB600F in Japan), which would mean it shouldn't be restricted , but the speedo only goes up to 180kmh so I am not sure. I have noticed that 4500 revs in 6th gear is about 140kmh. So if I do the math it should go pretty quick if your red lining. So will need to check this out and get back to you ...."
"Hi NewSol
I talked to the dealer and he will do it for me. As it is illegal to do in Japan he cant give too much detail. but it does require changing the Airbox and mufflres and a wire splice on the ECM loom. I guess when it is done I will get the parts list and can then tell you what I had to purchase. And then get some shots of the splice etc and just reverse engineer the thing? The chain etc are all ok and dont need replacing.
Unfortunately I will wait until after the Japanese MOT (Shaken) before I mod the bike as it is impossible to reregister mod'ed bikes. This will happen in November and then I will do the mod and have 2 years before it needs MOT again. sorry you probably need it now .....
It is expensive mufflers / airbox (but I was getting mufflers anyway. I guess it is about $300 dollars for the parts excluding the muffler."
Link http://www.fireblades.org/forums/hon...net-919-a.html
I know in limited speed bike has something inside exhaust pipe and intake port,we only need to remove this.But the modification in ECM wire is so difficult.His answer make me believie only need change some wire in loom for derestriction bike.
Could anybody post some pics of ECM plug (gray,black connetor) for me?I can compare with my bike and maybe find something different.
Thanks so much
NewSol is offline
post #9 of 42 Old 09-20-2007, 09:24 PM
farmerjoe's Avatar
On a side note, where exactly in Vietnam would you want to do 260Kph?
farmerjoe is offline
post #10 of 42 Old 09-21-2007, 12:22 AM Thread Starter
Sometimes we have drag.And what a f**k if can not vs with Hor600 full power.
In my opinion why we only have max 180 while the bike can go faster than.
You know what I mean.
NewSol is offline
post #11 of 42 Old 09-21-2007, 12:33 AM Thread Starter
Some pics before we have a drag.In highway beside the beach without anybody or vehicles
And me with my Hor900 silver
In this pics the guy with CBR 1000 restricted speed can not beat YZF 600 full power.Because CBR 1000 limited under 180kph and YZF 600 full power can go up 220 kmh.
That 's not fair
NewSol is offline
post #12 of 42 Old 09-21-2007, 02:59 AM
Church of the Holy Smoke
MotoCycho's Avatar
That 's not fair
Based on what I see in this picture these cowboys shouldn't be going faster than maybe 40kph.. He he he!
The Flip flops seal the deal for me!
- Rev. CYCHO -
MotoCycho is offline
post #13 of 42 Old 09-21-2007, 03:24 AM
MotoCycho's Avatar
...That 's not fair
_______ _________
Man.. tell me about it. My my stupid ZX-14 won't go any faster than an indicated 186MPH and the speedo goes all the way to 190. WTF is up with that?
- Rev. CYCHO -
post #14 of 42 Old 09-21-2007, 03:26 AM
3dcycle's Avatar
flip flops= better feel for the sourondings
3dcycle is offline
post #15 of 42 Old 09-21-2007, 07:47 AM
I'm guessing there isn't a helmet law? Or you all are a bunch of rebels.
post #16 of 42 Old 09-21-2007, 07:52 AM
async's Avatar
Vietnam, cool! I like Pho and Bun Tom Thit Nuong Cha Gio but can't find any around here
async is offline
post #17 of 42 Old 09-21-2007, 09:06 AM
MotoCycho's Avatar
Originally Posted by async View Post
Don't taze me bro!
Instant hit!
- Rev. CYCHO -
post #18 of 42 Old 09-21-2007, 07:13 PM Thread Starter
@ MotoCycho: I take pics after they finish the test.
@sugs : In Vietnam some street has helmet law and other not.But I think put on your helmet before ride always are the best thing.
@async : you really know a lot of Vietnamese food! I guess you was there more than 1 time.I live in Sai Gon.Contact me if you come to Vietnam.
@ anybody help me with some pics of the connector to ECM(gray and black connector under your tail) Please !!! thanks so much
I wrote some topic for de restriction and techical tips in this website.
http://www9.ttvnol.com/forum/garage/954018/trang-7.ttvn
You can have a look.But in Vietnamese.
NewSol is offline
post #19 of 42 Old 09-21-2007, 11:28 PM
drivit's Avatar
i'm guessing it's the 1 from the speed sensor. where do you get wiring diagrams from?
drivit is offline
post #20 of 42 Old 09-22-2007, 03:14 AM Thread Starter
The wiring diagrams i take from from service manual
This is wiring diagrams of Hornet 919 '02
Link for high resolution
http://s24.photobucket.com/albums/c1...919_wiring.jpg
NewSol is offline
post #21 of 42 Old 09-24-2007, 02:12 AM Thread Starter
Could anybody post some pics of your ECM connector (gray & black) for me!
Maybe I 'll find some wire different with mine.Help me please
NewSol is offline
post #22 of 42 Old 09-24-2007, 04:15 AM
for all the hassle if another 40km/h is worth it, you can also try your luck looking for a derestrictor device from Japan. if i'm not mistaken, your bike is a Japanese model. i find it so hard to ride the bike at 180km/h and above.
smokin is offline
post #23 of 42 Old 09-25-2007, 03:38 AM Thread Starter
I found a website show how they de restrict Honda CB1300.I think the solution for Hor 919 same
http://hondacb1300.net/yabb/YaBB.pl?num=1185829932
De restrict air intake
Doing some mod wire at ECM connector
NewSol is offline
post #24 of 42 Old 09-27-2007, 06:22 PM Thread Starter
Could anybody post some pics of ECM connector for me?Help me,please
NewSol is offline
post #25 of 42 Old 11-09-2007, 01:03 AM Thread Starter
I had de-restricted my Hornet 919 by myself already.The bike after derestricted very perfect you can feel clearly the increase power.
You can have a look in this website.Sorry it in Vietnamese but i think you can understand with the pictures
http://www9.ttvnol.com/forum/garage/.../trang-10.ttvn
And there are some thread written by me show how to de-restricted CBR 1000RR,Hornet 600,CB1300,VFR800,CBR954...
Thanks all.
NewSol is offline
post #26 of 42 Old 11-09-2007, 10:55 AM
Heavy Metal
ratdog's Avatar
link doesn't work... .ttvn file doesn't load
did you mod the ECU by cutting the grey wire?
thx
-rd
ratdog is offline
post #27 of 42 Old 11-11-2007, 04:48 AM Thread Starter
NewSol is offline
post #28 of 42 Old 11-11-2007, 07:04 AM
Hi NewSol,looked at your tech info and am wondering just hoe restricted my bike is.How did you get to the inlet restriction,ie.,WHAT did you remove and HOW?
thanks,
Timo.
sahornet is offline
post #29 of 42 Old 11-11-2007, 07:35 AM
"Whose ABBA ZABBA?"
Wow, pictures are worth a thousand words. Very well done. Incredible the effort to restrict the 1000RR! I cannot imagine buying a litre bike and having it's power chopped in half. I have a ZX10R and it is restricted to 186MPH(300KPH) but I'd never know it. Good work, NewSol.(and tell your friends to wear protective clothing!!!!!!!!!!!!!)
General George S. Patton
post #30 of 42 Old 11-12-2007, 07:26 PM Thread Starter
In this thread show how to de-restrict 186mph in ZXR12R may be it work on your bike ZX10R but I'm not sure
http://www9.ttvnol.com/forum/garage/954018/trang-8.ttvn
In this thread show how to de-restrict Hornet 600cc.
http://www9.ttvnol.com/forum/garage/954018/trang-9.ttvn
@sahornet : the plastic plate only stick to air box by glue.Very easy to take it out by a knife.
Good luck
NewSol is offline
post #31 of 42 Old 11-13-2007, 07:57 AM
BrokeRecord
Man, I didn't realize they put that much junk in the intake system. That oughtta breathe about as good as a fat boy choking on fishbones, like I did one time!!!
brokerecord is offline
post #32 of 42 Old 11-13-2007, 08:04 AM
"Whose ABBA ZABBA?"
Hmm, voltage rises above 3.88VDC on the tach line, this turns on Q1 which must inhibit FI or Ignition. Change the 22K to 2.2K and bitch never gets to 3.88VDC.
post #33 of 42 Old 11-13-2007, 08:39 AM
Duuuuuuurp.....
OSIRIS's Avatar
Don't mean to side track here, but I topped my 9er out at 150 but the speedo goes to, what like 180, I can't remember... I looked at the gear ratio spreed sheet on LDH site and mine pretty much matches that. Is there a restrictor on the American version as well. I don't see how there could be because going 150 I was sitting at about 9K RPM.
2004 Honda Shadow Aero - Black & Silver (Sold)
2002 Honda 919 - Pearl White (Sold)
2007.5 Aprilia Tuono 1000R - Black & Silver
Apparently I need to hit a few more states
OSIRIS is offline
post #34 of 42 Old 11-13-2007, 09:12 PM
dude your bike is way restricted, Ben's will easily do 170
motorwerks919 is offline
post #35 of 42 Old 11-14-2007, 06:17 AM
Sorry NewSol,my hornet is 900.After deristriction does it require a PCIII.
Thanks,
Timo.
sahornet is offline
post #36 of 42 Old 11-14-2007, 08:55 PM Thread Starter
No need use PCIII after derestriction.It is conversion from Japanese style to European style.
NewSol is offline
post #37 of 42 Old 11-15-2007, 02:04 PM
bucky's Avatar
really? somebody thinks the speedo numbers have something to do with top speed?
also? really? somebody thinks their zx10 would have been able to go more than 186?
there is a problem with teaching science in america, isn't there?
(and note to self, apparently, manners)
bucky is offline
post #38 of 42 Old 12-06-2007, 02:30 PM
farmerjoe's Avatar
If you're extending the offer to all WTers I may take you up on it.
Much better to get a hold of a 919 than riding on of those Honda scooters.
post #39 of 42 Old 12-06-2007, 03:03 PM
farmerjoe's Avatar
Originally Posted by MotoCycho View Post
_______ _________
My 2006 R6 tach red line is 17500 but the rev limiter is at 14k, what's up with that?
post #40 of 42 Old 12-08-2007, 04:32 AM
Thanks again NewSol.Havent done it yet getting close to Xmas, but, next year it will be done and i'll let youknow how it goes.
sahornet is offline
