Curious problem - Wrist Twisters
post #1 of 11 Old 07-11-2008, 04:50 AM Thread Starter
Newfie
karlb63's Avatar
Curious problem
About 2 months ago my front headlight would not come on while starting my 9'r up. I tried cycling the ignition to no avail. After getting home I removed the headlight and checked the bulb. All was o.k. Voltage was hitting the switch but not the headlight. Whilst examining the switch the light mysteriously came on. The next night it did the same thing. This time however I accidentally hit the horn and the light came back on. WEIRD. Every time since then the headlight does not come on, all I have to do is tap the horn and it comes on.
The only mods I have made electrically is adding the pc3.
Could there be an issue from when I originally wired the pc3 into the harness and the one connection that may have started to corrode?
HELP!!
karlb63 is offline
post #2 of 11 Old 07-11-2008, 05:05 AM
Trackday Recognition Veteran
Check the headlight dimer switch for bad connections or broken solder.
Sokali is offline
post #3 of 11 Old 07-11-2008, 12:17 PM
Go by Radio Shack and buy a can of spray contact cleaner. Pop that baby open and spray it real good. Cycle the switches a few times to work it in real good. Close her up and see if that doesn't help. I've had bike switches get oxidized on me in the past and do some funky things.
StewPA is offline
post #4 of 11 Old 07-11-2008, 12:31 PM
bucky's Avatar
use the search feature in this site. it's been covered, i think. a VERY similar symptom, if not identical
bucky is offline
post #5 of 11 Old 07-11-2008, 06:56 PM
Ride the snake!!
Oliwoodd's Avatar
My headlight has been doing a similar thing for a couple of weeks, Mine comes back on when I play with the starter button.
Oliwoodd is offline
post #6 of 11 Old 07-11-2008, 07:24 PM
OK. Then check the starter switch for broken solder at connections.
Or waste two weeks asking people what they think is wrong.
Sokali is offline
post #7 of 11 Old 07-12-2008, 05:40 AM
he he he Sokali
post #8 of 11 Old 07-12-2008, 06:32 AM Thread Starter
Newfie
karlb63's Avatar
BRILLIANT!
karlb63 is offline
post #9 of 11 Old 07-12-2008, 07:16 AM
Originally Posted by karlb63 View Post
BRILLIANT!
Find the problem?
Sokali is offline
post #10 of 11 Old 07-12-2008, 01:05 PM
bucky's Avatar
the ways of the dick you have learnt well, sokali-san. beaming with pride am i.
bucky is offline
post #11 of 11 Old 07-12-2008, 07:20 PM
But time it will take to become a Jedi Master, like yourself.
Sokali is offline
