coolant hose slinky? what? - Wrist Twisters
post #1 of 60 Old 06-08-2010, 06:35 PM Thread Starter
arctic954's Avatar
yep --- not new to sportbikes. (this is bike #16) But am new to the 919.
Is there ACTUALLY a reason there is a 'slinky' on the left side lower coolant hose? --- or is it simply decorative.
--------You mean to tell me that the slinky actually will dissipate heat from the header away from the coolant hose?
Educate me here...
arctic954 is offline
post #2 of 60 Old 06-08-2010, 07:02 PM
Tirone shoelaces
TexasTraffic's Avatar
My bet is armor.
TexasTraffic is offline
post #3 of 60 Old 06-08-2010, 07:05 PM Thread Starter
arctic954's Avatar
....that is something I did NOT think of.... and would make since --- hence the bike doesn't have a belly pan to protect the hose.....
Any OTHER ideas or TRUE explanations?
post #4 of 60 Old 06-08-2010, 07:10 PM
CG
catonsvilleguy's Avatar
I think it has to be crash protection. Otherwise that hose would be spewing coolant all over the place if it touched pavement. Might even be a DOT requirement.
catonsvilleguy is offline
post #5 of 60 Old 06-08-2010, 07:10 PM
So, you're a human...
adamjayp's Avatar
I thought it was armour too, and maybe to keep the hose from kinking.
adamjayp is offline
post #6 of 60 Old 06-08-2010, 07:26 PM Thread Starter
arctic954's Avatar
he, he..... yep.
Pretty sure my daughter is going to have a new toy......
post #7 of 60 Old 06-08-2010, 07:29 PM
I have seen a few that installed stainless braid, looks cool
post #8 of 60 Old 06-08-2010, 07:48 PM
dr1
dr1
dr1's Avatar
same reason any other vehicle has one, to help keep the hose from collapsing.
dr1 is offline
post #9 of 60 Old 06-08-2010, 07:58 PM
or over expansion maybe?
Lemonhead is offline
post #10 of 60 Old 06-08-2010, 08:09 PM
I always thought it was to protect it from flying debris and in a crash. Nothing would be cooler that running down the road on a hot summer day and having a sharp rock rupture your main coolant hose and spewing 200 degree liquid all over your left leg. Stranded and burned? Sweet!
post #11 of 60 Old 06-08-2010, 08:59 PM
It provides a magnetic effect on the silicates in the coolant...which aligns the molecules as they push through the cylinders. This causes a tumbling effect of the molecules whenever there is a sharp change in the fluid pathway, so that the boundary layers are disturbed, resulting in a higher rate of heat exchange between the metal and the coolant. So, although the internal metal surfaces will be cooler, the coolant reads hotter on the gauge. The original idea actually came from Scotty, when he forgot to remove the coils providing support and protection of a flux capacitor during shipping, and installed it with the coils on.
Blackheart is offline
post #12 of 60 Old 06-08-2010, 09:06 PM Thread Starter
arctic954's Avatar
at first I was confused.... then I saw you were from Nevada. ha, ha.
post #13 of 60 Old 06-08-2010, 09:48 PM
OMFG thats hilarious.
another vote for armor from flying front wheel debris and or a crash.
post #14 of 60 Old 06-08-2010, 09:51 PM
Gets censored
It's to keep your hose from collapsing, dont take it off.
brian is offline
post #15 of 60 Old 06-08-2010, 09:52 PM
Gets censored
lol, opps. ^ what he said.
brian is offline
post #16 of 60 Old 06-09-2010, 12:14 AM
Pob
Keeps the hose in position/shape and gives some protection against scuffing was what a Honda dealer told me.
Pob is offline
post #17 of 60 Old 06-09-2010, 05:01 AM
It's for entertainment value when you crash without a helmet. You can take the slinky off and play with it for the rest of your born days.
post #18 of 60 Old 06-09-2010, 05:22 AM
maybe a bit far fetched, but, an aftermarket radiator by a diesel hotrod facility in pittsburg has dimples in the tubes to slow and tumble the coolant as it passes through.
so.......
post #19 of 60 Old 06-09-2010, 05:34 AM
The spring would have to be on the inside to keep it from collapsing.
It's a pre-formed hose, so it shouldn't kink once installed. The armour/expansion theories sound plausible though.
Professional
post #20 of 60 Old 06-09-2010, 07:04 AM
dr1
dr1
dr1's Avatar
it wouldnt need to be on the inside actually, although it would probably work better. You can buy a similar thing at the auto parts store so you can bend straight hose into the shape you need without it collapsing. A round hose is going to try to oval if you want to pinch it shut.
dr1 is offline
post #21 of 60 Old 06-09-2010, 07:57 AM
Maybe we should contact Mythbusters on this one.
post #22 of 60 Old 06-09-2010, 08:00 AM Thread Starter
arctic954's Avatar
so....being the nimrod that I am.
I took off the slink last night to do a test......rode the bike to work this morning on my 30 mile commute.
I went to pass a semi ---- and the radiator hose split..... throwing coolant over me, my helmet, and my rear tire. The semi got completely juiced and veered into the median. Because of the spray, I couldn't see and while heading for the other center median.....the rear brake wouldn't work from the coolant. Just had to lay her down.....slid several hundred feet and JUST about went off the edge of a bridge.
just kidding. The hose seems to be fine....for now.
post #23 of 60 Old 06-09-2010, 08:49 AM
so.......
It's true that breaking up a boundary layer allows for better heat transfer. It's NOT true that the metal would be cooler while the gauge would read hotter. We use this technology in heating/cooling blood in open heart surgery. This same characteristic (breaking up the bondary layer) increases gas diffusion in artificial lungs.
The key is to break up the layer without significantly increasing resistance, and therefore the pressure required to pump the fluid.
It's also true that Scotty talked about flux capacitors.
post #24 of 60 Old 06-09-2010, 08:59 AM
When the engine is running, the hose has positive pressure inside it. Exploding would be the issue, not collapsing.
Whatever the case, I'm willing to bet the Engineers at Honda had a good reason to put it there.
Professional
post #25 of 60 Old 06-09-2010, 09:15 AM
Blackheart, I've personally seen head temps drop while water temps increased (before re-entering the radiator) on our Midget and Sprint Cars using Red Line water wetter. How would you explain this?
Professional
post #26 of 60 Old 06-09-2010, 09:53 AM
I can attest to the protection from flying debris reason. On my commute to work one day a car kicked up a piece of steel ... something that flew across two lanes of traffic and hit the lower radiator hose on my 919, bounced off and slid across my left leg, cutting completely though the leg of my riding pants but not into my leg. Upon inspection the coil had been cut almost completely through on three loops but the hose wasn't even touched.
That coil of wire my not suit your vision of what your bike should look like, but it definitely has a quite specific function.
As to preventing it from collapsing, the hose will never collapse unless there is a partial vacuum in the system which can only occur if the low pressure relief valve on the radiator cap is stuck or the reserve tank hose is pinched off. Either way it indicates a problem that must be addressed and not a normal operating condition.
post #27 of 60 Old 06-09-2010, 12:03 PM
What you describe is certainly possible due to less vaporization of the coolant liquid occuring on the surface of the metal, so, more efficient heat transfer into the coolant, which allows the metal to potentially be cooler.
The statement I made was that the temperature of the metal wouldn't be cooler while the coolant GAUGE reads higher. The gauge reading would remain constant, as it is mostly affected by the thermostat. Of course, this assumes not-extreme conditions...such as racing, really high ambient temps, idling, hillclimbing, and inadequate or undersized cooling systems.
(Also, the gauge reading on "normal" systems is not where you are talking about measuring temperatures.)
post #28 of 60 Old 06-09-2010, 12:23 PM
BrokeRecord
Has-been, were ya'll running Alky? I've seen them come in boiling with frost on the intake!
My vote, protection and expansion.
brokerecord is offline
post #29 of 60 Old 06-09-2010, 12:37 PM
On the parts microfiche it's listed as "15: PROTR, RADIATOR HOSE
(LOWER),A AC 1470518-001 $32.58"
I would take "PROTR" to be protector.
garyb900 is offline
post #30 of 60 Old 06-09-2010, 01:17 PM
Gets censored
I had a mustang that a buddy of mine and I built I had an issue with the bottom rad hose collapsing. A old school racer instructed me to run a spring thiingy on the hose.... never happened again. Just my experience.
brian is offline
post #31 of 60 Old 06-09-2010, 02:42 PM
CG
Except the "spring thiingy" is supposed to **in** the hose..........
A lot of factory hoses come with such a device in them. This is generally on the lower hose, presumably because the water pumps sucks on that fat black tubular thang
post #32 of 60 Old 06-09-2010, 02:59 PM
Arctic !!! You Forker! You had me going.......
Diesel trucks have a similar binding surrounding the "soft joiners" on the induction system with hose clamps at each end. The boost is enough to expand the circumference enough to cause them to shorten and "blow off" from the hard parts.
I've got experience with that one.
post #33 of 60 Old 06-09-2010, 03:35 PM
bwoso's Avatar
When a hose collapses there is a smaller diameter in one direction, but in the perpendicular direction the diameter increases, so to remove the risk of collapse the slinky thing doesn't need to be on the inside, it just needs to stop either the decrease or increase. With that said, I always thought there was positive pressure in a coolant system, so I am going with protecting the hose.
bwoso is offline
post #34 of 60 Old 06-09-2010, 03:39 PM
Do we know what kind of psi this system gets to in an arizona summer?
post #35 of 60 Old 06-09-2010, 04:15 PM
bucky's Avatar
it's for looks ONLY.
"yeah, even though the rider will lose an appendage from a flying piece of steel, he'll thank and love us at Honda more because he won't have to buy a new $25 radiator hose !" doesn't make sense. radiator hoses aren't exactly frequently pierced by rocks and road debris. there's rubber right behind the front tire, to and from the "heat exchanger" mount for the oil filter with no protection, and it's right in the line of fire.
bucky is offline
post #36 of 60 Old 06-09-2010, 04:23 PM
Hastatus Posterior
Farab's Avatar
I'd say armour.
Farab is offline
post #37 of 60 Old 06-09-2010, 04:29 PM
I hope you bought a Lottory ticket that day Rob, because that could have turned out alot worse. Go knock on some wood.
Thanks Blackheart, your explanation was much easier to understand than the one I got from the guys at Red Line.
Yes, methanol. I've never seen frost, but I've seen alot of condensation on the injectors.
That certainly makes sense!
That would be the negative pressure Rob was talking about. I guess the water pump was more efficient at pumping water than the radiator was at flowing it.
Professional
post #38 of 60 Old 06-09-2010, 04:42 PM
Roughly 14.7 PSIG (101.4 KPa), or whatever the cap is rated at, regardless of the ambient temperature. Above that the foot valve lifts, dumps excess coolant into the header tank, and drops the pressure. When the temperature drops the coolant contracts and can create a low order vacuum in the system, at which time a secondary valve in the cap lifts and allows coolant from the header tank back into the system.
post #39 of 60 Old 06-09-2010, 06:47 PM
16-20psi according to the service manual
post #40 of 60 Old 06-09-2010, 06:49 PM
CG
Except antifreeze is all kinds of slippery AND toxic. The last place you want that stuff is slathered all over your back tire..........
