Coils - Wrist Twisters
post #1 of 8 Old 08-11-2007, 10:19 PM Thread Starter
jclong74's Avatar
Coils
Has any one thought about &/or changed out the coils on the 919? It was a pretty popular when I had my 750. Would there be any benefits to doing it?
2006 919 (Sold)
2011 Cb1000r
jclong74 is offline
post #2 of 8 Old 08-12-2007, 09:51 AM
No benefit whatever. Ten years ago, sure: coils were so weak as to be laughable, especially considering that automotive coils of the same era were the equivalent of God's own lightning, able to jump the minor gap in the distributor and plug gaps in excess of .080". The ignitions in motorcycles have come a long way since then, so unless you are running a heavily modified engine or exotic fuels the stock coils are perfectly adequate.
post #3 of 8 Old 08-12-2007, 05:44 PM Thread Starter
jclong74's Avatar
Thanks
2006 919 (Sold)
2011 Cb1000r
jclong74 is offline
post #4 of 8 Old 08-12-2007, 07:24 PM
drivit's Avatar
i installed the 4 individual coils from a 929.
it was hard to start, ran well momentarily, and stalled.
lots off gas smell from the exhaust. the spark is obviously weak.
i would really like to get this working right.
if anybody knows how or knows someone, that be cool.
drivit is offline
post #5 of 8 Old 08-12-2007, 10:20 PM Thread Starter
jclong74's Avatar
I believe this is because the 919 uses a duel coil system. One is for cylinders 1&4 and the other is for 2&3. I a duel coil system the coil sends spark to both cylinders at the same time. This might be the cause of your problem
2006 919 (Sold)
2011 Cb1000r
jclong74 is offline
post #6 of 8 Old 08-13-2007, 05:24 PM
Unless your control unit is specifically designed for individual coils (as the 929 obviously is) you will either overload the driver transistors in the control unit (coil primary windings connected in parallel), or provide only half the voltage the coils need (primaries in series). If the coils were connected in series the spark will be too weak to keep the fires lit for long and you may foul the plugs, but that will be the end of your problems. If connected in parallel, the ECU coil driver transistors may burn out in short order, and since they are encapsulated within the ECU it will be trashed (worst case scenario). Hopefully the driver circuit is current limited to prevent this, but I'm disinclined to short one of the coil leads on mine to test it.
Ideally, the igniter transistors in the ECU should be connected to external coil driver transistors (one for each coil) which can handle the load, but you will still have a waste spark.
My advice: remount the stock coils, ignoring the fact that they aren't trick, and ride the silly thing!
post #7 of 8 Old 08-13-2007, 06:14 PM
drivit's Avatar
thanks for the helpful details, no damage, i'm riding it.
gonna hunt down a 929 ECU this winter.
try and swap out just the ignition side.
with a hacksaw....................
drivit is offline
post #8 of 8 Old 09-10-2007, 02:34 PM
Trackday Recognition Donation
If you crank up the boost high enough on the gpz, you'll eventually blow out the spark.
We use a pair of Dyna's configured similarly to the stockers (direct swap) but stronger. If you really had the need for more spark that would probably the way to go.
gpzTurbo is offline
