Clear Alternatives How To Video - Wrist Twisters
post #1 of 17 Old 10-20-2006, 06:11 PM Thread Starter
Unbannable
Super Sneaky Steve's Avatar
Part 1
http://www.youtube.com/watch?v=eDqoUO1b6to
Part 2
http://www.youtube.com/watch?v=gI0H9wIvIHY
Part 3
http://www.youtube.com/watch?v=4UTGOVyL8pE
Finished Product
http://www.youtube.com/watch?v=2rrDN5HdXYY
I made this to help noobs so it doesn't pertain to most people here, but I figured it would make a good "How To" in the sticky section.
I used Mike's crimping tip for the ground wires.
Super Sneaky Steve is offline
post #2 of 17 Old 10-20-2006, 06:37 PM
Thumbs up
Dude, good vids, love the public service penchant you've got. Hey, did you ever get the $5 bill I sent ya for your fender kit?
Kahuna is offline
post #3 of 17 Old 10-20-2006, 06:49 PM Thread Starter
Unbannable
Yes I did. Thanks a lot.
post #4 of 17 Old 10-20-2006, 07:52 PM
Hola Como Estas?
ramrod's Avatar
+1, Thanks for your vids man. When I get some extra cash I'd like to do this, for now the Tail Light Convertor Mod is holding me over.
ramrod is offline
post #5 of 17 Old 10-20-2006, 10:29 PM
Church of the Holy Smoke
MotoCycho's Avatar
Fine cinemagraphic work Triple S, but the problem with video instructions vs. simple step by step text with a few good pictures and captions is we are forced to do the project at the speed of the video. I mean it's interesting and all.. well.. not really, but man.. I just couldn't watch more than 30 seconds before I got to bored and want to fast forward. I realize it is intended for people with limited experience... but I like a good tutorial every now and then. Maybe you know a trick I have not thought of or something? Guess I'll never know.. cuz I have tried 3 times to watch your video and I just cant get past the first 30 - 45 seconds. Maybe if you had some hot Betty holding tools or something?
BTW, the "L" shaped thing is called an allen wrench.
PUT MORE HOT CHICKS IN THE VIDEOS OF YOUR FANCY RED MOTORCYCLE!
- Rev. CYCHO -
MotoCycho is offline
post #6 of 17 Old 10-21-2006, 04:15 AM
Ken
Community Admin
Ken's Avatar
Good stuff Steve. That's a lot of time and work to tape this and share it. No doubt it'll come in handy for others. Thanks!
BTW - How do you like the CA light as far as form, fit, finish, and effectiveness? Are the LED's, including the turning signals, bright enough? Do you need to get a plate light?
2009 Honda Goldwing
Ken is offline
post #7 of 17 Old 10-21-2006, 03:23 PM Thread Starter
Unbannable
I like the set up so far. Everything is bright and functional. I'm choosing to run the risk of not running a plate light. If I get pulled over then I'll fab up something.
My only problem was with the relay. It fixed the blink rate perfectly but it starts with a cancelation and not a blink. So the first critical second is lost. I'm going to call CA and see if there isn't a way to fix the problem. So for now I'm running the stock relay with the faster blink rate.
post #8 of 17 Old 10-21-2006, 04:05 PM
Good luck with CA! Remember what I went through with them? If you strike out you can do what I did. Install a Tridon EL-12 elctronic flasher available at auto parts stores for around $15.
post #9 of 17 Old 10-21-2006, 04:48 PM
Don't mean to threadjack here, but I was wondering if anyone else has had some of the LED's go out on there CA integrated tail light? I have only had mine for a month, and the tail light has lost about a quarter of its LED's.
post #10 of 17 Old 02-17-2007, 10:39 PM
Hey whats Mike's crimping tip for the ground wires.
Mike's crimping tip for the ground wires. What is that exactly?
miguellevesque is offline
post #11 of 17 Old 02-18-2007, 09:32 AM Thread Starter
Unbannable
Look at the picture. See the wires that don't go anywhere? Those are the ground ones. I used some pliers and criped the ends after heating them to seal it closed.
post #12 of 17 Old 02-18-2007, 09:41 AM
what does criped means?
Sorry im a french fella, i can see there is some shrink wrap on it. Do you like bend the end of the wire, pinch it and put shrink wrap over it, and then heat it?
post #13 of 17 Old 02-18-2007, 09:53 AM
I had a H-D
west467's Avatar
I think he means "crimped" a mechanical splice. Usually a small connector is used with pliers to connect two wires.
west467 is offline
post #14 of 17 Old 02-18-2007, 12:27 PM
hmmm still dont get it
I really dont understand
post #15 of 17 Old 02-18-2007, 07:14 PM Thread Starter
Unbannable
Hmmm, ok it's a lot more simple than you're making it out to be.
In the picture you can see two wires comming out of each connector. The yellow wire is a postive, the short wire is really green, but it looks black because of the shrink wrap. Instead of leaving the shrink wrap open ended, I used some pliers to crimp the end closed, just like the wrapper on most candy bars.
Get it?
post #16 of 17 Old 02-18-2007, 09:10 PM
Go'n So slow I'm stopped
xrmikey's Avatar
Crimped=To Pinch closed.Squeeze tightly w/pliers or Wire "Crimping" tool.
xrmikey is offline
post #17 of 17 Old 02-18-2007, 11:18 PM
AHhhh
Yep, thanks...was more complicated than i really was thanks
