Cleaning Titanium - Wrist Twisters
post #1 of 20 Old 03-26-2006, 07:29 PM Thread Starter
Question Cleaning Titanium
Hi all,
Any suggestion about what product to use to clean titanium slip-ons?
I have used just simple water and a cloth in the past and even that seems to leave marks on the cans..
Thanks.
flatovercrest
03 919
flatovercrest is offline
post #2 of 20 Old 03-26-2006, 08:22 PM
Two Wheeled Warlord
Danke's Avatar
What are you cleaning off them? Burnt on lube etc. or is it just dust and the normal day's dirt?
Danke is offline
post #3 of 20 Old 03-26-2006, 08:39 PM Thread Starter
Just that, no oil.
flatovercrest
post #4 of 20 Old 03-27-2006, 03:46 AM
Wd-40
post #5 of 20 Old 03-27-2006, 06:58 AM
Two Wheeled Warlord
Danke's Avatar
I used to use lemon Pledge when finishing up polishing Ti. Now when I'm done wiping down the bike with Plexus I give the pipes a quick buff.
Danke is offline
post #6 of 20 Old 03-27-2006, 09:42 AM
Love Machine
awarble's Avatar
Try Honda cleaner/polish!!!
Awarble,
07 Honda CBR600RR
My Site
awarble is offline
post #7 of 20 Old 03-27-2006, 09:34 PM
cyclerider105
Guest
Posts: n/a
I use plexus with a soft cloth on my titanium satos and it makes them look great! Plus, Plexus works great on the rest of the paint and plastic too!
post #8 of 20 Old 03-28-2006, 05:21 PM
get some micro fibre cloths... they won't scratch anything... and use gun cleaner. Go to your local gunsmith and buy some rifle protectant.
clean stainless/titanium polished aluminum... no scratches and a nice protective layer that water will bead on. Gun oil is also heat resistant so it won't burn off in 5 mins.
typhoonblue919 is offline
post #9 of 20 Old 03-30-2006, 09:38 AM Thread Starter
Thanks for the suggestions guys, my 919 is going through some minor cosmetic changes and I'll post some pics in the next few days as soon as UPS delivers the couple remaining parts.
post #10 of 20 Old 03-30-2006, 03:50 PM
919 City Pilot
Pegjumpflyer's Avatar
If its really bad you can use a product called Flitz....great stuff...
also 3M makes a polish called finesseII also great stuff.....both work on paint,plexi/plastic all metals.
Pegjumpflyer is offline
post #11 of 20 Old 04-07-2006, 06:56 AM
zky
I work in a lab where we clean titanium parts regularly. Titanium will absorb and hold oils, and we have to get the oils out of the parts before working with them. We clean the titanium by heating it up a little, then wiping with acetone while warm. We complete this process 3 times. The heat helps drive out the oils, and wiping it down warm will eliminate more of the oils than doing it at room temp.
I don't know for sure, but some of the other products mentioned may actually be putting more oils into the titanium than actually cleaning them. I don't have titanium cans, so I have not tried this process on them. I'm sure the other products mentioned will probably work without issue. Just thought this may be helpful information.
zky is offline
post #12 of 20 Old 04-07-2006, 07:25 AM
can you explain the heating it up part a little? like with a heat gun or a blast furnace? I have a titanium can, a heat gun and acetone and am willing to test it.
post #13 of 20 Old 04-07-2006, 08:46 AM
Two Wheeled Warlord
Danke's Avatar
We used to clean Titanium frames with acetone after polishing, but before decaling and pledging. It would really lift all the oil from your fingers off, the decals were dry release and any contamination meant you had to remove re-buff and so on. No heat cycles though.
The thing about the exhaust is it's allways going to covered in oil, or grime from the roads and so on. Unless you're talking show bike taking it to a semi even level of polish is good with me.
You didn't say what the Ti parts in the lab are for, but I'm guessing it's plumbing, and the oil will be contaminating what's in the tank.
Danke is offline
post #14 of 20 Old 04-07-2006, 10:23 AM
"Whose ABBA ZABBA?"
Jet, just run your bike.
General George S. Patton
post #15 of 20 Old 04-24-2006, 09:23 AM
zky
The Ti parts are aerospace hardware. The heating of the Ti drives the oils out of the part to the surface where they can be wiped off. It is probably not necessary to get a good cleaning for the exhaust, but just wiping it down while running and a little warm may provide a better cleaning.
zky is offline
post #16 of 20 Old 04-24-2006, 09:48 AM
Two Wheeled Warlord
Danke's Avatar
Prior to welding, or before use?
Danke is offline
post #17 of 20 Old 04-25-2006, 03:51 AM
zky
Before use.
zky is offline
post #18 of 20 Old 04-25-2006, 08:37 AM
Two Wheeled Warlord
Danke's Avatar
Are they secret parts?
Are they for this!
Danke is offline
post #19 of 20 Old 04-25-2006, 08:46 AM
Are they for this!
Yep, and this guy flies it.
dadogs is offline
post #20 of 20 Old 04-26-2006, 08:41 AM
zky
That guy looks just like my boss!!
zky is offline
