Camera Mount for Track Day - Wrist Twisters
post #1 of 22 Old 05-21-2015, 06:46 PM Thread Starter
So, apparently I just won a track day for a week from Monday at Road America... So now I'm in full on scramble mode... Any good ideas for a place to mount a camera on the bike? They have a no helmet mounted cameras rule (which is where I have mine mounted now) that I totally understand. The only other place I played with mounting mine was on the headlight and on the bottom half of the tank. The headlight mount buzzed really bad, and I liked the tank mount but the turn signal was right in the middle of the picture. Any ideas?
post #2 of 22 Old 05-21-2015, 07:30 PM
If you have aftermarket fat bars or some kind of anti vibration thing inside the handlebars, the top of the brake reservoir is good. Stock or aftermarket without weights, too shaky.
I'd pull those old videos but I'm on my phone.
post #3 of 22 Old 05-21-2015, 07:40 PM Thread Starter
If you have aftermarket fat bars or some kind of anti vibration thing inside the handlebars, the top of the brake reservoir is good. Stock or aftermarket without weights, too shaky. I'd pull those old videos but I'm on my phone.
I'm just running renthals with cosmetic bar ends...
post #4 of 22 Old 05-21-2015, 07:58 PM
Clamped to your crash bar is a classic option.
post #5 of 22 Old 05-21-2015, 08:15 PM Thread Starter
Crash bar? Like a givi crash bar type thing? Don't have one...
post #6 of 22 Old 05-21-2015, 08:20 PM
I don't think that'll do. Some weighted ends or possibly that $100 internal anti shake insert will do.
Otherwise try the frame sliders?
post #7 of 22 Old 05-21-2015, 08:33 PM
Welp, sucks to be you then.
post #8 of 22 Old 05-21-2015, 08:38 PM
Oh yea, super solid and out of the way (at least a contour hd) which you might be able to get a GoPro without clearance issues. In front of where your knees are on the tank right when it starts to come back in towards the triple area. No shakes there and you can see the front suspension work iirc.
Might check temps next time you're riding to make sure it doesn't get too hot there. If it does you might want to consider a better adhesive (like 3m double sided extreme tape).
post #9 of 22 Old 05-21-2015, 10:08 PM
Riding Naked All The Time
lococnc's Avatar
2004 919 Uranium
lococnc is offline
post #10 of 22 Old 05-22-2015, 05:55 AM
I'm going riding.
scrat's Avatar
On my 9er I put it on the left frame tube right in front of the head. Out of the way, my gopro didn't buzz too badly.
https://www.facebook.com/scrat.gortm...2794539904629/
scrat is offline
post #11 of 22 Old 05-22-2015, 06:14 AM Thread Starter
Thats where I had it originally... and the front turn signal was centered in the picture... otherwise I really liked it there.
post #12 of 22 Old 05-22-2015, 08:09 AM
BockHawk's Avatar
Are you riding with STT, badmoon? Great org to ride with, especially if you've not ridden track before. They're safe, fun, and educational.
2002 919 40,000 miles
BockHawk is offline
post #13 of 22 Old 05-22-2015, 08:34 AM Thread Starter
Yep, they had a giveaway for people who had never done a track day, and I was one of the people that won, so now I'm scrambling to get the bike ready... It worked out nice that I blew out a fork seal last week and have new seals, bushings, springs, and stainless brake lines in the mail...
post #14 of 22 Old 05-22-2015, 09:10 AM
BockHawk's Avatar
Nice! You'll have a blast, I can just about guarantee it. RA isn't my favorite course, not enough corners, but it's a good place to get your feet wet since you get a lot of time to relax between turns. Just remember to breathe and follow the coaches. Welcome to my addiction
BockHawk is offline
post #15 of 22 Old 05-22-2015, 10:39 AM
Cant you use some sort of bicycle mount and mount the GoPro to your handlebars?
edit: Or a super cheap option:
(source: http://www.instructables.com/id/DIY-...asy-and-Cheap/)
Or something not so cheap, but looks BA
post #16 of 22 Old 05-22-2015, 10:51 AM
I use this to hold my GPS. It is rock solid, and pretty well protected if you low side.
Motorcycle Camera GPS Phone Tank Mount for Honda CBR 600RR 1000RR 599 F4i | eBay
jnich77 is offline
post #17 of 22 Old 05-22-2015, 11:58 AM
Oh man, time to chuck those stock turn signals! Or remove them for the track day, it'll give you something to do after setting up your pit.
post #18 of 22 Old 05-22-2015, 12:01 PM
Gonna be tough to tuck in with that on the tank, specially since you'll have to raise the camera a bit to clear the gauges.
post #19 of 22 Old 05-22-2015, 02:39 PM
Depending on how you flip the top bracket, it sits well forward of the gas cap.
jnich77 is offline
post #20 of 22 Old 05-23-2015, 09:51 AM
I once had mine suction cup tank mounted ahead of the filler.
Filler mount is very poor for track day use if you intend to be low down.
I sketched in doing a bar mount instead, offset from centre towards the speedo which I always taped over.
Haven't bought the hardware yet, but intend to do so.
Should be nice and rigid with minimal vibration.
I also used a tail mount with camera facing forward, that worked well for the time your body is well off centre, could even see the tach sweep.
post #21 of 22 Old 05-23-2015, 06:44 PM Thread Starter
So I just dug into the headlight bucket and figured out how easy it was to pop the turn signal off, and then I don't have to worry about taping them, so looks like the underside of the tank is the way to go. Being able to see the suspension work is pretty cool too. Thanks for all the suggestions guys!
post #22 of 22 Old 05-24-2015, 01:37 PM
Nice. Don't forget to share some clips!
