cable separators - Wrist Twisters
post #1 of 6 Old 07-21-2008, 04:01 PM Thread Starter
NAKED & IN LUV
GLENN's Avatar
cable separators
hi guys wat do ya think i found these on the net.
http://ausfr.com.au/cart/shopdisplay...t=NEW+PRODUCTS
GLENN is offline
post #2 of 6 Old 07-21-2008, 05:48 PM
Bazooka Moe's Avatar
Looks like kinda tight, like it might 'grip/squeeze' cables.
Bazooka Moe is offline
post #3 of 6 Old 07-21-2008, 06:52 PM
Throttle cable outer housing is .243", or 6.1 mm, and that for only about 5 inches, then the 8 mm protector takes over, so they wouldn't be of much use there.
The average uncovered dash 3 braided stainless brake line is just over 6 mm as well, but when the covering is taken into account they grow to .285", or 7.25 mm. National Aerospace Standard specifies no metal midline clamp for braided lines without some sort of elastomeric cover to prevent the braid from biting into the inner liner, possibly causing weak points, leakage, or outright rupture, so these clamps should not be used for that application either. xrmikey's clamps do not firmly hold the lines, just provide direction and a small amount of float to allow movement. While they aren't up to NAS standards, they are perfect for this application, especially for the coated lines.
While the clamps advertised may look "trick" to some, they don't really have a use, especially for $17 each.
post #4 of 6 Old 07-21-2008, 06:58 PM
faster4344's Avatar
rob is 100% right but would you expect anything less from him??
faster4344 is offline
post #5 of 6 Old 07-21-2008, 09:40 PM Thread Starter
NAKED & IN LUV
GLENN's Avatar
thanx 4 the info it looks like i will have to wait 4 xrmikeys lathe to start up
GLENN is offline
post #6 of 6 Old 07-23-2008, 09:39 AM
BrokeRecord
Either wait, or run a 7.5mm bit thru them.
Check out Little Machine Shop.com for odd size bits.
brokerecord is offline
