bump start - Wrist Twisters
post #1 of 17 Old 08-02-2008, 07:49 AM Thread Starter
drivit's Avatar
bump start
i let the fan run too long, ran the battery down, haven't tried a bump start in 20 years.
i figured no way but gave it a shot anyway.
it started, maybe no biggy but i was impressed with the bike,
i love this thing.
drivit is offline
post #2 of 17 Old 08-02-2008, 08:44 AM
Yup. As long as the battery has enough oomph to bring up the ECU and prime the fuel rail it should fire right up. One thing I've found helps is to put it in gear and roll it backwards until you feel it come up to compression, then pull in the clutch and give it a good run. In this way the crankshaft has a little more time to rotate before it hits a compression stroke and you have some more momentum built up.
I became an expert on bump starting a 500 single when the kick start gear stripped on my Gold Star, and it couldn't be done without backing up to compression first. Of course with a single the crank makes almost two full revolutions before hitting compression, so has plenty of inertia.
post #3 of 17 Old 08-02-2008, 11:20 AM
hope i never have to do it
post #4 of 17 Old 08-02-2008, 12:07 PM
just curious? how did you let the fan run to long? wasn't the bike running? or was it that you shut the bike off and figured it needed to cool down?
barmatt80 is offline
post #5 of 17 Old 08-04-2008, 11:41 AM
my thoughts too Barmatt
post #6 of 17 Old 08-04-2008, 12:37 PM
Had to bump start Gin's 599 a few times before I replaced the battery, just stick it in 2nd and give it a good run then pop the clutch, fires right up.
post #7 of 17 Old 08-04-2008, 12:55 PM
Das Kalmar
gert260's Avatar
my first bike was a cb 450 that I had to bump start every time.
BOOM CHICKA
gert260 is offline
post #8 of 17 Old 08-04-2008, 05:37 PM
REDROKR hope i never have to do it
+1
post #9 of 17 Old 08-04-2008, 09:14 PM
Franklin McGillacutty
riquefied919's Avatar
Its bad for the brushes in the alt to charge a dead battery using a charger or replacing the batt is the solution. Providing the replacment batt is fully charged
riquefied919 is offline
post #10 of 17 Old 08-05-2008, 02:23 PM
These bikes start surprisingly easy. I had just got my leg out of a cast and could kinda walk but not run. The battery died so I got a few hobbles across the parking lot and popped it in 2nd, fired right up. Had to do it again the next day on the way to work (and leaving work) so I got a new battery on the way home!
post #11 of 17 Old 08-05-2008, 04:46 PM Thread Starter
drivit's Avatar
if the engine gets really hot, the fan continues running on mine for a short while, after i turn it off-i think?
drivit is offline
post #12 of 17 Old 08-05-2008, 04:48 PM
My fan keeps running if I use the kill switch, but with the key off it shuts everything down
post #13 of 17 Old 08-05-2008, 05:01 PM
I killed Barton664
Basspiece919's Avatar
Thats how mine is.
Basspiece919 is offline
post #14 of 17 Old 08-05-2008, 05:14 PM
I just use the key, can't remember the last time i used the kill switch.
hutcho is offline
post #15 of 17 Old 08-07-2008, 06:07 PM
Veteran Donation
I never use the Killswitch,Kinda thought it was safty overkill.
When would it even make sense to use the thing?
tvetree is offline
post #16 of 17 Old 08-07-2008, 07:50 PM
honda recommends leaving the kill switch on and using the key.
I use the kill switch when i have the clutch held in and getting ready park after a ride or such, where the thumb is just an easier way to shut the bike off.
post #17 of 17 Old 08-08-2008, 04:06 AM
I think maybe they taught that in the MSF...to use the kill switch. I have been just using the key more, just a matter of breaking the habit.
