Brakes grinding - Wrist Twisters
post #1 of 13 Old 06-06-2006, 08:03 PM Thread Starter
Brakes grinding
Hey all!
I have an '02 919. Got it w/225 miles on it from a guy who didn't know what to do with it. I've added SATO carbon fibers, PC III, stainless steel brake lines, CRG mirrors and levers and some very sweet Michelin Pilot Powers (which I see are standard on the Speed Triple which I have an eye for).
Anyhow... I ride in the desert mountains of southern California. Lots of twisites and heat. Ever since I changed the brake lines I've noticed a grinding sound from my fron tire. Today I did a complete check of the front end and found that there is no gap at all between the brake pads and the rotors on either side. The rotors and pads are in great shape though. I did completely change and bleed the brake fluid when I changed the lines. I will try to once again relpace the brake fluid and bleed the lines.
If anyone has any suggestions I am open to them.
By the way... my unit only has 5600 miles on it.
Listen to SIRIUS 27 and have a happy 666! :chris:
nakedj is offline
post #2 of 13 Old 06-06-2006, 09:43 PM
Same problem here. '02 919 1800 miles.
pags is offline
post #3 of 13 Old 06-06-2006, 09:58 PM
Church of the Holy Smoke
MotoCycho's Avatar
Originally Posted by nakedj
Hey all!
What exactly is the problem? No gap? There is no gap between a disc and a brake pad.. not one you can see anyway. Perhaps the grinding is debris or the pads are still braking in. Mine made a faint grind for several thousand miles if i recall correctly in the front. Of course verify the pads have lining, but I think you are simply hearing normal mating between the pads and rotors based on what you describe. Get in there with a flashlight and make sure though.
BTW: I have almost 19,000 miles on my '03 and still running the original front pads. The rear I have changed once with EBC organics, which lasted maybe 2000 miles and then I switched to EBC HH (Double H) pads which lasted as long as the OEM set did, maybe 8000 miles give or take. Just changed them 200 miles ago again.
- Rev. CYCHO -
MotoCycho is offline
post #4 of 13 Old 06-06-2006, 10:30 PM
Wookie
ragdoll's Avatar
Check the pads, are they worn down a lot? That can cause the sound. If their is some debris or chemical on the pads it could do it too.
Is the braking power the same as it always has been?
'02 RC-51
'10 Unicycle
ragdoll is offline
post #5 of 13 Old 06-07-2006, 06:47 AM
Honda Addict
razorbike's Avatar
If the brakes feel like they function normally and if the front wheel spins freely when off the ground without a lot of drag it's normal. Mine made a grinding brake sound from the front until about 2,000 miles. Noise is gone now at 8,000 and the brakes work fine. Pads in good shape. They are supposed to drag the rotors just a little bit.
razorbike is offline
post #6 of 13 Old 06-07-2006, 08:03 AM Thread Starter
Everything works great. My service manual said to check for a minimum of .7mm gap between the pads and rotors with a feeler gauge. I couldn't get any size feeler in there. I suppose I should stop whinning and just keep pounding out those miles.
Thanks bro!
nakedj is offline
post #7 of 13 Old 06-07-2006, 08:08 AM
"Whose ABBA ZABBA?"
.7mm is about .028 inch. Not much. If you lift the front end and spin the wheel, does it move rotate a revolution or two with a little bit of 'chhhh chhhh
chhh' sound? If so, =normal. Some pad drag is present especially with dual discs.
General George S. Patton
post #8 of 13 Old 06-07-2006, 08:28 AM
A slight scrubbing is normal. You probably had too much gap prior to changing the lines and brake fluid.
NewRedRider is offline
post #9 of 13 Old 06-07-2006, 08:38 AM
[QUOTE=Bigdaa If you lift the front end and spin the wheel, does it move rotate a revolution or two with a little bit of 'chhhh chhhh
chhh' sound? If so, =normal. [/QUOTE]
A revolution or two seems more than most dual rotor bikes I've seen. Mine goes about 1/2 a turn???
jratbike is offline
post #10 of 13 Old 06-07-2006, 09:50 AM
Did you pull the front wheel axle around the same time or at some point just before realizing you had the additional drag?
post #11 of 13 Old 06-07-2006, 09:52 AM
Honda Addict
razorbike's Avatar
Hmmm, if it only goes 1/2 turn sounds like you do have too much drag.
post #12 of 13 Old 06-07-2006, 10:10 AM
My $.02
Either push/pry back pistons of calipers, better yet unbolt 'em, & spin whl to see if drag still exists. If not, you got a pad or something hanging up. Possibly rest stops dirty???
If drag still exists then you ned to start looking into axle torque? Forks tweaked/improper alignment???
btw... don't forget to "pump up" brakes before riding.
h ryder is offline
post #13 of 13 Old 06-07-2006, 12:53 PM
Warped rotor(s)?
