Brake rotor - Wrist Twisters
post #1 of 13 Old 12-27-2006, 02:29 PM Thread Starter
Toll Runner
str8ghtjacket's Avatar
Brake rotor
Hey guys as I was working on the bike I noticed the rear brake rotor had this washer or spacer was breaking and coming apart, Is this in need of urgent repair or should I let it go for now . str8
str8ghtjacket is offline
post #2 of 13 Old 12-27-2006, 05:01 PM
async's Avatar
I'd replace the brakes now. Better to err on the side of safety.
Just my 2 cents..
async is offline
post #3 of 13 Old 12-27-2006, 06:41 PM
Unbannable
Super Sneaky Steve's Avatar
I'd order the part you need asap, but I wouldn't let that keep me from riding. You still have good working front brakes, right?
Super Sneaky Steve is offline
post #4 of 13 Old 12-27-2006, 06:50 PM Thread Starter
Toll Runner
yeah they are fine, was just trying to hold off for the GB on brake lines , owell one more day wont hurt right!! str8
post #5 of 13 Old 12-27-2006, 07:40 PM
Replace it ASAP... Who knows... Not worth the trouble!
post #6 of 13 Old 12-28-2006, 03:01 AM
Uh....maybe I'm confused, but aren't you pointing to the mounting circle for the pin that holds the brake pads in place? If so, it's just moved away from the caliper because the piston has pushed it out. Completely normal unless the pads are worn to the limits. If the circle is coming apart that is another issue, and yes I would replace it. I don't see what this had to do with the brake rotor via that picture, but maybe I missed something.
post #7 of 13 Old 12-28-2006, 05:44 AM Thread Starter
Toll Runner
HondaJim, your right I should have said brake caliper, not brake rotor,The picture is not real great Ill have to try to get a better one , str8
post #8 of 13 Old 12-28-2006, 07:20 AM
There is not a whole lot going on with the rear brake pad. Looks like there is some sort of white backing next to the pad followed by a thin metal backing plate. All sandwiched together.
post #9 of 13 Old 12-28-2006, 07:33 AM Thread Starter
Toll Runner
Yeah thats it , the white backing next to the metal backing plate . its coming apart right around the pin . Mikes the man!! str8
post #10 of 13 Old 12-28-2006, 07:54 AM
I think that white backing is there for anti squeal. Correct me if I'm wrong. A split or small piece missing around the pin will not effect the rear breaking.
post #11 of 13 Old 12-28-2006, 07:57 AM Thread Starter
Toll Runner
Ok cool thanks Mike, Maybe I can dig into that when I do the brake lines , prob need to do a pad change anyways, wonder if that piece come with the brake pads , prob not . str8
post #12 of 13 Old 12-28-2006, 08:11 AM
OEM yes, Aftermarket no. Here again that is only a educated guess.
post #13 of 13 Old 12-28-2006, 06:56 PM
Go'n So slow I'm stopped
xrmikey's Avatar
Mikes Right. OEM Yes. After Market Has a different Type of Backing Plate, & some don't have any at all. You can use the OEM stuff on the after market pads that don't have one. Makes no difference. All is Interchangeable. Its all for anti-squeal.:001_smile:
xrmikey is offline
