brake light modulator installation 919 - Wrist Twisters
post #1 of 2 Old 07-14-2007, 05:45 PM Thread Starter
I got it together with headlight modulator from headlightmodulator.com. I bought CA version with 4 flashes.
Installation was as following
take seat off, take grabrail off with 6 mm hex, take out two 10 mm bolts under the caps, and plastic grommets, take out rear fairing disconnect two connectors from stop light switches and one connector from main harness. Brown wire is for taillight leave it alone. Connect green modulator to green wire junction in the harness, cut green w yellow strip wire and connect black wire of modulator with two wires to the stoplight end and red wire of the modulator to the single wire which goes to the single connector. Put it back together.
It flashes a bit slow than I expected but does the job..
serge is offline
post #2 of 2 Old 07-15-2007, 10:44 AM
It serves what purpose?
