Brake Light Issue - Wrist Twisters
post #1 of 13 Old 08-11-2015, 04:39 AM Thread Starter
mercenario27's Avatar
Brake Light Issue
Brake Light Issue
I was returning from a ride the other day and I noticed that my EFI light was flickering. My buddy also told me my headlight was out. I pulled the bike apart the other night. I decided to pull out the PCIII, because I never had the money to get it tuned and I also didn't like how the wiring harness was wedged under the tail.
Make a long story short, pulling the PCIII out fixed the EFI problem and resoldered the short in the ignition resolved my initial issues. I reassembled the bike and I noticed I don't have brake lights, but I do have tail lights. I did notice that I had a 2 wire plug not plugged into anything near the EFI. Did I miss something?
Current
2006 Honda CB900F 919 Hornet
Sold
1996 Suzuki GSF750 Kan.of.tuna
1985 Honda VF700 Intercepter
1997 Suzuki DR650
mercenario27 is offline
post #2 of 13 Old 08-11-2015, 04:45 AM
Common issue is the rear brake switch sticking in the closed position, so most likely your brake light is staying on all the time.
marylandmike is online now
post #3 of 13 Old 08-11-2015, 04:46 AM
Originally Posted by mercenario27 View Post
Brake Light Issue I was returning from a ride the other day and I noticed that my EFI light was flickering. My buddy also told me my headlight was out. I pulled the bike apart the other night. I decided to pull out the PCIII, because I never had the money to get it tuned and I also didn't like how the wiring harness was wedged under the tail. Make a long story short, pulling the PCIII out fixed the EFI problem and resoldered the short in the ignition resolved my initial issues. I reassembled the bike and I noticed I don't have brake lights, but I do have tail lights. I did notice that I had a 2 wire plug not plugged into anything near the EFI. Did I miss something?
I had the same concern last time I really dug into mine... That two wire connector is the diagnostic port and isn't connected to anything
post #4 of 13 Old 08-11-2015, 04:59 AM
Did you remember to plug the brake light switch on the front master cylinder back in?
post #5 of 13 Old 08-11-2015, 05:11 AM Thread Starter
My rear switch was acting up, not closing the circuit. replacing the rear brake light switch was on my to do list. Maybe your right its stuck closed now and brake lights are on.
Current
Sold
1997 Suzuki DR650
post #6 of 13 Old 08-11-2015, 05:14 AM Thread Starter
I figured it was a diagnostic port, but after discovering my brake light issue I started to doubt myself.
Current
Sold
1997 Suzuki DR650
post #7 of 13 Old 08-11-2015, 05:16 AM Thread Starter
I did unplug the switch and I think I hooked the two wires back up on the on the correct post. Will it matter if I got the two mixed up?
Current
Sold
1997 Suzuki DR650
post #8 of 13 Old 08-11-2015, 05:22 AM
It does not matter which wire is connected to which post. It is possible with the rubber boot to not seat the wire on a post and think you have it installed correctly. The boot can hold the wire in between posts without making a connection.
ray.beard is offline
post #9 of 13 Old 08-11-2015, 06:46 AM
If it is your rear brake switch, I would replace it with a hydraulic switch, which replaces the banjo bolt at the rear master cylinder. Much more reliable.
post #10 of 13 Old 08-11-2015, 07:21 AM
deandeib's Avatar
Probably so Mike. In the years and 1000's of miles on my 9er, the rear brake light switch is the only thing I've ever had to replace (other than tires and brakes)
deandeib is offline
post #11 of 13 Old 08-12-2015, 03:18 AM Thread Starter
It was the brake switch, it was stuck on. Do you have a part number for a hydraulic switch. is it a bolt on replacement? Thanks for all your help.
Current
Sold
1997 Suzuki DR650
post #12 of 13 Old 08-12-2015, 04:02 AM
post #13 of 13 Old 08-12-2015, 09:12 AM Thread Starter
Kewl Beans
Current
Sold
1997 Suzuki DR650
