Bled the brakes and now... - Wrist Twisters
post #1 of 21 Old 12-02-2008, 06:52 AM Thread Starter
Hey everyone. I bled both the front and rear brakes a few weeks ago, but now I'm seeing what looks like seapage of fluid around the bleed screw. I tightened it back down to spec, and also stuck a little papertowel inside the bleed screw to soak up some of the fluid, but it still leaks out. Both the lever and pedal still feel firm.
I did notice this; when I put on the little black rubber cover, the fluid seems to bubble out around the threads.
Ideas?
Thanks,
Cris P.
s2cmpugh is offline
post #2 of 21 Old 12-02-2008, 06:54 AM
Donation BOTM
Have yo uclean the living crap out of the bleeder area with brake parts cleaner ? Have you noticed the fluid level dropping ? Sometimes they can become saturated with excess fluid and look like its seeping out -
2ohno is offline
post #3 of 21 Old 12-02-2008, 07:11 AM
McCrimmon's Avatar
Sounds like some fluid left over from the bleeding...It will tend to build up inside the bleed screw and in the rubber cap
2008 Yamaha FZ1-Street
2005 Honda CBR 600rr-Track
McCrimmon is offline
post #4 of 21 Old 12-02-2008, 07:50 AM
Wipe the bleed screw(s) squeaky clean as recommended by 2ohno. Is it one or more screws leaking? Most important, never over tighten these bleed screws.
post #5 of 21 Old 12-02-2008, 08:37 AM Thread Starter
I tightened down the bleed screw to 6ft lbs (had to use a wobble extension on it b/c of the tight space). The rear one is worse compared to the front ones. I guess I didn't get the papertowel down inside the screw far enough. I'll try to clean it up even more. Is this a common issue after bleeding the brakes on this bike?
s2cmpugh is offline
post #6 of 21 Old 12-02-2008, 08:43 AM
Donation BOTM
Having fluid stuck in that stupid little cap is !
2ohno is offline
post #7 of 21 Old 12-02-2008, 09:00 AM Thread Starter
Well mine seems to be coming from the threads and hangs out between the caliper and rubber cap loop thing that is secured to the bleed screw.
Cris P.
s2cmpugh is offline
post #8 of 21 Old 12-02-2008, 12:29 PM
CB900 Hornet
Sturmmann's Avatar
It is normal to have some seepage from the bleeder after any bleeding. It's the left over fluid that dances around the threads and center shaft. Clean it meticulously and keep riding.
The only concern to look for now is the gradual increase of brake lever/pedal effort. Then, and only then will you know it is losing brake pressure...well along with the fact that fluid is leaking and dripping out.
But since you have done the procedures correctly, there is nothing to worry about buddy! Ride hard!
Sturmmann is offline
post #9 of 21 Old 12-02-2008, 03:32 PM
Franklin McGillacutty
riquefied919's Avatar
Cris P.
actully if fluid is seaping out then the brake fluid is asorbing water. reducing the effectiveness and boiling point of the fluid. Simultainiusly rusting the piiisss out of the system.
A wobble , universal joint, or extension will reduce the torque to the bleeder.all three used together makes your torque wrench all but useless. PM me if you need assistance.
Your bleeder screw sounds like its not seated properly. Due to lack of torque, contamination or bad seat. First try giving them a LITTLE more torque. If this does not work remove and inspect the bleeder screw seats.Clean the tapered end and seat in the caliper, be quick you will only have so much time before the system runs dry then reinstall.
riquefied919 is offline
post #10 of 21 Old 12-02-2008, 07:40 PM Thread Starter
Well damnit. I'll try torqueing them down a bit more to see what happens. I never loosened them much at all, just enough to let fluid flow thru. If it is just excess fluid stuck inside the threads and hold leaking out, how much longer will it continue to do so?
Thanks,
Cris P.
s2cmpugh is offline
post #11 of 21 Old 12-02-2008, 07:51 PM Thread Starter
I should add that I noticed when I push the little rubber cap back on top it seems to force it out more. Is that a coincidence?
Cris P.
s2cmpugh is offline
post #12 of 21 Old 12-02-2008, 07:55 PM
Cris P.
take a qtip or 5 and dry all the fluid out of the little rubber cap... then pump the brakes with the little cap off.. if there is fluid coming around the bleeder then you have something wrong with the bleeder get a new one.. if if isnt coming out then put the little cap back on after you get all the fluid out of it.. if fluid starts coming out then... then you need someone smarter than me.. its either fluid inside that litttle cap.. or a bad bleeder... or maybe its not tight enough... try to tighten it with a wrench
post #13 of 21 Old 12-02-2008, 08:03 PM Thread Starter
Why would all three be seeping like this? Kinda seems odd that all three bleeders are bad, doesn't it?
Cris P.
s2cmpugh is offline
post #14 of 21 Old 12-02-2008, 08:29 PM
Cris P.
yeah... i think they are either just a touch loose.... or more likely this is a job for captain q-tip
post #15 of 21 Old 12-02-2008, 09:49 PM
Trackday Recognition Veteran
I agree. I've never used a torque wrench for bleeders; just a small wrench.
Sokali is offline
post #16 of 21 Old 12-02-2008, 10:18 PM
Resident Viper Driver
919jockey's Avatar
I agree. I've never had what you described when I've bled my brakes before. I've also never bothered using my torque wrench on them either.
919jockey is offline
post #17 of 21 Old 12-03-2008, 08:49 AM Thread Starter
I'll clean them up real good w/ Admiral Q-tip when I get back into town. I do remember this though...when I push and pulled HARD on the pedal and lever, no fluid came out, no bubble, and no seepage. It only seeps when I put on that little black rubber cap back on the bleeder screw.
Cris P.
s2cmpugh is offline
post #18 of 21 Old 12-03-2008, 09:09 AM
Yes I just use the german torque spec " Good-unt-ight" til they stop leaking.
post #19 of 21 Old 12-03-2008, 09:21 AM
Cris P.
sounds like a job for el senor q-tip
post #20 of 21 Old 12-03-2008, 10:34 AM
s2cmpugh PM'd me on this (somehow I missed it), and I'll give y'all the cliff notes version of my reply.
When the bleeders are opened, the fluid fills the cavity of the hole where the bleeder threads in pretty much completely, most of which comes out the end of the bleeder. That's most, not all. When the bleeder is tightened down the fluid stays in that cavity and is forced out past the threads when the cap is put on. As the brakes are used the fluid will heat and expand, along with any air trapped under the cap, and continues to work it's way past the threads. To cure this apply some vacuum to the bleeder after tightening it down and the air drawn past the threads will carry fluid with it and out the end of the bleeder. Works pretty well.
As to how tight to run down the bleeders, everyone assumes that 1,000 PSI behind the bleeder requires a lot of tightening to prevent leakage: it just ain't so! While it is 1,000 PSI, the total force trying to push the tapered end of the bleeder away from it's seat is quite small -- with the typical size of the drilling to the bleeder being 2.5 mm, or just under 0.01", the force is well under 10 pounds (hole area of 0.0076 square inches times 1,000 pounds per square inch = 7.6 pounds force applied). Overtightening the bleeders can deform the tapered end, actually crushing down the cross drilling, and after that it doesn't matter how tight you get it: it will never seal. Overtightening can also damage the seat in the caliper, and there is no cure for that other than replacing it. Well, there is a cure, but it's a jury rig, and jury rigging brakes is not advised!
post #21 of 21 Old 12-03-2008, 12:36 PM
you'd have to be one stuot guy to tighten something that tight using a 10mm wrench. With palms of steel.
