Bike Will not start? - Wrist Twisters
post #1 of 53 Old 03-05-2009, 12:15 PM Thread Starter
Jared G 919's Avatar
Hey guys,
I'm finishing up my projects on my 919 for the Winter (renthal bars installed, painting my grey parts matte black) and I am eagerly awaiting warmer weather and street cleaners.
That being said, I tried to fire up my bike quick the other day and got nothing except a few backfires out of the mufflers. I tried again today with a charger attached because my battery died on me, and again, nothing but some backfires. I pulled the choke on, left it off, gave it a little gas, which probably only complicates the issue, and left the gas alone. The gas tank has fuel in it, with some stabil from late fall.
I have started it every couple weeks this winter just to warm it up a little bit, and the last time, about 2 weeks ago, it fired up just fine.
I cant quite figure it out. Any ideas on this?
Jared G 919 is offline
post #2 of 53 Old 03-05-2009, 12:48 PM
Try draining the old gas out and putting new in? Spark plugs?
ultimatefighter34 is offline
post #3 of 53 Old 03-05-2009, 01:17 PM
3dcycle's Avatar
the question should be what did you touch last. start there.
3dcycle is offline
post #4 of 53 Old 03-05-2009, 01:52 PM
Tire abuser
prtsimmons's Avatar
+1 to the post that said "check what you touched last"
Check everything on the handlebar - especially the clutch cut-out switch and the throttle cable. If the throttle cable is a bit tight, it might be opening the throttle butterflies and making it difficult to start.
prtsimmons is offline
post #5 of 53 Old 03-06-2009, 01:45 PM Thread Starter
Sounds good. I think I'll start by tearing down the handlebars again. Gas should be good right now.
Thanks guys. We'll see what happens.
post #6 of 53 Old 03-06-2009, 01:52 PM
3dcycle's Avatar
can you go into a little more detail of what you painted. which peices, that might help a little too.
3dcycle is offline
post #7 of 53 Old 03-09-2009, 11:21 AM Thread Starter
idle screw
Anyone know how many turns from fully closed the idle screw should be set at?
post #8 of 53 Old 03-09-2009, 11:26 AM
Praefectus Castrorum
brevity's Avatar
If you're referring to the yellow-knobbed adjuster, then adjust it until your warmed-up engine (idling) is spinning in the neighborhood of 1,200 rpms. I don't remember reading anything in the shop manual about an 'adjust from zero' instruction.
brevity is offline
post #9 of 53 Old 03-09-2009, 11:47 AM Thread Starter
Hi there, well I have no idea. I've checked the sidestand, messed with the yellow idle screw, tried starting in full throttle to shut off the fuel and everything else.
I did mess with the throttle lines, so now I have no idea where they are to be set factory.
3d, I just painted the side covers, exhaust covers and passenger handle.
I think I will need to check the plugs. Is this a fairly time-consuming ordeal? It looks like it is according to the manual.
The bike has only 4000 miles on it. Should the plugs fould that fast? Is the back-firing a hint of that? Sorry, I'm not the most engine-savvy when it comes to understanding them.
post #10 of 53 Old 03-09-2009, 11:49 AM
Combined threads
post #11 of 53 Old 03-09-2009, 11:50 AM Thread Starter
post #12 of 53 Old 03-09-2009, 11:50 AM
Combined threads
totally confused me for like 25 seconds...lol...
post #13 of 53 Old 03-09-2009, 11:51 AM Thread Starter
sorry about that. Didnt mean to do that.
post #14 of 53 Old 03-09-2009, 12:27 PM
As stated above... bike ran good before you changed the handlebars, correct?
What exactly did you do to the throttle cables? There should be a ever so slight play in the throttle when it is closed. Twist the throttle then let it go. Do it snap back by itself without binding?
post #15 of 53 Old 03-09-2009, 12:45 PM
is there a posibility he broke a wire or something inside the housing??
i know it turns over... but does he have spark??
post #16 of 53 Old 03-09-2009, 12:56 PM
The switch housing contains the starter button and the red rocker kill switch.
If a wire was broken on the starter button or the kill switch the bike would not turn over.
Jared: We are under the assumption the bike turns over... Correct?
post #17 of 53 Old 03-09-2009, 12:56 PM Thread Starter
The slack in the throttle feels as it should. It does snap back. I'm losing my mind over this.
post #18 of 53 Old 03-09-2009, 12:58 PM Thread Starter
Hi,
Yes, it does turn-over. Just wont light. Any fuel introduced with the throttle creates a rumbling sound in the exhaust and a very loud backfire.
post #19 of 53 Old 03-09-2009, 01:10 PM
Just re-read your 1st. post. It stated that you started the bike a couple of week ago. Was anything done to the bike after it was running? It is not clear if the mods. were done before or after the bike was last running.
post #20 of 53 Old 03-09-2009, 01:34 PM Thread Starter
The bike was running before and after the mods. That's why I'm not sure what the deal is.
post #21 of 53 Old 03-09-2009, 01:44 PM
Sorry for the 101 questions... It's not easy to troubleshoot over the net.
When you did warm it up every couple of weeks, how long did allow the bike to run. BTW: I would never recommend this procedure, you do more harm than good.
Battery Tender - Stabil, fresh oil/oil filter, done until spring.
post #22 of 53 Old 03-09-2009, 02:06 PM Thread Starter
no problem. I completely understand. I only allowed it to run for a few minutes just to warm it up.
post #23 of 53 Old 03-09-2009, 02:11 PM
In that case, I would suspect fouled spark plugs. Pull them out and post up a pic or two. The pugs are not the easiest to remove, are you up for the task?
post #24 of 53 Old 03-09-2009, 02:33 PM Thread Starter
Will do. The manual says to disconnect the rad. fill neck, radiator etc; I'm assuming this might take some time to do huh? Sorry for all the questions.
post #25 of 53 Old 03-09-2009, 02:42 PM
3dcycle's Avatar
what bout the kill switch? hate to pull the plugs of and see kill switch is in kill postion. friends wife did it to her 599, could not figure it out. not 100% sure but 919 does spin with it killed right? most hondas do.
3dcycle is offline
post #26 of 53 Old 03-09-2009, 02:50 PM
Hi,
Jared: This thread will help.
Read Jared's post. Kill Switch in the OFF position - You get nothing!
post #27 of 53 Old 03-09-2009, 04:14 PM
3dcycle's Avatar
oh ok just had to make sure that could not be the issue, (hate it when it happens)
3dcycle is offline
post #28 of 53 Old 03-09-2009, 08:21 PM Thread Starter
I probably should mention also that my "FI" light comes on when trying to start.
post #29 of 53 Old 03-10-2009, 06:40 AM
It wound help if you had supplied ALL the information. Forget about the spark plugs, you have a more technical problem. Follow the PGM-FI self diagnosis as outlined on page 5-10 of the shop manual.
post #30 of 53 Old 03-10-2009, 10:17 AM Thread Starter
So the spark plugs probably arent the issue then huh? I'm assuming the "shop manual" is different from the owners manual correct? Do I need to get this through Honda directly?
You'd think that buying a brand-new, 0 miles bike from Honda, you could get a little more than 4000 mi. out of it without having to worry about this stuff. I havent done anything drastically to my bike as far as mods. New bars, and the bafflectomy and taking my rear tail-lights off. I've owned a Honda Accord and an Acura TL type S and never had one issue with either one of them.
If I have to start throwing money I dont have around already on this bike, (towing cost, repair cost, parts) and dealers telling me because I did a couple mods they wont touch it, i might be better off cutting my losses and selling the thing. I'm really frustrated right now.
Thanks for all the help you guys have given me on this. I DO appreciate it.
post #31 of 53 Old 03-10-2009, 10:30 AM
Trackday Recognition Veteran
You need to slow down a little, don't need to go to drastic measures like selling the bike.
I'd still take a look at the plugs first, regardless of the FI light.
At least the easy ones.
The FI light should stay on till the engine has started. I may be wrong, but I don't think so...
It is a Honda, after all... :
Sokali is offline
post #32 of 53 Old 03-10-2009, 10:49 AM
I'm going riding.
scrat's Avatar
Don't sell it! it is usually the simple things that frustrate us! it is rather easy to check the plugs, you can even get the outside ones out w/o having to raise the tank. it should have the color of a beautifully toasted marshmallow... One reason it's good to just let it be stored in the winter (without starting it) is that it will load up on fuel... and even when it comes up to temperature in the garage, it takes a while to run it out of the system. In extreme cases of flooding, fuel will wash down the cylinders and mix with your oil, reducing compression from not having a wet seal between the rings and cylinders. This will also prevent starting, but can be remedied with an oil change.
Step 1: check plugs. they can be a tell-all!
scrat is offline
post #33 of 53 Old 03-10-2009, 11:47 AM
put a set of stock cans on there and take it to them and tell them to fix it..........
a call to honda corporate will help if they don't wanna.....
it is under warranty... don't take no b.s. from them..
post #34 of 53 Old 03-10-2009, 12:22 PM
OKAY. I walked out to the parking lot and tested this. The FI light comes on briefly when you turn the bike on. It goes off about the same time the fuel pump quits priming the system. It does not come back on when cranking either.
However. If anyone remembers this thread... https://www.wristtwisters.com/forum/s...ad.php?t=15908 ...then you may remember me having issues with the bike starting.
For whatever reason, the kill switch was about halfway cocked when I took off for the day and it flipped on/off/whatever and killed the bike as I was going down the road. With the kill switch triggered, the FI light came on.
Of course, it didn't turn over when the kill switch is engaged, but since you replaced the bars, maybe somehow the switch is killing power to the coils but allowing you to turn over the starter...is that possible? Don't know...just grasping. Check the plugs.
Did you get a tool-kit with your bike? You should have. It will have a plug tool in there. I find that it is quite easy to just lift the tank, prop it up with by putting a short 2x4 between the tank and the frame (run the board left to right with the bike...not along the frame) then use the plug tool, a ratchet, and I think a 10 MM socket. This is much easier than the way the manual recommends.
If all else fails, you can find a friend with a truck/trailer and have them help you take it to the dealer for fixing under warranty.
post #35 of 53 Old 03-10-2009, 03:26 PM
Check the plugs...
Sokali is offline
post #36 of 53 Old 03-10-2009, 03:44 PM
Tom
Tom's Avatar
Some reference material:
Tom is offline
post #37 of 53 Old 03-10-2009, 04:59 PM
3dcycle's Avatar
you beat me...
mazing how "WE" mess up our bike and now its hondas fault
3dcycle is offline
post #38 of 53 Old 03-12-2009, 09:31 AM Thread Starter
Okay. Been a long couple days. Thanks again everyone for the help on this. I am going to get a look at the plugs today. However, I was one of the people that bought my bike brand-new and didnt get a tool kit. Can anyone recommend the size plug socket I need? I did a search and couldnt come up with anything. Any certain other attachments that might be useful in getting the plugs out?
post #39 of 53 Old 03-12-2009, 10:11 AM
Tom
Tom's Avatar
...5/8" (16mm)...
Tom is offline
post #40 of 53 Old 03-12-2009, 01:51 PM Thread Starter
Thank Tom. Got the wrench.
Well here's what the easy ones look like right out of the bike: To me, they are plenty dirty. Would cleaning them be the best option? Or just order some new ones?
