Bigger Petrol Tank Mods - Wrist Twisters
post #1 of 18 Old 11-12-2007, 01:12 AM Thread Starter
Bosi72's Avatar
Hi,
I will be travelling more than 250km on one tank which is currently standard for Honda CB900F6. Ideally I will be travelling 500km, but 350km will be Ok too. Has anyone heard about replacing standard with some non-standard (or from other bike make/model) tank ?
Regards
Bosi
Bosi72 is offline
post #2 of 18 Old 11-12-2007, 01:33 AM
Not Banned
Tk919's Avatar
The tank is what gives the 919 its cool look .. GL on finding what you want though...
Tk919 is offline
post #3 of 18 Old 11-12-2007, 01:41 AM
Ben
HondaStreetfigh's Avatar
Get a Goldwing.
2 > 4
HondaStreetfigh is offline
post #4 of 18 Old 11-12-2007, 02:01 AM
mee2yoo's Avatar
Not a chance bro. Too much to go wrong to even try and hook up an auxillary tank or some other model of tank. Just get used to pulling over for gas a little more frequently. Besides, with the OEM tank, you'll look cool doing it 'cause the OEM tank gives the bike its SWEET lines!
Ride Red or Go Home!!!
mee2yoo is offline
post #5 of 18 Old 11-12-2007, 05:06 PM
Veteran Donation
But if you figue a way to do it .I want to know 6+ gallons would be great!!!
tvetree is offline
post #6 of 18 Old 11-12-2007, 05:53 PM
Praefectus Castrorum
brevity's Avatar
Originally Posted by HondaStreetfigh View Post
Get a Goldwing.
+1
Or an Elite... j/k
brevity is offline
post #7 of 18 Old 11-12-2007, 06:13 PM
Tom
Tom's Avatar
Check this out.
Tom is offline
post #8 of 18 Old 11-12-2007, 07:00 PM Thread Starter
Bosi72's Avatar
Thanks for all your responses.
A fellow biker from Oz sent me a link about mods that he performed on his Honda CX500. Great article, probably something I will perform on my Hornet.
http://users.monash.edu.au/~jhovel/tank-part1.shtml
Cheers
Bosi72 is offline
post #9 of 18 Old 11-12-2007, 07:14 PM
Hwysurfer's Avatar
I get close to 350 km with stock tank, indicated. But that's riding it to fumes. Commute on Hwy only at 5k rpm.
Hwysurfer is offline
post #10 of 18 Old 11-12-2007, 07:58 PM
Go'n So slow I'm stopped
xrmikey's Avatar
With the custom bike builders around, I'm sure you could find someone to expand your tank for a 6-7 gal. capacity. It's all about how much $ you want to spend. I'll bet they could keep the same look going for the bike too.
It would just be taller & maybe a little wider.
xrmikey is offline
post #11 of 18 Old 11-12-2007, 08:27 PM
I need a break by the time the tank is empty. But if you are in the Outback I can fully appreciate the dilemma. Once in upper Canada when a station was closed, I barely rode 50ml to the next one from carried fuel cans.
Not excited about the bondo transformer tank option. Get a custom one built, and you'll be a lot happier.
dream is offline
post #12 of 18 Old 11-12-2007, 08:44 PM
Resident Viper Driver
919jockey's Avatar
I dunno, get a luggage rack that you could put a gas tank on to use when you need it?
919jockey is offline
post #13 of 18 Old 11-12-2007, 09:40 PM
Lethal with Whiffle-Bats
Caleb_I's Avatar
Remove Pump from tank, extend lines, add saddlebag brackets... install jerrycans,, link jerrycans+tank+pump
HEHE.... that should get you far enough to need to get off!... J/k I wouldn't advise this at all.. however I have seen an older Shadow 750 with metal cans in place of saddlebags,, and Hoses linking them, and 2 hoses ziptied to the side, going up under the tank... I can only imagine that was what the poor bastard was doing....
Caleb_I is offline
post #14 of 18 Old 11-12-2007, 09:48 PM
I have seen video of cage/bike crashes starting lethal fuel fires. So I am reluctant to carry extra fuel.
dream is offline
post #15 of 18 Old 11-13-2007, 02:50 AM
Team Hornet
Ratmick's Avatar
FWIW I run mine on premium unleaded and it normally returns between 19-20km/l. That would give 340-360km per tank if you ran it to empty...but I fill mine when the reserve light comes on.
Interestingly my ZZR600 got much the same for 2/3 the engine (plus a bit more weight).
Mick
Ratmick is offline
post #16 of 18 Old 11-13-2007, 04:00 AM
How about carrying a reserve in the top case...
rangermania is offline
post #17 of 18 Old 11-13-2007, 06:59 AM
hooker_47's Avatar
Here is a link to tanks that a lot of the ADV guys use. You would have to modify, of course, but it would give you some extra on the bike.
http://www.kolpinpowersports.com/sto...ies/3/products
This one took me awhile to find. It's a company out of Australia. They make the bladders specific for the bikes shown on the webpage, but I know some guys have made use of the bladders on other bikes. Might be worth a call.
http://nomadtanks.com.au/Tanks.php
-Joe
hooker_47 is offline
post #18 of 18 Old 12-04-2007, 12:53 PM
yikes! i only get, say, 180-190kms when the reserve lights. i've been able to get, at times, 220kms but that is probably pushing it.
zimi... is offline
