being lazy - Wrist Twisters
post #1 of 16 Old 06-30-2008, 07:03 AM Thread Starter
Fishfilet300's Avatar
being lazy
Ok I know I'm being lazy and could probably do an intensive search of past forums to get my answer but it's much faster to just ask....Where do you put the big 2.5 x 1 x 1 inch black box labeld (must be used) on Rizoma turn signals? I have two of them for the front and I can't get them into the headlight bucket.
Your's doesn't matter.
Fishfilet300 is offline
post #2 of 16 Old 06-30-2008, 09:16 AM
What's the black box for?
There is no room in the bucket, that's for sure. Do you have enough wire to get it under the seat? That's where it probably belongs.
If you have a little Givi screen like I, if you're really lazy, just velcro it to the top of your guage cluster. You're probably the only guy who would ever notice it. I keep a spare black turtleneck shirt there most of the time just in case.
post #3 of 16 Old 06-30-2008, 09:52 AM Thread Starter
Seriously? You don't have the box?? Hmmmmmm There's absolutly no way are the wires long enough to reach the seat.
Anyone else have the Avio 21?
post #4 of 16 Old 06-30-2008, 10:27 AM Thread Starter
OK I found out what the box is, it's a load box and resistor. Can anyone with an electrical background tell me if I can splice two lights into one box, (to conserve space) or if I have to use one for each light?
post #5 of 16 Old 06-30-2008, 10:52 AM
Probably would be easier to just buy a LED flasher and replace the stock flasher under the seat.
post #6 of 16 Old 06-30-2008, 11:27 AM
I (think I) know LEDs need an LED flasher unit. I thought that was what your "black box" was. Resistors slow LEDs down, but they also dim your LEDs.
But, yeah, get the LED flasher unit.
post #7 of 16 Old 06-30-2008, 11:32 AM
Stop being lazy, read the 919 Helpful Topics!
post #8 of 16 Old 06-30-2008, 11:33 AM
Unbannable
Super Sneaky Steve's Avatar
If you're doing only one set of LED's you don't need to use resistors or change your relay. Your blink rate will go faster but that just makes it stand out more.
Super Sneaky Steve is offline
post #9 of 16 Old 06-30-2008, 11:42 AM Thread Starter
Oh I assure you I've read the infamous How to link. Infact that's the only reason why I thought I could handle this mod But when the product arrived with it's load box and extra resistor and nothing like the How To link , I thought I was out in uncharted waters. I wasn't sure if it was a Rizoma nuiance. I'll post some picts tonight when I get home so the WT team and see what I'm looking at.
post #10 of 16 Old 06-30-2008, 12:55 PM
cpg74's Avatar
I guess the new Rizomas your supposed to use them, if you do and where you put them I don't have a clue?
I'd just shoot an e-mail over to PJ's and see what they say.
I've got an older set, but you can see it slightly cracking where the clear part holds the screw in and spoke with Paige about getting a replacement pair, which reminds me that I need to get a picture taken and send it there way of mine.
cpg74 is offline
post #11 of 16 Old 06-30-2008, 03:38 PM
(oYo)
2000TJ's Avatar
mechanical flasher from your local auto parts store is all you need
replacing the OEM flasher is only required to quell the fast blink (resulting from the change in resistance on the circuit)
assuming your lights have integrated current protection (resistors), a mechanical will do you just fine
2000TJ is offline
post #12 of 16 Old 06-30-2008, 06:13 PM
The "load box" is just an 8 ohm 25 watt power resistor that emulates the current draw of the original incandescent bulbs to duplicate the original flash rate. There must be one per side if you want the slower flash rate if you do not go with an LED specific flasher. In use, the resistor will get quite hot (perfectly normal), so should be mounted solidly to a piece of metal to help get rid of that heat -- otherwise it will either burn out or overheat wires or components near it, and yes it will get hot enough to melt plastic. There is, however, no reason to mount tham near the front signals -- anywhere in the circuit will do, so you could place them under the seat firmly tied to a frame member to act as a heat sink.
Frankly, a mechanical or LED specific flasher is a preferable solution, but be advised that there may be a problem if you are still using conventional rear turn signals -- the LED flasher may not be able to handle the extra load, and may either burn out or shorten it's life. Check the manufacturer's literature to be sure it can handle it.
post #13 of 16 Old 06-30-2008, 07:23 PM Thread Starter
ok as promised here are the photos of all the components and the very lame instructions. Maybe you can help decipher them. As you can see the wires are pretty short, the load box is quite large and the resistor is a seperate component. Any help you can offer would be greatly appreciated.
post #14 of 16 Old 06-30-2008, 09:30 PM
Boy, that is lame! It appears the load box may be a separate flasher unit triggered by the rears, but it's difficult to be sure given their lavish description. Ah well -- you can hook it up as they show and see what happens. Without further technical data it's difficult to say what is going on inside the turn signal, but I suspect there is a single high power LED and the load box is what's called a current buck driver, and would be essential for proper operation. It would be interesting to see the insides of the indicator. Lacking that, assume everything they sent is necessary and find a place for all the stuff near the indicators.
Good luck finding a place for everything -- it looks like they assume you have a sportbike and acres of room inside a fairing.
post #15 of 16 Old 07-01-2008, 04:38 AM
I'm going out on a limb here, it's appears you have 2 options.
1. Use the Rizoma box
2. Loose the Rizoma box in favor of a Electronic flasher to slow down the blink rate. These plug n' play flashers are linked on the 919 Helpful Topics.
It's easy to wire the the new blinkers into your existing stock set-up.
post #16 of 16 Old 07-01-2008, 09:17 AM Thread Starter
I just with Mike at PJ's Parts (great people) to clear up what the box is for. It turns out that these are high intensity LED's and the box is nothing more then a coverter to prevent the bulb from burning out. As clearly stated in the photo, "it must be used". Without it, the bulb will fry in one blink (ouch). The seperate additional resistor is to adjust the blink rate if you want. Because there is so little room in the 919 headlight bucket, I AM going to have to splice in additional length to run wires from under the seat to the front signals. So there you have it. Thank you all for your help. -Fish
