Bearing Driver set - Wrist Twisters
post #1 of 6 Old 12-06-2008, 03:12 PM Thread Starter
Bearing Driver set
Hey guys.. Does anyone know of a supplier or brand that has a bearing driver set that has both an outer driver and a pilot style of driver....
I attached a page from our 919 Honda service manual as this is the type of bearing driver set I am looking for..
thanks for your help guys!
CB900F2 is offline
post #2 of 6 Old 12-07-2008, 07:47 AM
touring919's Avatar
Sockets and a vice. Or sockets and a rubber mallet.
touring919 is offline
post #3 of 6 Old 12-07-2008, 08:38 AM
Sockets and a vice aren't going to get it. What are you going to clamp that vice to? I've been down the bearing replacement road. You need a bearing driver set if you want to be assured that the job will, and has been done right. You start beating on your wheel with what ever you have laying around and you're asking for trouble. I had the mechanic at work, a pro, install mine. He has the proper tools and know-how to do it right. If you don't posess the know how, at least get the right tools.
If I wanted a bearing driver set, which I don't because I wouldn't get my moneys worth out of it, Id check Sears, then maybe Northern Hydralics, or Snap-On or a Mac dealer.
And be sure to greasd the inner hub and outer bearing surface before you start driving that bearing in because it it a TIGHT fit.
post #4 of 6 Old 12-07-2008, 10:55 AM
919 City Pilot
Pegjumpflyer's Avatar
I have a few Matco sets....I Have to look to see how big (dia) they go. Thet are standard though.
Pegjumpflyer is offline
post #5 of 6 Old 12-07-2008, 03:02 PM
I've got a complete set of bearing removal tools from Motion Pro. Used them many times to remove wheel bearings:
http://www.motionpro.com/motorcycle/..._remover_sets/
They also have a tool to install swingarm bearings.
Bearing install is usually easy. Put the bearing in the freezer overnight. Heat the part the bearing is going in. Using the old bearing, place it on top of the new one and drive it in. Just make sure you're putting pressure on the outside race only, and that you get it started straight. I've changed numerous wheel bearings this way and it's quite easy. If I was going to do a swingarm bearing I'd probably use the same method, or the vise method. Or you could buy the Motion Pro or similar swingarm tool.
It looks like it would be pretty easy to make with all thread rod, bolts and some washers. A hardened bolt would probably work better without fear of stripping the threads.
post #6 of 6 Old 12-07-2008, 04:28 PM Thread Starter
This is true... but I found a light duty shop press for cheap, so I am in the lookout for the driver set as noted... I never thought sourcing out the bearing driver set with a pilot style of design would be so hard...
Checked with snapon, mac, grey and other tool manufactures and nothing.. very odd..
CB900F2 is offline
