AUSSIE HORNET PICS - Wrist Twisters
post #1 of 23 Old 07-14-2008, 04:01 AM Thread Starter
NAKED & IN LUV
GLENN's Avatar
AUSSIE HORNET PICS
THIS IS THE BEST SITE I'VE SEEN ON THE NET AND ALL THE INFORMATION IS AWESOME. WELL DONE GUYS!!! HERE'S THE LIST OF THE MODS THAT I HAVE DONE TO MY BIKE.
-RIZOMA PROTOTYPE MIRRORS
-GSM SIDE COVERS
-CLEAR ALTERNATIVE INTERGRATED TAIL & TURN SIGNALS
-BRAIDED BRAKE LINES
-RENTHAL ULTRA LOW BAR
-REMIUS CANS
-SATO REAR SETS
-PAZZO SHORTY LEVERS
-K & N FILTER
-PC111
-FLAPPER MOD
-HEADS PORT & POLISHED
-VENTURA BAGS
-110 HP
GLENN is offline
post #2 of 23 Old 07-14-2008, 04:08 AM
Great lookin' Bike Glenn and very nice mods!
marylandmike is online now
post #3 of 23 Old 07-14-2008, 04:22 AM
Ken
Community Admin
Ken's Avatar
Welcome aboard, Glenn. Great looking Hornet!
2009 Honda Goldwing
Ken is offline
post #4 of 23 Old 07-14-2008, 04:25 AM Thread Starter
NAKED & IN LUV
GLENN's Avatar
TNX MIKE
GLENN is offline
post #5 of 23 Old 07-14-2008, 04:27 AM Thread Starter
NAKED & IN LUV
GLENN's Avatar
GOOD TO BE HERE
GLENN is offline
post #6 of 23 Old 07-14-2008, 04:35 AM
Heavy Metal
ratdog's Avatar
Go BLUE
Crush the Magpies !!!
welcome
ratdog is offline
post #7 of 23 Old 07-14-2008, 07:13 AM
Curmudgeon
semi_gray's Avatar
I don't see PAIRS blockoff plates in that impressive list of mods
semi_gray is offline
post #8 of 23 Old 07-14-2008, 07:31 AM
welcome to the hive. I suggest you contact semi-grey about his block off plates they are amazing
post #9 of 23 Old 07-14-2008, 09:28 AM
919, CRF250X, LC4, CB400F
ndcent's Avatar
Classy mods.
ndcent is offline
post #10 of 23 Old 07-14-2008, 09:38 AM
Welcome aboard
dadogs is offline
post #11 of 23 Old 07-15-2008, 03:57 PM
Speed Lover
XRCajun's Avatar
Nice job Glenn! Looks like you also eliminated the rear fender. Add that to your mods. And get rid of the factory sticker on the swing arm.
Welcome aboard.
XRCajun is offline
post #12 of 23 Old 07-15-2008, 07:23 PM
huh
what are block off plates?
post #13 of 23 Old 07-15-2008, 07:50 PM Thread Starter
NAKED & IN LUV
GLENN's Avatar
Originally Posted by MotoCycho
You could remove and block off the entire PAIR valve system. It's the two hoses coming out of the top of the valve cover... they run to a valve which sits in the triangular shaped area in the frame right above, then there is a hose which runs back to the air box. Remove all hoses and valve, plug air-box nipple and custom cut block-offs for the holes in top of the valve cover out of plate aluminum. You can use one of the hose plenum thingies as a template. Underneath, there are REED valves, 2 per side 4 total. The REED valves can be used to seal your block-offs but you have to remove the #2 Philips screw from each one first as the top of the screw will interfere with a flat fit. Every single screw in my 4 REED valves broke but who cares.. you are just blocking off? Removing the PAIR system will neither help or hurt your engine performance or fuel economy. The PAIR system is simply a way for the manufacturer to get cleaner PPM (parts per million) emissions readings at the tail pipe by injecting fresh air into the exhaust on deceleration. The PAIR system does not actually add to or reduce the actual number of molecules of pollutants, it simply fluffs up what is coming out of the tail pipe. Removing the PAIR system will reduce or eliminate that popping noise you get out the tail pipe on deceleration. In my opinion, the PAIR is dead weight on the bike (mere ounces.. but?) and like you said, clutters up the otherwise cleanliness of the top of the engine. Changing spark plugs is much easier with it gone. Also, you will need shorter screws for your block-off plates.
Or.......you could use a set of my PAIRS plates I've just made available. No need to remove the screws on the reed valves as I've made blind holes on the underside for those.
I also used M6 studs and stainless steel acorn nuts (polished) for a finished look on my bike. Just a thought (or plug)
GLENN is offline
post #14 of 23 Old 07-16-2008, 11:58 AM
Looks good!
post #15 of 23 Old 07-16-2008, 12:06 PM
wisco919's Avatar
Sweet!!
wisco919 is offline
post #16 of 23 Old 07-16-2008, 12:08 PM
Love the Mirrors. Where would I get a pair if I wanted some?
Ripper is offline
post #17 of 23 Old 07-16-2008, 03:45 PM
Lone Wolff's Avatar
Where did you buy your Ventura luggage rack/bags?
Do you just have the Pack rack, and no L brackets when you have the bags attached?
Only one North American distributor for these that I can find, and their website makes it seem like the L brackets are required for the sport rack or pack rack. Your bike doesn't appear to need them.
Thanks a million for sharing these pics! You may have saved me a bunch of $$ when I finally decide what to go with regarding luggage for my bike.
2006 Honda 919
Lone Wolff is offline
post #18 of 23 Old 07-16-2008, 04:12 PM Thread Starter
NAKED & IN LUV
GLENN's Avatar
prototype mirrors
http://www.pjsparts.com/catalog/inde...2aa76145db1805
GLENN is offline
post #19 of 23 Old 07-16-2008, 04:30 PM Thread Starter
NAKED & IN LUV
GLENN's Avatar
mine local bike dealer or http://www.kenma.com.au/ven_bps.html.
yes u need L bracket mounts , pak rack & grab rail slide into bracket mounts about 2 inches
GLENN is offline
post #20 of 23 Old 07-16-2008, 05:00 PM
Wow Real Nice Welcome
post #21 of 23 Old 07-16-2008, 05:54 PM
Lone Wolff's Avatar
OK, so the L brackets are mounted to the frame inside the rear cowl and the only visible part is what sticks up thru the grab rail holes. Is that correct?
Having to get those doubles the price, but this is a system I am definitely considering. I really like having the option of a normal sized rack for everyday use, and the larger pack rack when needed for trips.
Thanks for the info.
2006 Honda 919
post #22 of 23 Old 07-16-2008, 08:00 PM Thread Starter
NAKED & IN LUV
GLENN's Avatar
that is why i got this system best of both worlds.
basically that is all that sticks out beside the bolts for swapping racks.
GLENN is offline
post #23 of 23 Old 07-19-2008, 10:56 AM
Lone Wolff's Avatar
I pulled the trigger and ordered a tour kit from RideNow Powersports. $337.50 shipped.
Here's the link if anyone else is interested. That was the best price I could find by about $50.
http://www.ridenow.com/product/detail/venTK.aspx
2006 Honda 919
