At the risk of ... - Wrist Twisters
post #1 of 14 Old 10-25-2007, 06:59 AM Thread Starter
Rider reborn
TheDarkness's Avatar
At the risk of ...
Beating this horse any further...
I have decided to upgrade my 03's non-adjustable front suspension. From what I have found, the most economical improvements are weight appropriate springs, and valve kit from RaceTech. This and a heavier fork oil should be a vast improvement. I am throwing this out there as a question to the tuning experts. I don't plan to race, just spirited commuting. Any help would be awesome. Also, how many hours in shop time should this take.. for billing purposes?
Thanks much.
Lex Talionis
TheDarkness is offline
post #2 of 14 Old 10-25-2007, 07:02 AM
Speed Lover
XRCajun's Avatar
What bike are we talking about here?
XRCajun is offline
post #3 of 14 Old 10-25-2007, 07:11 AM
There is a informative thread discussing the Race Tech internals. Unfortunately the link to project919 is no longer active. The OEM rear shock is waaaay over sprung, a Ohlins or Penske is needed to complete the package.
post #4 of 14 Old 10-25-2007, 07:20 AM
red dirt girl
Kristen's Avatar
Outstanding Restoration BOTM Donation Donation
Thanks much.
Ummm, isn't that what got you into trouble in the first place, "spirited commuting"?
Kristen is offline
post #5 of 14 Old 10-25-2007, 09:51 AM Thread Starter
Rider reborn
Lex Talionis
post #6 of 14 Old 10-25-2007, 10:47 AM
Heavy Metal
ratdog's Avatar
sigh...sad but true
old project 919 links that don't auto-convert to the archives can be found at forums.project919.com (hopefully) i dumped out all the porn/drug stuff that had accumulated...should be safe viewing these days
http://forums.project919.com/viewtop...179&highlight= should work, just not sure if it's the link you were thinking of...
ratdog is offline
post #7 of 14 Old 10-25-2007, 12:06 PM
I've been thinking of re-springing the front of my `04 this winter, also. 28k and the fork oil's never been changed.
I wonder if we could do a group buy?
Shouldn't be too hard to do ourselves. Maybe we could ge XRMikey to walk a bunch of us thru it.
post #8 of 14 Old 10-25-2007, 12:09 PM
Heavy Metal
ratdog's Avatar
Originally Posted by ratdog View Post
sigh...sad but true
oh wait..it's not
ratdog is offline
post #9 of 14 Old 10-25-2007, 12:36 PM Thread Starter
Rider reborn
that was while operating my station wagon... I have much better restraint now.
Lex Talionis
post #10 of 14 Old 10-25-2007, 12:38 PM Thread Starter
Rider reborn
Not a bad idea.
Lex Talionis
post #11 of 14 Old 10-25-2007, 04:29 PM
Corner speed sets u free
streakin919's Avatar
Well i can tell you from personal experience just changing the fork oil will make a noticeable difference. I change mine @ 15k, and it's getting about time to do it again. I'm thinking of cutting some aluminum rings to use for preload this time.
streakin919 is offline
post #12 of 14 Old 10-25-2007, 04:30 PM
Donation BOTM
Darkness - how deep do you want to go ? I had a guy here ( Jamie James to be exact ) in NC fix my Z1000 - we put adjusters on both sides , then dropped an Ohilins valve kit in each for and the replace the crappy stock shock with a tastey Ohilins unit - total was about $1800 parts and labor - you can get the valve kit and rear shock for like $1100 , if in not mistaken, as long as they havent raised prices in a few months.The coolest things about the Z was that I had a picture of Jamie riding wheelies on my bike after we went for a test ride and it was set up perfectly - it handled simply amazingly after they did the work and set my swing arm angles and such - well, worth the outlay of cash.
2ohno is offline
post #13 of 14 Old 10-25-2007, 05:43 PM
I have an `04, so I have the preload thing whipped going in.
You have to take the fork off, and take the top off, for a fork oil change, correct? If so, then 90% of the work is already done. At that point, we may as well change springs. I hear they're not too expensive.
I had my 929 re-done front and rear, and yes the transformation is amazing. I already have an Ohlins on the rear of the 919. Got lucky, bought mine used. Best $$$ I have spent on the 919.
post #14 of 14 Old 10-25-2007, 06:18 PM Thread Starter
Rider reborn
That is exactly the POINT!! I don't want to go way deep. I see value in what you have done, b/c you are so happy with it.
My issue happens to be my weight - 6' 215 - add leather and you got Heavy. Also, I bought this bike to put miles on it... I can't see spending 1/2 of what I payed for it -to replace the front forks. $500, I can live with... to keep the front end from bottoming out...
I reserve the right to change my mind on this and any other topic...
Thanks again, D
Lex Talionis
