anyone thought of a guage cluster swap? - Wrist Twisters
post #1 of 12 Old 09-28-2008, 10:49 AM Thread Starter
cjames235's Avatar
searched and couldnt even begin to find anything out
this is of course on a 919
i would freakin LOVE to swap out the cluster for a factory honda digital cluster from a cbr, but am unsure if all the signal voltages are the same..... if they are it would be as simple as mounting it and wiring it up
anyone have any info on the voltage ranges for any of the cbr sensors? anyone have a cbr and a multi-meter to check it out? it would only take a few minutes
thanks for any help
cjames235 is offline
post #2 of 12 Old 09-28-2008, 11:59 AM Thread Starter
cjames235's Avatar
if anyone cares, heres what ive gathered so far some of it may or may not be useful
----------------919----------------------cbr929rr
ECT (80C)------2.1-2.6kohm---------------2.1-2.6kohm
ECT (120C)----.62-.76kohm---------------.65-.73kkohm
RPM------------10.5V min.-----------------10.5V min.
SPEED-----------0-5V-----------------------0-5V
ECT is the same for both on low temp and at high temp they are still within range of each other so maybe they will be close enough to work
RPM not too sure about, it just says 10.5V min, but doesnt give any kind of range? not sure if they are the same or not..... im not sure if they both read off of one cyl. or all 4..... anyone know this?
SPEED is the one that is really questionable, they are both 0-5V but with one being digital and the other being a sweep type gauge im not sure they are interchangeable (unless the sweeper is a digital signal and not analog)
and of course the oil, cel, and fuel level are just dummy lights so they will just be wired directly into the new cluster
post #3 of 12 Old 09-28-2008, 12:02 PM Thread Starter
cjames235's Avatar
sorry if this is kind of rambling, im just looking for an alternative to the boring stock cluster
post #4 of 12 Old 09-28-2008, 06:46 PM
someone has done a gauge swap here, but I believe it was with an f4i?
post #5 of 12 Old 09-29-2008, 07:49 AM Thread Starter
cjames235's Avatar
link? ive been searching like crazy i would love to do it!
post #6 of 12 Old 09-29-2008, 07:55 AM
This should be the link you are looking for.
https://www.wristtwisters.com/forum/s...ad.php?t=15057
post #7 of 12 Old 09-29-2008, 08:59 AM Thread Starter
cjames235's Avatar
thanks for the link although that does help with wire colors, that is an aftermarket cluster. im trying to wire up and use a factory honda cluster from a cbr
post #8 of 12 Old 09-29-2008, 09:01 AM
Oh. Shoulda read more. Have you tried looking online for the manual of the bike it came off of?
post #9 of 12 Old 09-29-2008, 10:54 AM Thread Starter
cjames235's Avatar
yes..... the specs i posted above are straight from 929 and 919 service manuals, what im mainly concerned about is the speedo's..... if one is a digital signal and one is analog, then the signals wont work together
post #10 of 12 Old 09-29-2008, 11:44 AM
Curmudgeon
semi_gray's Avatar
I glanced at the title and thought for a second it was "anyone thought of a garage clutter swap?"
semi_gray is offline
post #11 of 12 Old 09-29-2008, 01:36 PM
btzung's Avatar
found it... try this:
https://www.wristtwisters.com/forum/s...ead.php?t=5945
the speedometer portion is compatible, the 919 has digital output.
btzung is offline
post #12 of 12 Old 09-29-2008, 04:34 PM Thread Starter
cjames235's Avatar
wow thanks! thats totally what i was looking for!........ now i need to find me a cluster (preferably one that doesnt rev to 14k hehe)
