Any cons to a centerstand? - Wrist Twisters
post #1 of 19 Old 09-29-2008, 01:08 PM Thread Starter
Ride Fast Take Chances
Karl's Avatar
I just bid on a 919 on ebay and it has a centerstand that I assume was installed at the dealer.
All the pics show the bike on the centerstand so I can't tell how far it sticks out when it is in the up position.
Anyone out there with a centerstand? Should I be concerned about it scraping in corners?
Any negatives to having the center stand?
thanks
Karl is offline
post #2 of 19 Old 09-29-2008, 01:18 PM
Praefectus Castrorum
brevity's Avatar
Do a search on 'centerstands' for more concrete info. Shouldn't get in the way of anything you want to do, even a track day, according to Nemo (methinks) and Robtharalson (meknows).
brevity is offline
post #3 of 19 Old 09-29-2008, 02:32 PM
Ken
Community Admin
Ken's Avatar
You should be fine as long as it's the OEM stand or the SW Motech stand (preferred) and it was installed properly. Many people favor using a rear stand rather than installing a centerstand, but you should be fine. It will make chain adjustments and rear wheel maintenance much easier.
2009 Honda Goldwing
Ken is offline
post #4 of 19 Old 09-29-2008, 02:53 PM
XRMIKEY scraped his sidestand yesterday on Glendora Mountain Road.
Impressive indeed!
Professional
post #5 of 19 Old 09-29-2008, 02:56 PM
Impressive indeed!
WOW, that's impressive! Never did mine! Did Mikey bring a pair of fresh underwear?
BTW love my SW motech CS for lubing the chain+other work, dirt parking and makes a smaller garage footprint.
dream is offline
post #6 of 19 Old 09-29-2008, 05:10 PM
BrokeRecord
I wouldn't trade mine for a washtub full of catfish fillets.
Best thing I did to mine.
brokerecord is offline
post #7 of 19 Old 09-29-2008, 05:28 PM
I, too, can recommend a centerstand for the 919. Mine is the Honda stand with the center section of the top cross-tube cut away to the width of the exhaust collector as per WT posts. If I'm touring, I install it with the springs and use it to lube the chain easily. If I'm riding locally, I remove it. I also use it for maintenance in the garage without the spring, sort of like a center/shop stand. Versatile and easy on-off. It takes like 30 seconds to install/remove without the spring, a minute with.
I like it.
Norton919 is offline
post #8 of 19 Old 09-29-2008, 08:05 PM
Serial Monogamist
ST-DocLizard1's Avatar
Total Awards: 21
After 35K, we don't leave home without it! It makes chain maintenance on the road a breeze when touring. Ours is the Hondaline.
Doc
ST-DocLizard1 is offline
post #9 of 19 Old 09-29-2008, 09:12 PM
Resident Viper Driver
919jockey's Avatar
I think the only con is people being green with envy because they wish they had one.
919jockey is offline
post #10 of 19 Old 09-29-2008, 09:45 PM
Where can you buy one of these amazing sounding things?
set126 is offline
post #11 of 19 Old 09-29-2008, 09:48 PM
per the question the only con is it prevents a CBR900R pipe conversion, but I decided against that.
dream is offline
post #12 of 19 Old 09-30-2008, 01:54 PM
Tonight we ride
Nemo's Avatar
I like it.
That's a mod I should consider! The one thing I don't like about my Hondaline 919 centerstand is the fact that it isn't removable, stock, unless you pull the exhaust headers.
I can, however, confirm that the Honda centerstand won't touch asphalt in a pretty serious lean; at the track in June and again yesterday, I was scraping pegs (with peg feelers removed) and my own boot toes, but not the centerstand.
Larger photo:
Nemo is offline
post #13 of 19 Old 09-30-2008, 02:04 PM
About 20 extra pounds hanging off your bike. My stand lives in my garage, I don't have the need to carry it with me at all times.
post #14 of 19 Old 09-30-2008, 03:49 PM
20 extra pounds (more like 12) that's all below the CG. If you can feel those 20 (12) LBS when actually riding, then you're either super-human or an extremely nit-picky guitar tech from SO.CAL.
Professional
post #15 of 19 Old 09-30-2008, 04:19 PM
Lol, I figured someone would let me know the actual weight of a centerstand. I'm all into the light thing though, so it's something even if it's not a lot. Same reason I can't bolt on a Corbin, picked one up and thought it felt like an anchor. Also just never felt the need for a centerstand since I have a couple of garage stands, but I can see how it might be handy if you needed to work on your bike away from home.
post #16 of 19 Old 09-30-2008, 07:45 PM
Nemo, good job.
Who made your suit?
post #17 of 19 Old 09-30-2008, 08:40 PM
i have to say i did the cbr900 pipe conversion and i love it.. awesome sound much less weight and a buttload more power... but then again thats my opinion and i could be wrong
post #18 of 19 Old 10-01-2008, 05:35 AM
I also have the 900rr conversion and I love it. But, that is not a reason to not get a bike with a centerstand. If you decide later to do the conversion you can always take the centerstand off.
timbo813 is offline
post #19 of 19 Old 10-01-2008, 11:08 AM
I Love Parallel Twins
Naked/SS's Avatar
A centerstand is a worthwhile investment in your bike.
JDubya
Harleyville, South Carolina
USA
Naked/SS is offline
