I was about to do the fender chop thing, until I had the whole "snow shovel" off and was amazed at how clean it looked just the way it was. I then just re-formed the original license plate mount with a vice so it would fit between the two plastic tabs that stick out from the tray (I didn't want to cut them off in case I wanted to put it back together), pulled the ecu tray down and lifted the ecu up so I could carefully drill a couple of holes in the back of the tray, found some bolts to fit and now I have my own homemade fender eliminator. If you want to see pics, let me know.
I took a similar approach. I actually put two new holes in my plate to mount to the original tabs. I then installed a few LEDs throught the bottom of my CA smoke tail light lense to work as my plate lamp. I was able to keep everything together so the bike could be put back to original condition. Wire connections and all.
Related Threads
678.5K posts
10.2K members
Since 2006
