Another rain day project... - Wrist Twisters
post #1 of 26 Old 05-19-2006, 05:18 AM Thread Starter
It was time to replace my integrated tail light bulbs with the Clear Alternatives LED tail light integrator. I have installed a few of these LED boards on other bikes, they are bright, well made, and turn round time from the manufacturer is excellent. Since I already had a clear lens and Triton EL-12 electronic flasher the board is all that I need to complete the project.
Clear Alternatives supplies everything needed as you can see from the photo. I would recommend buying their electronic flasher instead of using the supplied resistors.
post #2 of 26 Old 05-19-2006, 05:27 AM
If it keeps raining there you are going to be broke, heavily modded, and happy. Well, maybe not the happy part.
post #3 of 26 Old 05-19-2006, 05:30 AM Thread Starter
Funny, I was just thinking the same thing. This is it for awhile, yeah right!
post #4 of 26 Old 05-19-2006, 07:13 AM
Hey, have been thinking about doing this soon also. Let me know how it goes. Are the turn signals bright? I put some aftermarket external LEDs on and you can't see them during the day at all. I figure, if I am not going to get the daytime visibility that I probably should have, might as well go for the best looking by integrating it.
What is the advantage of the electronic flasher over the supplied resistors? Does it just slow it down more or is it more reliable? Thanks Mike, can't wait to see how it turns out.
blackbetty is offline
post #5 of 26 Old 05-19-2006, 07:26 AM Thread Starter
Trust me these LED's are bright. Take the time and count them if you like. The electronic flasher will function with aftermarket front blinkers as well. Also the resistors must be placed in a safe space otherwisie they could melt the plastic. They are rated at 5 ohms and 20 watts = hot!
post #6 of 26 Old 05-19-2006, 08:32 AM
Love Machine
awarble's Avatar
They are bright, check my website out too. I need to get some outdoor pics, all i have are inside my garage.....
Awarble,
07 Honda CBR600RR
My Site
awarble is offline
post #7 of 26 Old 05-19-2006, 10:34 AM Thread Starter
Done... I did not remove the left tail light socket, instead I drilled a couple of 1/8" holes in the outter edge of that socket and fed the yellow blinker light wires through them. Makes for a much neater installation and everything remains in place.
I will post a couples of pics. if and when the sun ever comes out. That way you can see what they look like in bright sunlight.
post #8 of 26 Old 05-19-2006, 10:49 AM
That would be great. If you haven't put everything back together yet, could you post a pic of the wiring installation? I would like to see what you mean by going around the side. The prob is that I already installed aftermarket blinkers and had to splice them in. I cut the clip off of the stock and spliced it onto the new blinkers so as to leave the bikes wiring alone.
post #9 of 26 Old 05-19-2006, 10:56 AM Thread Starter
I don't see any problem, the only splice you will need to do is the +12v from the stock blinker wires to the new yellow LED board blinker wires. Unfortunately everything has been buttoned up. It's real simple, trust me.
post #10 of 26 Old 05-19-2006, 11:17 AM
You think I would be able to keep my exsisting LED's that I'm kind of stuck with inplace and wire that light plate in series with them? I'll have to take some pics when I get home.
dadogs is offline
post #11 of 26 Old 05-19-2006, 11:21 AM Thread Starter
Whey you say LED's are you referring to the rear blinkers? If so Clear Alternatives sells a LED board just for tail/brake applications.
post #12 of 26 Old 05-19-2006, 11:42 AM
Yea, I installed some darn near flush mount LED's for rear blinkers when I did my fender eliminator and am kind of stuck with them since I had to drill my cowl to run the wires. Found out they are pretty much useless in daylight hours......
dadogs is offline
post #13 of 26 Old 05-20-2006, 06:56 AM Thread Starter
visibility test in bright sun
The sun finally came out this AM so I wheeled out the 919 and faced the LED tail lights directly into the sunshine. This would be the worst case scenario and IMO they look brighter than the stock filament type bulbs. You can judge for yourself.
post #14 of 26 Old 05-20-2006, 07:39 AM
Those look pretty sweet. Thanks for the pic. I am definitely going to do it as soon as I have some cash. The 919 was a moneypit of mods and upgrades. Now I have this cursed R6 that is like a match that keeps getting too close to my wallet. Already paid for the trackday so I had better get that thing running first. But the clear alternatives will be later this summer, I can feel it...
post #15 of 26 Old 05-22-2006, 07:02 PM
Love Machine
awarble's Avatar
Looking good Mike!!! And man hose bars look good two....
Awarble,
07 Honda CBR600RR
My Site
awarble is offline
post #16 of 26 Old 05-23-2006, 11:16 AM
Heavy Metal
ratdog's Avatar
after our man steve went the way off the woolly-mammoth, we haven't had an official 919 mod-whore...i suppose we could toss mike's hat into the ring, but i'm gonna need to see more...much more
ratdog is offline
post #17 of 26 Old 05-23-2006, 11:25 AM
BockHawk's Avatar
He has done 3 mods in the last couple weeks. At this rate, he'll pass me up in no time.
900RR exhaust w/ Yosh CF can
F4i forks/fender
PowerCommander
flapper mod (does this count)
custom fender eliminator (sheetmetal is cheaper than the CW piece)
turn signal taillight integrator
CA LED taillight pods
2002 919 40,000 miles
BockHawk is offline
post #18 of 26 Old 05-29-2006, 08:01 PM
What is this 'flapper' thing?
I looked at the CW thing too, nice but pricey. got any pics/details of yours?
CA LED taillight pods? That a different taillight altogether?
Kahuna is offline
post #19 of 26 Old 05-29-2006, 09:38 PM
Kahuna, go to http://www.919.org
then "mods"
then "flapper" mod
since you asked about the flapper mod, you will probaly find a bunch of information on that site that you did not know before.
misterjason is offline
post #20 of 26 Old 05-30-2006, 08:12 AM
I did the flapper mod on Saturday and then took the bike around the neighborhood... At first I noticed the growl early in the rpms, but mostly I noticed the front wheel get a hell of alot lighter in second gear than it did before.
Noticibly more pull! COOL!
ortonomics is offline
post #21 of 26 Old 05-30-2006, 08:18 AM
"Whose ABBA ZABBA?"
Where do they tell ya to mount those 20 watt resistors? You know, I wish I would have come up with the LED stuff.
General George S. Patton
post #22 of 26 Old 08-28-2006, 09:31 AM
Naked in Cheese Land
Anti-Shadows's Avatar
Mike - the Clear Alternative site lists the 03 919 - will that part fit the 02?
Anti-Shadows is offline
post #23 of 26 Old 08-28-2006, 09:53 AM
Mike - which Part number did you get? i'm sort of confused by the CA page. to get the LED board and a len - is it CTL-0047-IT
post #24 of 26 Old 08-28-2006, 10:18 AM
BockHawk's Avatar
They haven't made any changes to the taillight, it'll work on any 919.
BockHawk is offline
post #25 of 26 Old 08-28-2006, 10:42 AM
thanks bock
post #26 of 26 Old 08-28-2006, 02:17 PM Thread Starter
That's correct. The CTL-0047-IT consists of the intergrator board and your choice of colored or clear lens. I also reccomend their flasher which slows the blink rate down. I'm not to keen on the 20watt supplied resistors. They generate mucho heat.
Sportbike Lights is selling this exact kit on eBay for $84.99 with free shipping. This is a good price!!!
http://cgi.ebay.com/ebaymotors/99-06...QQcmdZViewItem
