Alternator output on late model 919 - Wrist Twisters
post #1 of 12 Old 12-11-2009, 09:52 AM Thread Starter
Can anyone with a service manual for late model 919, tell me what the manual lists as it output for the alternator? Adding electrical accessories to my 02 and don't think mine's going to have enough (380 listed). I thought as a last resort I could swap out mine for later one if the output has been significantly increase. Thanks all
rabbott is offline
post #2 of 12 Old 12-11-2009, 10:29 AM
Serial Monogamist
ST-DocLizard1's Avatar
Total Awards: 21
What are you trying to add? Mine is an '03 with a Gerbings jacket liner, Streetpilot 2610, JM2003CB, XM Radio, and a Sony Minidisc. No problems in 44K and I have the original battery on a tender with an in-service date of 02/04.
Doc
ST-DocLizard1 is offline
post #3 of 12 Old 12-11-2009, 10:55 AM Thread Starter
Doc
Hey doc, sounds like you've added pretty much what I have: 2610, Gerbings jacket, XM, but have heated grips as well. The last time I rode, my liner didn't seem to be putting out the heat that I remember when used on my Burgman 650 (550 output). My jacket and grips use 104w by themselves. Thanks for your comments.
rabbott is offline
post #4 of 12 Old 12-11-2009, 01:35 PM Thread Starter
Your steed
Doc
Your 9er looks good, apparently much of the same things that I've done, I used the Pelican bags for sides, and a Givi top case, Pelicans sturdy and cheap(ish) but a bit heavy. I'm always looking for next ex-motorcycle, but I can't find anything better than the niner so far. Doesn't do anything outstanding (IMO), but does everything very well and not expensive.
Ron
rabbott is offline
post #5 of 12 Old 12-12-2009, 10:00 AM
Serial Monogamist
Total Awards: 21
Could be that your grips are putting you over the edge especially at idle. I have used the Gerbings glove liners when necessary which is not very often. Both the jacket liner and glove liners are on a dual controller thermostat.
The last thing you want is to toast the battery and you know what goes next in line trying to keep up with the demand for more electrons.
Doc
post #6 of 12 Old 12-13-2009, 07:45 AM
rabbott, the 919 Shop Manual has minimal info in it.
Section 10 Alternator/Starter Clutch has zero electrical info.
Section 16 Battery/Charging System has a bit.
Page 16.2 says alternator output is 0.38 kW @ 5,000 RPM. (0.38 kW = 380 watts).
Page 16-8 says the check is to run the engine [email protected] 5,000 RPM with the headlight Hi Beam on and do a voltmeter check across the battery terminals. You should be in the range of 15.5 to 16.5 volts.
There is no info to speak of in the Common Service Manual, other that letting you see that the Alternator is a Permanent Magnet Type.
Hopefully this all helps you.
post #7 of 12 Old 12-13-2009, 10:17 AM
A little more info from MisterMike's Maintenance How-to page. May help if you are trying to decide how much available power there is for accessories.
Lighting Specifications:
0.38kW/5,000 rpm Alternator Capicity
184 total Watts with the high beam = 48.4% of the Alternator Capicity
243 total Watts with a dual 55/60W headlight system = 64.2% of the Alternator Capacity
60W Headlight-High beam
55W Headlight-Low beam
21W x 2 Brake lights
5W x 2 Tail lights
23W Front turn signal
8W x 2 Front running lights
21W Rear turn signal
5W License plate light
1.7W x3 Instrument lights
1.7W Turn signal indicator
post #8 of 12 Old 12-13-2009, 10:27 AM
Mister Mike has a ton of good stuff in his How-to.
post #9 of 12 Old 12-18-2009, 08:57 AM
All wattage figures assume a system voltage of 14 volts.
Alternator output listed as 380 watts @5,000 rpm. To the best of my knowledge this has not changed over the entire production run.
Constant loads:
Headlight ---- 55 watts (W).
Taillight ----- 10W (5W*2)
Front driving lights -- 16W
License ------ 5W
Instrument lights--- 5.1W (1.7W*3)
Instrument cluster -- ~10W
ECU --------- 16.8W
Fuel pump --- 20W
Ignition ------ 14W
Injectors ----- 14W Both ignition and injectors are pulsed loads, so this figure is an industry accepted figure extrapolated from # of coils / injectors times a constant.
Battery maintain / charge --- Too variable to give an accurate figure. As an average it's less than 5W for a fully charged battery at least 10 minutes into a cruise maintaining greater than 2,500 rpm. Stop and go traffic is another matter entirely.
Total -------- 166W
Intermittent loads:
Brake lights --- 42W
Turn signals ---- 36W (44W minus the 8W driving light that is off when turn signal operating)
High beam --- 5W (difference high to low beams)
Total --- 83W
Grand total of 250W worst case, leaving ~120W in reserve. This is, of course, assuming the engine is turning at least 5,000 rpm.
There you go.
robtharalson is online now
post #10 of 12 Old 02-15-2013, 11:24 PM
sytheii's Avatar
Hey quick question, rob, if you're around to anser, is the power output supposed to be 14v, or is it 13.8, or is there a variable range for voltage? assuming your regulator is working normally, what is the mean?
sytheii is offline
post #11 of 12 Old 02-16-2013, 08:35 AM
From the service manual
post #12 of 12 Old 02-16-2013, 12:50 PM
sytheii's Avatar
Damnit! I looked in mine but wasnt thurough enough. Thanks!
sytheii is offline
