9er quick turn throttle? - Wrist Twisters
post #1 of 20 Old 10-04-2010, 08:49 PM Thread Starter
arctic954's Avatar
.....have used an r6 throttle tube on a few bikes....
Anyone know of what works on the 919 for a quicker turn?
arctic954 is offline
post #2 of 20 Old 10-04-2010, 08:54 PM
Most likely any standard HRC throttle tube
post #3 of 20 Old 10-04-2010, 09:14 PM Thread Starter
arctic954's Avatar
Price? Distributor?
post #4 of 20 Old 10-04-2010, 09:20 PM
I stopped selling them about 6 months ago, but purely coincidentally I am expecting some more soon as a special order for a customer.
The issue will be the fact this will be somewhat trial & error... The HRC Throttle Tube alone may or may not do the job. It may also require the throttle housing and possibly longer lines too... Price would range from $50 to $130 depending on what parts are needed.
post #5 of 20 Old 10-04-2010, 09:28 PM
Blue919Guy's Avatar
I use the rizoma billet grips, and throttle turn was a little quicker. They come with a few cams to adjust it.
Blue919Guy is offline
post #6 of 20 Old 10-04-2010, 09:33 PM
Sounds like a solution right there
post #7 of 20 Old 10-05-2010, 07:30 AM Thread Starter
arctic954's Avatar
......few years back on TLZone/TLPlanet, there was a guy that use to make custom parts for the TL1000R.....
He also made a simple piece of plastic that you'd simply drop in the throttle house to change the cam size. One of those things that when I received it.....I thought....that's it?
post #8 of 20 Old 10-05-2010, 07:32 AM Thread Starter
arctic954's Avatar
I might just buy an R6 throttle tube and try it....... Heck, they're all for 7/8 bars with the same piece of lead at the end of the cable.....usually the only difference is the width of the throttle cam.
The R6 throttle tube is $15 from a dealer.
post #9 of 20 Old 10-05-2010, 07:46 AM Thread Starter
arctic954's Avatar
.....I digress, looks like both the R1 and the '06 R6 tubes are the keepers. With the R1 tube being even less of a turn....ones 1/6th, the other is 1/5th.
I happen to still have an R1 throttle tube sitting on my bench......I'll take everything apart tonight and post up the results.
Btw - here is a link to a guy talking about using the R6 tube on a z1000.
http://www.riderforums.com/showthread.php?t=41625
post #10 of 20 Old 10-05-2010, 04:42 PM
I have the Rizomas as well, but I could only get one cam to fit. Didn't pay attention to throttle turn after the change though, sorry
Sure do love the grips though!
post #11 of 20 Old 10-06-2010, 05:17 PM
Tire abuser
prtsimmons's Avatar
You want a Tamer Throttle from G2 Ergonomics. G2 Ergonomics - Motorcycle Throttles Tubes
I used to work at a shop that sold them. You can change the cam on the throttle to have a quicker throttle, or a much quicker throttle, or fast off the bottom with slow throttle for the last 1/4 of the turn - they are much more sophisticated than a simple quicker throttle. They really improved a lot of bikes with jerky power curves (i.e., KTM 950 Adventure, 2-stroke dirtbikes). Good quality, well engineered, made in USA, what more could you want?
prtsimmons is offline
post #12 of 20 Old 10-06-2010, 07:58 PM
ok i'm missing something here. can someone explain to me how a quicker throttle turn can improve twitchy throttle responses? my best impression for improving said issue was to adjust the air/fuel mixtures throughout the rpm range. on the 919, this is done via a PC3 and i have to say, it works. my current 919 with no PC3 is VERY jerky and twitchy whereas my other 919 that had the PC3 was much smoother in throttle response.
post #13 of 20 Old 10-06-2010, 08:17 PM
My 919 is twitchy even with a PCIII. It is the thing that bothers me the most about the 919.
The G2 throttle tamer is just that...a TAMER... it is the opposite of a quick turn. It is slow initially then eventually goes back to stock depending on the cam profile. G2 does make quick turns, they are the ones called "quick turn." I have my eye on one for my WR250X
Bryce919er is offline
post #14 of 20 Old 10-07-2010, 08:11 AM
An unsynch'd PCIII with a standard PCIII does not yield ideal results, especially if the typically excessive 919 throttle cable slack has not been adjusted out.
Have you synch'd the PCIII to the ECU Throttle Positioner ?
What map are you using ?
What are you running for exhaust ?
Mine was a nightmare in slow stop and go traffic before the PCIII etc. It was like an on off switch below 2500 RPM is stop and go traffic and first gear crawling. Now I have excellent throttle control down to below 1,000 RPM. You should not be having the excessive twitchiness you are experiencing.
post #15 of 20 Old 10-07-2010, 06:04 PM
I don't follow that line...
But on the rest, yes cables adjusted the slack out before the PCIII.
I did the open/closed set throttle thing on the PCIII with a computer hooked up.
LDH's Sato2 map with gen II Satos, flapper mod, noothing else.
I have not ridden a stock 919 in 6+ years so I can't say or remember if it is improved over stock but I think there is still room for improvement.
post #16 of 20 Old 10-07-2010, 06:10 PM
Hmmmm, LDH does really sharp mapping work, so it's not the map.
You have the cable slack out.
You've synch'd.
And you still have the on/off twitchy snatchiness.
I don't know what to say. I can walk mine down to less than 1000 RPM underload and have perfect throttle control and don't even need a dab of clutch. (Yosh TRSs with a map very similar to LDH's Version 4 Moriwaki based map)
Do you have stock front springs by chance ?
They are soooooooo light, that could be part of it, if not the major part of what you are dealing with.
post #17 of 20 Old 10-07-2010, 06:26 PM
You've synch'd.
Could you elaborate on this and post # 14 a little more please. I have a pcIII but have not installed it yet( waiting for winter). I'm very curious about your comment on the springs, I'm planning on fork work soon and have an Ohlins shock to install too.
post #18 of 20 Old 10-07-2010, 07:28 PM
Pleased to.
With the stock front as softly sprung as it is, it doesn't take much to get it diving. Once you get it diving and give it chance to unload, it'll spring right back up. Imagine your throttle as an on off kill switch. Each "off" will engine brake dive the front end. The subsequent "on" will spring it back up. If you have poor mapping down low, worse yet with too much throttle slack, and find yourself having to continually play the throttle back and forth, the front end gets going up and down. This is first hand experience speaking, not theoretical imagination and maybe you have experienced it too. Stock 919 mapping sucks. The base map loaded into the PCIII is not very good either. Bad mapping = bad fueling = poor combustion = fluctuating engine output. I found the stock map and the PCIII map to be poor, stock was worse. At 2500 and lower RPMs and small throttle openings with a 1/3 to 1/2 temp gauge condition, the throttle was like an on /off switch. It literally bucked on me. Roll off in 1st gear slow traffic and it dived, crack it open a bit and it jumped and rose. I learned to soften it with some clutch slippage. Ok, so you want a good map, those can be had for free off this site, and that will get you in the zone map wise if all you have is the basic PCIII map in your new PCIII. But mapping alone is not enough. Unless the map is perfectly synchronized with the factory ECU's throttle positioner, things won't be happening at the correct time. Here's why. The map is a two axis co-ordinate based map that relies on specific combinations of RPM and % throttle opening. For example, one co-ordinate is a 2 % Throttle Opening x 1750 RPM point, at which the ECU will signal the fuel injectors to be open for a certain and very precise duration in order to deliver a set amount of gasoline. Then you install a PCIIIusb with some map in it. The PCIIIusb piggybacks on the ECU and alters the ECU's map by whatever the difference is between the PCIII map and the map in the ECU. BUT if the PCIII is not synch'd to the ECU, then the PCIII map adjustment will be shifted from the correct co-ordinates. Imagine this. The bike is at 2 % Throttle Opening and 1750 RPM, but the PCIII is out of phase by + 3 % re Throttle Position. The result will be that the ECU will get a PCIII instruction that is actually for a 5 % Throttle Opening position, even though the bike truly is only at 2 %. The fuel injectors will be told to stay open too long, and will deliver too much gasoline. It will run rich, and could bog. Of course, the opposite scenario can also occur. This is why you have to synchronize the PCIIIusb to the bikes Throttle Positioner.
Is the above what you are looking for ?
If not, just say what else you are looking for and I'll do my best.
I've also redone my front end, 0.925 kg/mm springs, and revalved, all towards heavy track day useage. The stiffer front end has also helped.
If you want more info on the Throttle Synching, I have put together a canned package of info that I've sent to others. There's maps included, as well as some map comparisons. Just send me a PM with an e mail address that can accept attachments, and I'll send it your way.
post #19 of 20 Old 10-08-2010, 05:36 PM
Thanks, PM sent. This helps alot, all this is new to me. I'm planning to do springs and possibly valving over the winter, I agree with your observation of the up & down in the front at slower speeds, I've felt it a few times...
post #20 of 20 Old 10-08-2010, 07:55 PM
Yes I do have stock suspension (but an 04 rear shock).
