929 or 954 engines will not swap in - Wrist Twisters
post #1 of 11 Old 09-09-2007, 04:12 PM Thread Starter
Trackday Recognition Donation
Not without serious alterations anyway.
The swingarms of those two bikes bolt to the rear of the engines. That large protrusion will interfere with the 919's backbone-style frame.
The 900rr engine mounts similarly to the 919 but there'd be no significant power gain and therefore no point.
I'm working on something else and hopefully will have something to show for it in another week or two.
gpzTurbo is offline
post #2 of 11 Old 09-09-2007, 07:22 PM
royalchoppers's Avatar
Sweet. Can't wait to see.
One could always remove a portion of the lower backbone to use the engine swingarm mount of the 929 or 954. Hmmmm, food for thought.
royalchoppers is offline
post #3 of 11 Old 09-09-2007, 07:28 PM Thread Starter
My machinist/fabricator friend always says, "The impossible takes 15 minutes longer."
I don't want to chop this one. I'll change it but it will be able to go back to original easily enough.
gpzTurbo is offline
post #4 of 11 Old 09-09-2007, 07:47 PM
Speed Lover
XRCajun's Avatar
Inquiring minds want to know?
XRCajun is offline
post #5 of 11 Old 09-09-2007, 08:41 PM Thread Starter
Patience, Grasshopper
gpzTurbo is offline
post #6 of 11 Old 09-10-2007, 01:18 PM
drivit's Avatar
all i want is to get the 4 individual 929 coils to work. in need an ecm genius opinion......
drivit is offline
post #7 of 11 Old 09-10-2007, 01:30 PM Thread Starter
why? what else have you done to it?
gpzTurbo is offline
post #8 of 11 Old 09-11-2007, 03:21 AM
drivit's Avatar
i'm working on pictures..........not easy for me.
i want a HID headlight.
i need the room under the tank where the coils are
for the ballast and control module
no room out back, pictures will explain
besides, someone said it can't be done.
drivit is offline
post #9 of 11 Old 09-11-2007, 06:44 AM
<no room>
CBR 900RR head & throttle botties on the 919 lower?
Bryce919er is offline
post #10 of 11 Old 09-11-2007, 07:13 AM Thread Starter
I read the valve sizes are the same in the two heads. The cams might be different but I've heard mixed reviews about swapping those.
The coils probably can't be done because the pickups would have to be completely different, right? Not just an ecu swap.
HID headlight? That won't make it go faster! j/k
gpzTurbo is offline
post #11 of 11 Old 09-13-2007, 04:50 AM
drivit's Avatar
i think there's only 1 pickup, my guess is to bypass-only the ignition controls in the 919 ECM and run the 929 ECM ignition instead-how's that for dreaming.
drivit is offline
