919 suspension - what are your settings? - Wrist Twisters
post #1 of 39 Old 06-05-2006, 11:19 AM Thread Starter
Just wondering what other 9ers are running their preload and rebound settings at?
mudarra is offline
post #2 of 39 Old 06-05-2006, 11:28 AM
Sweepuk
Guest
Posts: n/a
3 rings showing on front- forks through yokes 6mm and next to softest on rear - I am 13 stone and it seems good to me for my riding.
post #3 of 39 Old 06-05-2006, 11:58 AM
Haha... you said stone. (<--Ignorant American. I have no idea what stone is... )
ortonomics is offline
post #4 of 39 Old 06-05-2006, 02:23 PM
Sweepuk
Guest
Posts: n/a
Sorry I am about 80 kgs - 82 Kgs not a porker but not skinny either
post #5 of 39 Old 06-05-2006, 02:37 PM Thread Starter
www.megaconverter.com
Perfect for us ignorant Americans!
mudarra is offline
post #6 of 39 Old 06-05-2006, 03:53 PM
Hmmm... kilograms probably won't help an american out either
bigassbertha is offline
post #7 of 39 Old 06-05-2006, 03:55 PM
tomvan72
Guest
Posts: n/a
I just set my set up to "fast". It seems to corner well there!
Actually I use about 30mm of sag both front and rear.
post #8 of 39 Old 06-05-2006, 04:12 PM
Suspension settings will vary depending on how many stones you weigh. 30mm is a good number to shot for.
post #9 of 39 Old 06-05-2006, 04:25 PM
goodhorsey's Avatar
yea, m51142's stone is about 30mm.
goodhorsey is offline
post #10 of 39 Old 06-05-2006, 04:26 PM
BockHawk's Avatar
uhh...does that even make sense?
2002 919 40,000 miles
BockHawk is offline
post #11 of 39 Old 06-05-2006, 04:29 PM
goodhorsey's Avatar
probably not. it just sounded funny to me at the time, what with all the confusion about stone, millimeters, etc.
post #12 of 39 Old 06-05-2006, 04:45 PM
I dont even want to know how you know anything about his "stones"
post #13 of 39 Old 06-05-2006, 05:09 PM
goodhorsey's Avatar
you had to go there, didn't you....
post #14 of 39 Old 06-05-2006, 07:02 PM
Of course, but it sounds like you were there first, LOL J/K
post #15 of 39 Old 06-05-2006, 08:08 PM
919 City Pilot
Pegjumpflyer's Avatar
rear all the way hard, front dropped 7mm. 160 lbs on a 03
Pegjumpflyer is offline
post #16 of 39 Old 06-05-2006, 08:40 PM
BockHawk's Avatar
If your preset on the rear is maxed you're actually losing traction. Especially if you only weigh 160. If you were like 300, you'd be golden.
BockHawk is offline
post #17 of 39 Old 06-05-2006, 08:40 PM
For us metrically challenged Americans a kilogram is about 2.2 lbs so that makes our English friend around 176 - 180 pounds.
JAX'9er is offline
post #18 of 39 Old 06-05-2006, 09:35 PM
DropBear 9
Guest
Posts: n/a
Nice little freeware converter.
http://joshmadison.net/software/convert/
Using forums based in the U.S. as well as the U.K means this little utility is mandatory.
You're all stuck in the stone ages. (pun partially intended) no disrespect however.
:euro:
I'm in Oz so we're pretty much metric (21st century) all the way.
Me, I'm 75 kilos, (11.8 stone, or 165 pounds) I have the rear pre-load set to softest, rebound half turn up from stock.
Front pre-load set to 3rd mark from top, rebound up half a turn. (mine's an '05)
Still tryin' a few things though as I've just fitted a new Pilot Power to the rear and I make no claim to being a test rider.
Feels good to me though!
post #19 of 39 Old 03-18-2007, 07:08 PM
Unbannable
Super Sneaky Steve's Avatar
Just in case no one has tried. I took my rear shock from a 2 (stock position) down to the softest 1 setting and it cured that annoying butt thumping going over small joints in the road.
It made a bigger differance than I thought it would.
Super Sneaky Steve is offline
post #20 of 39 Old 03-18-2007, 08:50 PM
ajcombs's Avatar
Helping a Member in Need
I'm a 200# dude and have my front showing about 3-4 rings and two turns from full hard then my rear is set preload adjustment one from full up and then half turn from full hard. the preload gets me about 35-40 mm sag set with a friend helping me. I don't have the road thump that SSS is talking about and wonder if previous owner had shock work done??
ajcombs is offline
post #21 of 39 Old 03-18-2007, 10:58 PM
settings... what is this settings you speak of... my 02 got no settings..
Mitch
'83 Suzuki GS750E
'02 Honda 919
Roseknight is offline
post #22 of 39 Old 03-19-2007, 05:38 AM
BockHawk's Avatar
You've got preload in the rear shock, and that's...uh...well, that's it.
BockHawk is offline
post #23 of 39 Old 03-19-2007, 05:51 AM
Not exactly.
post #24 of 39 Old 03-19-2007, 05:54 AM
BockHawk's Avatar
Okay, so for the more enterprising among us (like Mike), you can go the preload spacer route on the front forks. I stand corrected.
BockHawk is offline
post #25 of 39 Old 03-19-2007, 06:06 AM
Eternal Novice
supersoldier71's Avatar
Uhmmmm...I'm very new so I have no idea what I'm supposed to be doing to my suspension. I weigh 103.6kg, what's that mean for my 919?
Live free or die!
supersoldier71 is offline
post #26 of 39 Old 03-19-2007, 06:31 AM
This informative article should be helpful. Link
post #27 of 39 Old 03-19-2007, 08:22 AM
Eternal Novice
Enormously helpful. Thanks.
Live free or die!
post #28 of 39 Old 03-19-2007, 08:36 AM
yes Brock and mistermike.. I know.. and my rear is set to second to hardest setting on the rear.. though I havent done anything to the front (unless previous owner did something)... I was being a smarta$$..
Mitch
'83 Suzuki GS750E
'02 Honda 919
post #29 of 39 Old 03-19-2007, 08:38 AM
BockHawk's Avatar
I know, I was doing the same.
BockHawk is offline
post #30 of 39 Old 03-19-2007, 08:41 AM
Mitch
'83 Suzuki GS750E
'02 Honda 919
post #31 of 39 Old 03-19-2007, 11:17 AM
I bought the '02 bike with progressive springs already installed and it feels better than my Fireblade with stock suspension.
CRXnut is offline
post #32 of 39 Old 03-19-2007, 11:36 AM
On front, I have 5 rings showing, the little dot on the rebound damping is at the 3 o clock position. I weigh about 175, have Power Pilots with 32 lbs cold pressure in them. I have a used Ohlins on back, it was set up for a 160 lb rider. I backed out both comp and rebound either a quarter or half a turn, can't remember... Got rid of the chicken stripe on the back last Sunday. Very stable in the corners. I'll push it a little harder when the roads warm up, but so far so good.
post #33 of 39 Old 03-19-2007, 12:17 PM
chicken stripe ?
CRXnut is offline
post #34 of 39 Old 03-19-2007, 12:53 PM
put your ad here
4manhilt's Avatar
i remember someone suggesting a chart based on rider weight and typical riding style/venue. this chart (if only for the unmoded adjustable 919 suspension) should be easy for one of the suspension gurus to make. shortcomings of this model aside, i think it would get most riders close enough for day to day riding.
Most problems in life can be fixed... Stupid isn't one of em'.
4manhilt is offline
post #35 of 39 Old 03-19-2007, 02:40 PM
Nick's Avatar
I weigh about 175 and have my preload maxed out on both ends. That gets me in the 30mm range for sag. I get extra ground clearance and don't care about expansion joints on the freeway.
Nick is offline
post #36 of 39 Old 03-19-2007, 04:44 PM
Originally Posted by CRXnut View Post
chicken stripe ?
Link, and disregard the second definition.
motorwerks919 is offline
post #37 of 39 Old 03-20-2007, 09:25 AM
chicklen stripe is the unused portion of your tire
post #38 of 39 Old 03-20-2007, 09:26 AM
BockHawk's Avatar
That is, of course, if you have an unused portion of your tire
BockHawk is offline
post #39 of 39 Old 03-20-2007, 11:34 AM
Ha ha, that's great. Since I have never heard the term before you can imagine how wide mine is :-)
CRXnut is offline
