919 Maintenance Time - Wrist Twisters
post #1 of 15 Old 06-20-2007, 08:06 AM Thread Starter
919, CRF250X, LC4, CB400F
ndcent's Avatar
Ok...well I've just put 10K of my own miles on my 9er, pushing her to about 16k miles...
So what now?
Valve check/adjustment?
New chain/sprockets?
Oil change while it's being serviced of course.
Uhh...tune up of sorts?
What am I missing here guys? I'm not super into the maintenance aspect of things (aka I don't do this type of work myself I have a licensed mechanic/friend do it) although I do know they require some dollars to keep them in good running shape...any help is appreciated.
ndcent is offline
post #2 of 15 Old 06-20-2007, 09:37 AM
Air filter been changed?
post #3 of 15 Old 06-20-2007, 10:07 AM
Hola Como Estas?
ramrod's Avatar
Aren't valve checks done @ 16,000 miles?
ramrod is offline
post #4 of 15 Old 06-20-2007, 11:31 AM
I'm in about the same boat and almost made the same post last week. I checked my air filter and it looks clean. Time for plugs I think. Valves need an inspection. When I get home I'll scan the maintenance page from the manual and put it up.
David
djs_tx is offline
post #5 of 15 Old 06-20-2007, 12:32 PM Thread Starter
ndcent's Avatar
Thanks for the replies...any further suggestions are appreciated!
ndcent is offline
post #6 of 15 Old 06-20-2007, 01:29 PM
BockHawk's Avatar
Don't forget to check for loose bolts and nuts. It also wouldn't hurt to check your wheel and steering stem bearings.
2002 919 40,000 miles
BockHawk is offline
post #7 of 15 Old 06-20-2007, 01:33 PM
Wookie
ragdoll's Avatar
Honda Maintenance? I plan on doing my 16,000 mile checkup at 32,000 miles just to be safe
'02 RC-51
'10 Unicycle
ragdoll is offline
post #8 of 15 Old 06-20-2007, 02:37 PM
Hola Como Estas?
ramrod's Avatar
My bad, guess I skipped over that.
ramrod is offline
post #9 of 15 Old 06-20-2007, 02:51 PM Thread Starter
ndcent's Avatar
Ya know, I'd like to do the same. But I've always thought a little preventative maintenance is better than none.
ndcent is offline
post #10 of 15 Old 06-20-2007, 03:29 PM
Trackday Recognition Donation
Don't forget the nitrous bottle......
gpzTurbo is offline
post #11 of 15 Old 07-13-2007, 01:07 PM
bucky's Avatar
I never do ! (see attached)
bucky is offline
post #12 of 15 Old 07-13-2007, 06:09 PM
The Tinman rocks...
post #13 of 15 Old 07-13-2007, 06:13 PM
that is impressive ! what that pan is for ?? did you use drag bars or how you keep it from raising front?
serge is offline
post #14 of 15 Old 07-13-2007, 06:19 PM
+1
serge is offline
post #15 of 15 Old 07-13-2007, 11:28 PM
Go'n So slow I'm stopped
xrmikey's Avatar
You can increase your Maintenance intervals by putting steel plates under your seat too.
xrmikey is offline
