919 handling tip of the week... - Wrist Twisters
post #1 of 23 Old 05-07-2006, 03:17 PM Thread Starter
For those of you that ride the twisties or get involved with track days. Try bumping up the forks 10 mm in the triple clamps. This mod. which reduces the trail will allow your bike to turn in faster without compromising the stability. It's fast, easy to do, and if you don't like results just return them to the stock position.
I would like to hear some feedback from those of your that try this mod.
post #2 of 23 Old 05-10-2006, 08:39 AM Thread Starter
Hummm... 73 views and no repiles? Track day junkies; anyone??
post #3 of 23 Old 05-10-2006, 09:07 AM
tomvan72
Guest
Posts: n/a
I did this to mine a few months. I am not sure if I went 10mm or not. I think just 5mm. It did make a little difference but i have not tried any more. Maybe I will nexttime I am in the garge.
post #4 of 23 Old 05-10-2006, 09:25 AM
I am doing it next week before I head out to Deal's Gap. I'll let you know my thoughts afterward.
blackbetty is offline
post #5 of 23 Old 05-10-2006, 09:30 AM
tomvan72
Guest
Posts: n/a
I am living in very similar terrain as Deals. I have found that in the stock setting I am much quicker on the down hill portions than on th up hill. The front end pushes more going up. Make this adjustment has helped for sure. I will try going a littl farther. How much is too much?
post #6 of 23 Old 05-10-2006, 09:34 AM
BockHawk's Avatar
Go about 120mph, if it gets scary wobbly, it's too much. j/k!
2002 919 40,000 miles
BockHawk is offline
post #7 of 23 Old 05-10-2006, 09:50 AM Thread Starter
Your're not too far off the mark, too little trail and the dreaded "tankslapper" could rear its ugly head.
That said; how much is too much? Two problems could occur. Scary handling as mentioned and mechanical limitations. Unfortunately when my fork springs were being changed out for Ohlins I failed to measure the physical interference distance with the forks completely compressed.
10 mm is no problem. Beyond that you are on your own!
post #8 of 23 Old 05-10-2006, 10:12 AM
tomvan72
Guest
Posts: n/a
That is what i meant!
post #9 of 23 Old 05-10-2006, 08:15 PM
Hmm... would you advise this for RC51 forks as well?
Kidding. If I go any lower I'll probably be tankslapping at 90.
bigassbertha is offline
post #10 of 23 Old 05-16-2006, 09:32 AM
tomvan72
Guest
Posts: n/a
So I went from 5 mm to 10mm and what a difference. You guys should give a try. Free mods rule!
post #11 of 23 Old 05-16-2006, 09:43 AM Thread Starter
I hope more 919 riders try this mod. It really makes a difference.
post #12 of 23 Old 05-16-2006, 09:50 AM
Hey Mike, if I am riding from chicago to jersey to the gap, would you recommend doing it for the whole trip or waiting till i get there? In other words, what effect will it have for the straights. I plan on avoiding highways at all costs but some are inevitable. thanks
post #13 of 23 Old 05-16-2006, 09:55 AM Thread Starter
Bump those forks up before the trip. Straight line high speed stability will not be compromized.
post #14 of 23 Old 05-16-2006, 10:01 AM
tomvan72
Guest
Posts: n/a
I think my bike is more stable across the board. At least from the feel of things.
post #15 of 23 Old 05-17-2006, 06:06 AM
I tried this last night. Wow, it really seemed to make a difference. I went about 7mm and it is now much easier to initiate turns. Thanks a lot for the tip.
timbo813 is offline
post #16 of 23 Old 05-17-2006, 09:24 AM
The Guy passing you...
Evad101's Avatar
Donation Donation BOTM Donation
Well this depends, have you first installed 10mm preload spacers? That should be the first thing you do. The RC comes stock with -5mm preload. You add the 10mm spacer and it takes you to a +5mm preload. This will raise the front end up but allow you to actually set your SAG correctly. With the front end raised your turn in will be much slower.
Next question: Have you raised the rear end of your bike? Yes? How much? Did you do it it with an afer market shock that has a ride height adustment or did you use shims? Roughly 5mm adjustment will give you about 15mm at the rear axle. This will make a difference in the front end.
On my RC I have stiffer springs, plus the 10mm preload spacers. This allowed me to set the SAG correctly. I have a Penske shock in the back end with a ride height adjustment to which I lengthend the shock 5mm over the stock length. My bike now sits higher than normal. The turn in my bike is not twitchy at all but not slow either and it is rock solid stable in the turns. Take your time and get the suspension set up on it and it will reward you greatly!
-Dave
Evad101 is offline
post #17 of 23 Old 05-17-2006, 09:29 AM Thread Starter
Dave- bigass is playing with us. He has the RC51 forks on a 919.
post #18 of 23 Old 05-17-2006, 09:39 AM
BockHawk's Avatar
Hook, line, and sinker.
BockHawk is offline
post #19 of 23 Old 05-17-2006, 02:52 PM
Evad101's Avatar
... Nice!
-Dave
Evad101 is offline
post #20 of 23 Old 05-17-2006, 07:06 PM
Yeah, sorry. Not accustomed to non-919 owners in the predominately 919 forums. Suppose I should clarify from now on
post #21 of 23 Old 05-17-2006, 07:27 PM
Evad101's Avatar
Nah thats cool. I dont look in the forums really, I just look at the "today's Posts" nadn go from there.
-Dave
Evad101 is offline
post #22 of 23 Old 07-15-2006, 04:42 PM
I know a old post. but I done mine today. I havent got to ride it but i bumped it 11mm. I forgot how much this post said to go. I would think 1mm more wouldnt do any harm would it?
psdavidson is offline
post #23 of 23 Old 07-15-2006, 04:56 PM
The original post said 10mm. That's what I did to mine, and it's worked out great, especially since shortening the chain.
Use 11mm or above at your own risk. Just check clearance first, which can be hard to do without loading the front forks.
