919 engine mods - Wrist Twisters
post #1 of 10 Old 04-16-2006, 11:52 AM
cbx1260cc
Guest
Posts: n/a
919 engine mods
I'm new to the board but trying to get info from someone who may have already travelled this road.
Firstly if one wanted to improve the engine performance of their 919 and wanted to go Deeper than just a set of slip ons and a Power Commander what would there be available to do?
Are full exhaust available? If so from who?
Piston kits? If so from who and how big? Taking this a step further has anyone done or even considered doing a 954 engine swap? I do realise that the 954 has a MUCH bigger radiator and this may be necessary to keep the extra heat under control but back to the original question of ---has anyone done this swap? If so problems/ results etc etc.
Please tell me what your experiences have been and share with all of us.
Thankyou
Ricardo cbx1260cc
post #2 of 10 Old 04-16-2006, 07:17 PM
Heavy Metal
ratdog's Avatar
forget any swap
NOS - 15 seconds of happiness, the rest of the day, same old same old
cams - maybe +5 up top
945cc big bore
970cc big bore (re-sleeve)
gonna do the big bore kit? might as well do the rest of the fun stuff at the same time...
or fighter out a 1000rr
or wait for the 07's
ratdog is offline
post #3 of 10 Old 04-16-2006, 07:24 PM
cbx1260cc
Guest
Posts: n/a
919 engine mods
Ratdog,
Thanks for the reply--But why do you feel it wouldn't be a good idea to do an engine swap? Surely the big bore kit, cams etc would cost more than just finding a used 954 motor and swapping it out. Would seem to me to be the least expensive mode of operation. I do remember the MUCH bigger radiator for the 954 motor but if one were to go to 970cc big bore wouldn't the same problems with heat dissipation be an issue??
Please expand upon your thinking.
One last question--is there something SPECIAL happpening for 07?
Thanks
post #4 of 10 Old 04-16-2006, 07:55 PM
Heavy Metal
ratdog's Avatar
it's not a direct swap...and grafting bits ain't a piece of cake either
swappin radiators isn't a big deal, couple other things need to be swapped as well...
check out alexa's bike or read up on hornet 970's efforts, maybe check out the writeup on the Erion Project 919 bike or Jin's 12+month nightmare...it's all available in the archives of the well known 919 sites
there are a few full 919 exhaust systems available including the new borla system honda919rider is using
2007? Year of the Red
ratdog is offline
post #5 of 10 Old 04-17-2006, 08:09 AM
BockHawk's Avatar
Update to Jin's nightmare: turns out the vacuum hose diagram in the Honda manual was wrong, which caused the problem. He's riding once again!
I'm with ratdog on this one, go with the big bore kit and some cams...or buy an FZ1
Okay, so I was joking about the FZ1 bit.
2002 919 40,000 miles
BockHawk is offline
post #6 of 10 Old 04-17-2006, 09:38 AM
"Whose ABBA ZABBA?"
I like the turbo approach, but I don't know what's out there for the Hornet. On a naked bike, the turbo would be awe inspiring! Course, it may prove to be kinda overkill.
Custom paint job.......
TURBO HORNET
Then you could justify grafting a big 954 radiator to your new stud.
General George S. Patton
post #7 of 10 Old 04-17-2006, 11:03 AM
Heavy Metal
ratdog's Avatar
turbo options?
talk to honda919rider...there's some stuff out there for the old 900rr that could be adapted by an intrepid few
would be the mutts nutts...
ratdog is offline
post #8 of 10 Old 04-17-2006, 11:07 AM
Talk about a bitch tryin' to keep the front wheel down when the boost comes on!
dadogs is offline
post #9 of 10 Old 06-06-2009, 10:06 AM
bwoso's Avatar
Which engine parts are a direct swap with a 900RR, and how much of the sleeve is left after the 945 bore. The sleeve doesn't seem to be that thick, and I think taking .5mm off of each side would possible cause some issues. Are the 919 connecting rods the same as the 900RR? I'm thinking about some forged pistons, stronger rods, stronger head bolts, ignition retard, and some more boost.
bwoso is offline
post #10 of 10 Old 06-07-2009, 11:48 PM
CB900
rockdog32's Avatar
The 919 is a great bike, but not really one for tricking up. The best increases I've seen in HP are like 12-15 tops, which isn't really a great deal. It's more of a bling it up and make it sound better bike except for the turbo kit or nitrous which would dramatically increase HP probably at the expense of engine life.
If you want a real quick naked bike, go a B-King or a Duc Streetfighter, or naked up a CBR or R1.
I wish there were more options, but the bike has been built to get pretty much all it can out of its overall package already.
rockdog32 is offline
