919 Clutch Cover - Wrist Twisters
post #1 of 6 Old 10-26-2006, 04:37 PM Thread Starter
joeer77's Avatar
919 Clutch Cover
Does anyone know the torque spec for the three clutch cover hex head bolts on a 06 919? Need to replace cover after a dump. Thanks.
joeer77 is offline
post #2 of 6 Old 10-26-2006, 04:57 PM
I am looking through the service manual, and it doesn't even show taking the clutch cover off the right crankcase cover or torque values for installing the right crankcase cover. I say make sure they are good and tight. That is what I did when I replaced my alternator cover. Haven't had any problems.
post #3 of 6 Old 10-26-2006, 05:01 PM
Church of the Holy Smoke
MotoCycho's Avatar
I too can't find a specific torque for these bolts.. but the service manual says this for each size crankcase bolts:
10mm - 29 lbf-ft
8mm - 17
6mm - 9
not sure what "lbf" is...
Oh.. those are 6mm if I remember right.
BTW.. if the scratches are not too deep.. you can sand the scratches right out of the cover or fill them.. and then repaint.
- Rev. CYCHO -
MotoCycho is offline
post #4 of 6 Old 10-26-2006, 05:15 PM
Guess I didn't look close enough.
post #5 of 6 Old 10-26-2006, 05:54 PM
Honda Addict
razorbike's Avatar
Since the clutch cover isn't a critical engine part, I wouldn't sweat getting them to the exact torque spec. That's probably why they aren't specified in the manual. Just get them a touch past snug and that should be fine. Like Dadogs, when I replaced my alternator cover on the left side that's how I tightened the bolts holding it on. Just a touch past snug. No leaks and certainly not over tight.
razorbike is offline
post #6 of 6 Old 10-26-2006, 07:53 PM Thread Starter
joeer77's Avatar
Great
Ok thanks for the advice. I was just a little concerned about crushing the rubber gasket between the clutch cover and clutch housing. Good n tight it is.
joeer77 is offline
