900RR rear caliper holder - Wrist Twisters
post #1 of 10 Old 03-08-2009, 01:46 PM Thread Starter
Ben
HondaStreetfigh's Avatar
How do I modify it to make it work on my 919?
2 > 4
HondaStreetfigh is offline
post #2 of 10 Old 03-09-2009, 08:18 PM
9nineteen's Avatar
Donation BOTM
To keep the caliper holder from spinning, a "tongue and groove" method is used on both the 919 and the 900rr.
The 919 has the "tongue" mounted on the swing arm. The 900rr has the "tongue" on the holder. Take a look at the 900rr holder. . .there is a "groove", not deep but still a groove, right below a threaded hole. This shallow groove will now serve as, you got it, the mounting "groove" on the 900rr holder. This groove's depth can be increased by using an 8mm bolt in the threaded hole. But the best way is to have aluminum square rods welded above and below the groove to deepen (for added strength) and lengthen (for chain adjustment allowance). Cut off the old mounting tongue off the 900rr caliper holder for a clean look.
9nineteen is offline
post #3 of 10 Old 03-10-2009, 09:51 PM
Fat guy on a little bike!
Byrdman's Avatar
Maybe a stoopid question but, why?
Any pics of the change?
Jeff
Byrdman is offline
post #4 of 10 Old 03-10-2009, 10:24 PM
9nineteen's Avatar
Donation BOTM
This relates to those of us who have done the 6-spoke wheel conversion, the rear wheel coming from the 900rr. I'm the guilty party starting this wheel conversion following, which is fairly inexpensive. When I got my 900rr rear wheel, it came with the rr's smaller 220mm rotor. . .the 919's rear rotor is 240mm, thus needing the 900rr's caliper mount which brings the caliper toward the wheel's center to match the 220mm rotor. I liked the smaller rotor, very sportbike-like, less unsprung weight, etc. The rear brake is used basically for trail-braking stability anyways, not all-out stopping power. There's no real need for the 919 "bigger" rotor. ---So that's it. . .the reason is simply to run the smaller 900rr rear rotor. This rotor conversion can applied to the 919's stock wheel as well if one wanted to.
post #5 of 10 Old 03-11-2009, 05:35 AM
3dcycle's Avatar
if we did not want to mess with the 900rr holder we could in fact run the bigger 919 rotor right?
3dcycle is offline
post #6 of 10 Old 03-11-2009, 07:44 AM
I'm going riding.
scrat's Avatar
yes, the larger rotor does fit. it truly is a matter of preference, the larger rotor will provide more 'feedback' and more braking power for the amount of effort on the pedal. if you have a problem with keeping the front tire down, the larger rotor is nice, as you can feather the brake quite a bit easier to hold yourself at balance point. not that i condone such irresponsibility... but i've heard it's fun...
I actually have 1000rr wheels on my bike, and the rotor interchanged w/o a problem. I did have to take my time and get new bearings, seals, and make all new spacers for both axles though!
scrat is offline
post #7 of 10 Old 03-11-2009, 08:18 AM
3dcycle's Avatar
that is cool, i have wanted to do that as there are more options for the 1000rr. but not for this year will have to wait now untill i finish the other projects
3dcycle is offline
post #8 of 10 Old 03-11-2009, 08:22 AM
I'm going riding.
scrat's Avatar
lol...i had to do it out of necessity, i had a slight 'run-in' with three curbs one day when we were playin in the parking lot...doh! i also noticed the liteRR rear wheel is a size wider, and a 190 looks good on the back
scrat is offline
post #9 of 10 Old 03-11-2009, 08:32 AM
3dcycle's Avatar
yea i would think it would look good untill i can afford it, it will be a dream in the back of my head.
3dcycle is offline
post #10 of 10 Old 03-11-2009, 10:39 AM
I'm going riding.
scrat's Avatar
it doesn't look much different, but the wheels are gloss black instead of the satin/ charcoal color, and the cush drive on the new rear wheel is the 6-vane style, supposedly much stronger than the 5-vane. i did have to buy a new sprocket, also. i like it though now i have wheels that are round and can get my tires to hold air again! too bad it wasn't so easy to un-explode my knee that bent all sorts of wrong directions when my foot hit the ground at 40mph...
scrat is offline
