2 Cylinder 919 - HELP! - Wrist Twisters
post #1 of 39 Old 10-02-2009, 10:21 AM Thread Starter
So I go out to meet up with the local IT guys from different companies for lunch. I take my 919. It's been running perfectly ever since I had that kill switch incident about a year ago. Let's not go there. It runs like a champ to lunch, couple miles of city streets and a few miles of highway.
On the way back to the office, I take the exit from one highway to another, pass a car, and in 2nd or 3rd gear at about 6,000 RPM, it falls on its face. Spits, sputters, and just totally loses power. I roll off then back on the throttle and all is fine. At this point, I'm about 2 miles from the office.
Once I get within sight of my office, I take the street that runs next to it because it is desolate and straight. I'm going to try to re-create the problem. I get on it in first and take it to about 8,500, no problem...shift to second, and as soon as it hits 7,000, it does it again, just falls flat like it's misfiring. I roll off, drop the revs to about 5,000 and it runs fine. I roll back up and right at 7,000 it falls flat again. I decide to just stay low in the revs back to the office, but now it's just poorly (I can tell I'm at least 1 cylinder down) I immediately pull off so I can listen to it idle. It's idling smoothly, but sounds like a ninja 500.
I was less than a half mile from the office so I limped her on back. Parked and found that the header pipes for Cylinders 1 and 4 and cold as ice.
So at this point, I'm going to start my search at the coil. I'll raise the tank, swap the coils and see if the reverse happens (2 and 3 dead while 1 and 4 run).
Anyone else have any ideas?
BTW: About 2 weeks ago, I pulled all the plugs and replaced them. I've had the SATO pipes on for a while without a PCIII so I wanted to take a look at them. That's the last maintenance I've done.
post #2 of 39 Old 10-02-2009, 10:44 AM
McCrimmon's Avatar
Go back and look at what you did last...Check wires and plugs. More then likely you'll find your problem
2008 Yamaha FZ1-Street
2005 Honda CBR 600rr-Track
McCrimmon is offline
post #3 of 39 Old 10-02-2009, 10:48 AM
tc919er's Avatar
I was leaning towards water/crud in your gas or gas...but 2 cylinders cold? You didn't get plug wires wet?
"No freeman shall ever be debarred the use of arms."
---Thomas Jefferson 1776.
tc919er is offline
post #4 of 39 Old 10-02-2009, 10:49 AM Thread Starter
I already made sure the boots were securely attached to the plugs, and checked the wiring as good as I could without lifting the tank.
Here's the next question. Should I limp it home or have my wife pick me up in the truck? I'm leaning toward just having her pick me up, except for the fact that all the Hardley guys will still be here and will give me a hard time about my uber-reliable Honda being in the bed of a truck.
post #5 of 39 Old 10-02-2009, 10:51 AM
I wouldn't run it on two cylinders, seems that gas could build up in the two dead cylinders assuming the injectors are still pulsing.
post #6 of 39 Old 10-02-2009, 10:53 AM
McCrimmon's Avatar
I'd still recheck your maint stuff. Check to ensure you have spark to all plugs.
Just pretend your working late and pick up secretly ay night
post #7 of 39 Old 10-02-2009, 10:58 AM
Ride it off into the sunset then have her pick you up two blocks over, nobody will be the wiser. When it's fixed tell all the Harley guys it got Harleytosis from being around harleys in the parking lot but it's all better now.
voodooridr is online now
post #8 of 39 Old 10-02-2009, 10:58 AM Thread Starter
I will. I'll take a break in about an hour and go dig on it some. As for the ninja stuff, I'll just have her pick me up. She knows Veronica (my 919 or maybe that's 459.5 ) is my daily driver and stuff happens.
Most likely I'll just catch a ride home with someone from work then come back and get it.
post #9 of 39 Old 10-02-2009, 12:30 PM Thread Starter
Update...
I took a little break and looked at my problem a bit. When I first walked out there, I decided to just see if it would fire back up.
It fired and ran on all 4 cylinders for about 20 seconds before dropping to two. Then a few seconds later, all 4 were lit again. It continued this cycle for a bit.
I shut it down then unplugged and re-seated the wires going to the coil for cylinders 1 and 4.
Fired it up again and it ran on all 4 for a long while. Maybe a minute or so. Then it started the 4-2-4-2 cycle again. When running on 2, I can slowly give it gas and when the RPMs get up, all 4 pickup. However, holding steady at 2,000 - 2,500 RPM, it still cuts out and drops to 2 cylinders occasionally, then all 4 pick up again.
The tools in the tool kit do not allow me to get to the bolt holding the tank in place so I'll have to wait until I get home to swap coils.
I'll post up my findings after pulling and cleaning the plugs, and swapping coils.
post #10 of 39 Old 10-02-2009, 12:39 PM
4 whls good 2 whls better
starman's Avatar
Two cylinders to go out at once pretty much has to be either spark or fuel, doesn't it?
You took out the PCIII, meaning you messed with the injector connectors into the ECU. I'd reseat all those connectors.
If the injectors are firing and there's no spark, raw gas would be coming out the tailpipe. Hydrocarbon emissions would be through the roof, if you've got a convenient way of measuring that. I'm not experienced enough to know if the mufflers would stink of raw gas.
starman is offline
post #11 of 39 Old 10-02-2009, 12:53 PM Thread Starter
I've never had a PCIII on the bike.
When running on 2 cylinders, it is definitely running rich. It smells like a gas station right now. I'm guessing that the first time it backfires, the Satos will catch on fire from all the raw fuel absorbed into the packing material.
post #12 of 39 Old 10-02-2009, 12:54 PM
McCrimmon's Avatar
Should've bought a Yamaha
post #13 of 39 Old 10-02-2009, 01:11 PM Thread Starter
I don't know. I have some rubber hose for the coolant system on my 919 that says Yama###ta.
I can't believe the system censored the name of the company that makes rubber hose for Honda!!!
post #14 of 39 Old 10-02-2009, 03:32 PM
McCrimmon's Avatar
I'm sure when you'll figure it out and it will be a simple issue, bad plug, bad connection between plug and wire
Wish you luck either way
post #15 of 39 Old 10-02-2009, 03:43 PM
Where's Bucky when you need him? He's always good for a few sensitive words of encouragement.
post #16 of 39 Old 10-02-2009, 04:17 PM
Fat guy on a little bike!
Byrdman's Avatar
If you need a coil or other ignition parts for testing, just scream. I have a few extras just laying around here.
Jeff
Byrdman is offline
post #17 of 39 Old 10-02-2009, 04:23 PM Thread Starter
Update.
It isn't the coil.
I swapped coils and got the same result. So...something is broken between the coil and the ECU? I'm getting ready to go out with my wife for a while so I won't be back at it for a few hours.
Where do the wires from the 1&4 coil go? Do they go all the way back to ECU or what?
I was hoping it would be something as simple as replacing the coil or plugs, but that isn't going to be the case. Now, I'm guessing a bad spot in the wires leading to the coil or bad part that controls the ignition. Hmm....ideas?
post #18 of 39 Old 10-02-2009, 04:42 PM
Speed Lover
XRCajun's Avatar
If you smell fuel then the problem is the spark is missing from those two cylinders. If both cylinders keep failing at the same time then it's not the plugs or the wires. It has to be something common to both cylinders. I'm pretty sure that each cylinder has it's own coil also so it wouldn't be the coils either.
I'll take a look at wire diagram and see what seems to be common to those two cylinders.
XRCajun is offline
post #19 of 39 Old 10-02-2009, 05:20 PM
Speed Lover
XRCajun's Avatar
Okay it looks like there are only two coils but they are devided up into cylinders 1and4, 2and3. So are you sure you've got the correct cylinders not firing?
If you do indeed have raw gas and two cylinders not heating up then it almost has to be electrical and also numbers 1/4 or 2/3 not firing, that being the case the only thing it could be is the coil, the connector or wires to the ECU, or the ECU.
XRCajun is offline
post #20 of 39 Old 10-02-2009, 05:53 PM
Curmudgeon
semi_gray's Avatar
Update.
It isn't the coil.
Just to be clear, the same two cylinders misfired after the coil swap?
semi_gray is offline
post #21 of 39 Old 10-02-2009, 06:39 PM Thread Starter
That is correct. The suspect coil worked and the known good coil quit working after swapping. This tells me both coils are good. I'm going to study the wiring diagram in the service manual and try to track down the problem.
post #22 of 39 Old 10-02-2009, 07:04 PM
McCrimmon's Avatar
It's those pesky squirrels
They nibble on anything
post #23 of 39 Old 10-02-2009, 07:31 PM
Byrdman's Avatar
If you need an ECM to play with I have one of those as well.
You can borrow it for as long as you need.
Jeff
Byrdman is offline
post #24 of 39 Old 10-03-2009, 04:43 AM Thread Starter
PM sent.
I didn't get a chance to look any deeper last night and I'll be busy with other stuff all day today and tomorrow but hopefully I'll get some time to work on her at night. I'll keep you guys updated.
post #25 of 39 Old 10-03-2009, 09:09 AM
If the wiring checks out fine might want to take a look at the fuel pressure regulator.
post #26 of 39 Old 10-03-2009, 09:16 AM
$10 says you pinched a wire with putting the tank up and down.... thats why the intermittent cutting in and out.... remove the tank and take a good slow long look for cut wires...
post #27 of 39 Old 10-03-2009, 01:16 PM
I'm with MM on this one.
Check your vac lines just to be sure............
post #28 of 39 Old 10-03-2009, 03:43 PM
If you don't already have one buy a cheap digital voltmeter. Electrical troubleshooting is soooo much easier with one. Without one you're stuck with replacing parts until it's cured or accidentally finding something. Either way it's a hit or miss operation, and likely to end up costing you a lot more than a voltmeter would.
All circuits need three things to work: power in, ground, and a load in between.
If the coil isn't getting power then the break is somewhere between where the wire crimps to the terminal and the splice in the harness where it splits off for the coils. If this is the case you will have to strip the harness cover back to find and inspect that splice. Be advised that the splice may also supply power to the injectors and whatever else Honda wanted to stop working when the EFI is powered down, so it may have more than two wires coming from it.
If it's a case of missing ground your options are a bit more limited: coil connector, wire to the ECU (no intervening connectors between the ECU and the coils, so no bad pins for an easy fix!), the ECU connector pins / mating issues with the gang plug, and the ECU itself. This is very rare.
You already eliminated the coils (load), so it isn't relevant here.
Look for worn spots on the main harness outer covering -- they may indicate a point where rubbing and vibration has broken a wire. Also check the condition of the wires where they crimp to the terminals at the coils: quite often the copper conductor will fatigue and break without affecting the vinyl insulation. To check for this gently try to pull the wire away from the terminal -- if it is broken the insulation will stretch without detaching. If it feels solid stop pulling!
That's it for now. Good luck.
post #29 of 39 Old 10-03-2009, 04:56 PM
Wookie
ragdoll's Avatar
I was going to suggest there might be a sheet of metal under your seat shorting it out.
'02 RC-51
'10 Unicycle
ragdoll is offline
post #30 of 39 Old 10-03-2009, 07:37 PM Thread Starter
Thanks for the advice. I have a Fluke 77 III so I should be able to follow the ignition troubleshooting procedure(s) from the shop service manual. I took a quick (minute or two) look at the wiring harness and everything looks great. There are no rubbed spots. I'll check the little spade connectors and the other items when I have more time.
post #31 of 39 Old 10-04-2009, 05:42 AM Thread Starter
SOLVED!!!!!!!!!!
My problem is solved!
I finally had time to really sit down and look at it. That, plus Rob's advice on tugging the wire at the coil connectors, allowed me to find my problem and fix it. I have had the #1/#4 coil off twice (valve job, block-off plates) and Guess I broke the yellow/blue wire at the connector. I gave it a quick tug (checking wiring before following ignition troubleshooting from the manual) and the connector fell right off in my fingers.
I picked up a small box of weather resistant/proof spade connectors from Wal-Mart, went ahead and replaced both ends for the 1/4 coil (so it didn't look dumb or Jerry rigged) and fired it up. Rode around about 5 miles this morning and she didn't even hiccup.
Thanks for the suggestions and offers for parts/help. I guess I don't need them. Once again, Honda's quality shines while some idiot (probably me) broke something by tugging on a wire too hard.
post #32 of 39 Old 10-04-2009, 05:48 AM
Speed Lover
XRCajun's Avatar
Yeah for you Chris!
XRCajun is offline
post #33 of 39 Old 10-04-2009, 10:49 AM
Congrats
post #34 of 39 Old 10-04-2009, 10:54 AM
Good job troubleshooting. Glad you got it figured out and are back on the road.
garyb900 is online now
post #35 of 39 Old 10-04-2009, 10:57 AM
Trackday Recognition Donation
Good job
Bugs: 0
Cmurphy84: 1
gpzTurbo is offline
post #36 of 39 Old 10-04-2009, 02:15 PM
No that's not it.
It's the fuel regulator.......
aw, what the hey, good job!
post #37 of 39 Old 10-04-2009, 06:48 PM
Byrdman's Avatar
Great news Chris. Glad you got it fixed.
Jeff
Byrdman is offline
post #38 of 39 Old 10-04-2009, 07:08 PM
Self proclaimed idiot....
Border's Avatar
That is why this forum is so great.....
Glad to hear it got straightened out.
Border is offline
post #39 of 39 Old 10-04-2009, 07:34 PM
Survivor/Broken&Busted
yostevo052's Avatar
Community Service Veteran
woo ... glad to know i'll definately be able to rely on this place ... (probably mostly rob) for advice if anything totally out of the box goes wrong with my bike ... lmfao ...
yostevo052 is offline
