16k check up question - Wrist Twisters
post #1 of 6 Old 10-23-2007, 08:32 PM Thread Starter
Newfie
karlb63's Avatar
I had my 919 in for my 16k maintenance today. I was told it takes 5.5 hrs to complete. I stayed cuz I wanted to see the valve adjustments while it was being performed. Needless to say they never told me when it was being done and the whole job was done in 4 hrs including new tires. I asked the service counter how could they check the valve clearances without removing the gas tank and they responded that it was marked as completed. I did notice that the "head pan" bolts were adjusted but I was still suspicious whether or not they went in and adjusted the valves. I just wanted to confer with the rest of you whether this is normal, or a case of concern to the quality of the dealership.
karlb63 is offline
post #2 of 6 Old 10-23-2007, 09:48 PM
919 City Pilot
Pegjumpflyer's Avatar
I always mark my bolts...I hate it when they pencil whip something as serious as valve clearances.......
AT 16k 2 cyl needed shims on mine..... Tank should come off for easy access
Pegjumpflyer is offline
post #3 of 6 Old 10-24-2007, 05:45 AM
How do you know the tank wasn't removed? Also, I didn't think you had to remove it to check valves, just raise it.
post #4 of 6 Old 10-24-2007, 06:23 AM
919 City Pilot
yes up....pretty fast to do ~sry.........
post #5 of 6 Old 10-24-2007, 08:13 PM
touring919's Avatar
Definitly have to raise the tank. Not remove it. Checking the clearance takes less than a 1/2 hour no problem. So they could have done it without you noticing if you were off looking at new bikes in the showroom. Last I check my valves were right at nominal with 46k miles on them. Never needed adjusted.
touring919 is offline
post #6 of 6 Old 10-25-2007, 06:24 PM Thread Starter
Newfie
karlb63's Avatar
I feel better now thx.
karlb63 is offline
