02 919 Rear axle bolt and nut size - Wrist Twisters
post #1 of 10 Old 10-15-2008, 01:05 PM Thread Starter
STPDSQD's Avatar
I need to adjust my chain but I don't have a wrench or socket that fits either bolt. Does someone know the sizes off hand so I can pickup some sockets on the way home from work?
Thanks,
Jason
I got no time for the jibba-jabba. - Mr. T
STPDSQD is offline
post #2 of 10 Old 10-15-2008, 01:55 PM
The nut is 27mm or 1 1/16", which fits a little better. Use a socket -- there is little clearance for a box wrench and the slot the nut sits in restricts the rotation of a wrench.
The hex on the axle is 22mm or 7/8", either of which will work fine.
The hex ends of the adjusters are 8mm or 5/16".
I got my 1 1/16" socket at a pawn shop for $3, and if you can't find a 7/8" wrench there as well you're not trying very hard.
When the chain is adjusted torque the axle nut to 69 Ft/Lbs, or 4.901 × 10^-18 light year / grams, or 2 3/4 grunts.
post #3 of 10 Old 10-15-2008, 02:01 PM
...or if you just want to spend a little more ($300), you can get the 283 pc Craftsman tool set from Sears. The largest 1/2 in drive socket is a 27mm and the largest 3/8 drive socket is a 22mm. How do I know??? That's the set I have and I just adjusted my chain last weekend. Torque wrench not included. That's another $75.
Sears has the sockets fairly cheap too.... 22mm for 2.99 http://www.sears.com/shc/s/p_10153_12605_00943585000P and the 27mm for 6.99 http://www.sears.com/shc/s/p_10153_12605_00944243000P. I don't know why they don't list a 6-sided 27mm.
post #4 of 10 Old 10-15-2008, 04:04 PM
i use my buddies tool kit.. he is a harley mechanic... 2 large sets of vice grips and a ball-peen hammer.....
post #5 of 10 Old 10-15-2008, 04:19 PM
PHOBMAN's Avatar
Tighten it till it strips, then back it off a half a turn!
PHOBMAN is offline
post #6 of 10 Old 10-15-2008, 04:57 PM
Crap, thought it was a quarter turn not half. Gotta go fix mine.
post #7 of 10 Old 10-15-2008, 08:09 PM Thread Starter
STPDSQD's Avatar
All the info in one place! Thank you.
STPDSQD is offline
post #8 of 10 Old 10-15-2008, 09:02 PM
Lone Wolff's Avatar
For mine, the 1 1/16" worked way better than the 27mm. The 27 was too big. It would work, but had way too much slop. The 1 1/16 was a perfect fit.
2006 Honda 919
Lone Wolff is offline
post #9 of 10 Old 10-16-2008, 04:03 AM Thread Starter
STPDSQD's Avatar
My other bike has a cotter pin to secure the nut, since the 919 doesn't is loctite needed or recommended?
STPDSQD is offline
post #10 of 10 Old 10-16-2008, 06:36 AM
on my 07 the nut has a nylon lock insert thingie...
